Question about GE WSXH208A Front Load Washer
I washed a feather pillow and it busted, now it wont pump water out.
The pump just makes a clicking sound and the door is locked. do you have instructions on taking off the pump and cleaning it out?
  • zzzrondazzz Nov 20, 2008
    actualy, the cover came off with 2 screws and opened the pump drain. hard part was catching all the water and feathers in a bowl for dumping. no experienced needed. i love my washer...
  • rshawnhorton
    rshawnhorton Jul 29, 2012
    Wow! Thanks so very, very much. My daughter and I were able to unclog my washer! The manual gave no indication as to where to even go into the machine! We are women hear us roar...but only with your help of the solution below. Thanks again, Shawn & Lisa
There is a filter down in the bottom front of the washer (below the drum) that is probably clogged with feathers. It is a pain to get to, but once you get it cleaned out, the washer should spin and drain without problems.
Posted on Nov 08, 2008
Sounds like the fill water solenoid has bust, they are cheap to replace and fairly easy. make sure you disconnect from power supply and water supply before trying.
Jan 30, 2014 | Frigidaire GLTF2940ES Front Load Washer
Washing machine clogged with feathers
The pump is plugged most of the time it is under the washer take the hoses off and clean it out. Make sure to try to get ant feathers out of the hoses also
Sep 05, 2012 | Washing Machines
Duck Feather Pillow In Washer. Feathers everywhere. door will not unlock or drain water. help
Pull off the lower front panel and reach up on the right of the washer to the door lock assembly you will feel a tab hanging down pull it and the door will release. Clean out the drain filter and pump hoses etc. Rise it out and you may have to clean the filter a few times.
Nov 29, 2010 | Maytag MAH8700A Front Load Washer
Pump Pluggage
You have solved your own problem here.
The pump itself is clogged. Not sure if you are savvy with taking the pump off this model, and opening it up. It is really a workshop job rather than a DIY.Some of the bolts are in tricky places and it can also be a pain to put back correctly. The outer casing of machine has to be removed (ideally) to get to the pump easily.
Please rate my help++++Thanks for using FIXYA
May 08, 2010 | KitchenAid KHWS02R Front Load Washer
A feather pillow busted during the cycle - What do I need to do to prevent damage?
either you have overloaded the machine or else your spin speed was set on high, lower it down and it should not happen next time.Make sure there is nothing broken inside the tumble or the spinning area...
Jan 14, 2010 | Frigidaire Affinity ATF7000ES Front Load...
Waont drain
I would check the pump.
Follow the drain hose back to the pump, disconnect the outlet hose from the pump and disconnect the inlet hose from the pump. Look inside both hoses and the pump for pillow pieces.
The pump may have to be removed for cleaning, you should be able to turn the pump by hand, if not, replace the pump.
Inner tub.
Run some water in the washer with the inlet hose disconnected from the pump. You'll need a pan or bucket for the water to run into and look for pillow pieces.
Dec 21, 2008 | GE Washing Machines
Samsung WF448AAP maybe clogged with feathers.
dont put expensive pillows into a washing machine.
Dec 12, 2008 | Samsung WF337AA Front Load Washer
Water Won't Drain from Washing Machine
Hello phylislw61,
If you had an incident where a pillow broke and feathers where dispersed throughout the washer..then there is a good chance that teh drain fiilter screen, pump or hose feeding the pump is clogged. I would verify that the filter is free from anything that would limit water flow from getting to the pump.. then if the problem is still there.. examine the pump itself to make sure it isn't clogged...
If you or someone in your family is reasonably handy, here is a link to your washing machines exploded view and parts and this should provide sufficient information for how to access the pump and associated hoses etc that feed into and out of it for cleaning..
If you are having problems after you verify the lines are free of restriction, feel free to contact me and I will try to assist you in solving your problem.. Here is the link..
Dec 06, 2008 | Roper RAS8445KQ Top Load Washer
GE WSXH208A Front Load Washer Logo
402 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
