Question about Philips 17MD255V Combo
No picture under any source, TV, DVD, PC etc.
Niece may have played with remote. Good sound, Flash source selected or TV gray screen for 1 instant after turning it onthen goes black. So not a bulb problem.
  • 3 more comments
  • melody811 Oct 25, 2008
    I cannot see setting because I have no screen. A flash when it first is turned on then black screen.
    No, that will not work. I have a black screen except for the a second when it is first turned on.
  • melody811 Oct 26, 2008
    I already did that one, but thanks.
    Thanks but so far no fix.
    okay
  • 6,487 Answers
Did you try resetting the settings of the TV using the remote to make sure that this is not just a settings problem on it...
Posted on Oct 25, 2008
  • Mark Gil
    Mark Gil Oct 26, 2008
    Did you unplug the tv for overnight and check if that will reset the unit?
  • Philips Master
  • 19,396 Answers
Check the ribbon connector to the display.
Posted on Oct 27, 2008
  • 905 Answers
If you have already tried resetting and unplugging for a while , then something has happended to the video proocessing board inside the unit. it will need to be tested to determine the exact cause of the failure. if you have a warranty I would use it, otherwise you will need to take it to your local repair shop.
electech
Posted on Oct 26, 2008
  • jason Oct 26, 2008
    if you need any further assistance , don't hesitate to ask
    electech
    President:
  • 2,712 Answers
You could try a hard reset first..unplug Tv from power source and cables for about 1 hour and replug everything and see..
I have samsung plasma tv hpp5071x/xaa when i push the power button with remote control, i can hear cliking sound and looks like turn on and see red led light at the bottom right corner and also saww flash...
Hey If you have tried Using remote and side pannels Have you tried another TV to see if its the Cable? Also The clicking sound is normal its the TV's Power-source starting. The fan light I am not sure of but if it happens every-time it should be normal. If the screen gets warm Instantly (Hotish) Then you TV is dead D:
Mar 14, 2014 | Samsung PN42A450 Plasma TV
Video monitor
you connected the sound via optical spdif .......if the reciever has HDMI use that if not....select the correct device by going through the receivers selector .....ie: AV, DVD, CD, etc etc...you will find the picture when doing this. should work, also ensure the Tv source has been correctly set as the "SOURCE" on the tv remote.
Feb 03, 2014 | Kenwood VR-409 Receiver
When the dvd player plays EC1 is displayed on screen
Hi.
EC1 means "External Channel 1". EC! indicates one of the eternal connections. If only EC1 is displayed and you get no picture then you have the input tuned on the wrong connector. Try using the source/input select button on DVD remote to find the right input.
If the On screen display belongs to the TV the source/input select button on TV remote.
If EC1 is displayed and you can play movie, than that is normal.
Regards.
Ginko
Sep 03, 2011 | Panasonic Televison & Video
In the select Video window I do not have the buttons or a picture
Hi and welcome to Fixyah,
Open your Instant DVD recorder and then go ahead and select Go Direct to the advance mode. ONe window showing out there. Select your Dazzle dvc device and then click on options. Now click on video input and then click VHS input. On video input choose video composite if your video cable is yellow, red,white cable. Then click okay. Make sure that your cable is direct connect to the video out put of your camcorder. If still the same thing uninstall your video device driver. Video device is located under control panel>system>hardware>sound video and games controller then right click on pinnacle video and audio device uninstall. Restart the computer.
Mar 29, 2010 | Pinnacle Dazzle DVD Recorder
Tv has only snowy screen. Used the remote to
What to do if you have an all snowy picture (blue screen or the TV displays unusable signal-no signal or no sync)
1 – If you are using a digital cable box or satellite receiver (make sure it’s on) and be sure your TV is set for either CH3 or CH4 (which ever you usually view it on). If you usually view it through video inputs (video1 or 2 etc.) make sure the appropriate input is selected.
If you still don’t get a signal see if you get picture using the DVD or VCR (if available) if you do than plug the satellite or Dig. Box temporarily into the place of the DVD (unplug DVD) you may have to use some A/V cables (RCA yel./red/wht like the ones on the DVD) to hook to the tv from the sat./dig. box. If you get a signal then the sat./dig box is ok. If not the Sat./dig box is not sending a signal and is either defective or needs to be rebooted (unplug wait 5 min try again).
2 – If you are using standard cable or antenna (source) if possible check that the source is good by connecting to another TV. Otherwise try running the source into a VCR and then out to the TV using video inputs (RCA yel./red/wht like the ones on the DVD) and then selecting the appropriate input. Try seeing if the VCR plays using standard CH3 (or CH4)
If the VCR plays on video input but not when connected to CH3 (CH4) then the tuner of the TV may be defective – see if you can use the VCR to change channel using the VCR remote.
Be sure to vote/rate me if this helped Thanks!
Nov 24, 2009 | Toshiba 32AV502U 31.5 in. LCD HDTV
When tv is turned on with cable channels picture is snowy. when dvd or vhs tape played through tv the picture is snowy
Try using the video inputs
Nov 13, 2009 | Televison & Video
Rca 20F514TD blue screen
Nov 05, 2009 | RCA 20F514TD 20" TV
We moved tv from living room to bedroom and the screen says "unusable signal"
Oct 05, 2009 | GE 31GT720 31" TV
Dvd wont work.
First, is the DVD player output (Video out, audio out) connected to the TV input? Have you used the Yellow cable from  DVD video out to the TV video in? Mixing the audio and video cables will result in no signal. Have you selected the proper input with your TV remote control. Most plasmas accept a variety of input signals; you must select the right one. I deal with a number of these issues. Usually the connections are made improperly or the correct input source is not selected with the TV remote. Put a DVD in the player and press play. Be sure you have made the proper connection from DVD player video/audio out into an auxiliary or video input on the TV. These could be labeled Line 1 or Line 2.  With the DVD playing, run through the input options on your remote control. The button might be marked source, video or input. The screen should display your choices i.e. video 1, video 2, etc. When you see your DVD program, you've got the right combination.
Dec 13, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Lost manual...I cannot get DVD or VCR to record
You need to decide which set of inputs or outputs you want to use. To record, and watch what you have recorded on your TV, you will need TWO sets of audio/visual patch cords. One for recording and the other for playing. Let's start with the recording. Look for the Line in or video in plugs on your DVD-VCR unit. Some recorders have separate inputs for the VCR and DVD. Others let you select with the remote. Usually Line 1 is at the back and Line 2 is on the front. Your remote will have "recording source" to let you select, or sometimes you can use the channel up and down arrows to select your input source. Your remote will also allow you to select either the DVD or VCR for recording. Connect the Yellow plug to the Video In socket, and the red and white plugs to audio in., Connect the other end of the cord to the TV or cable box. Yellow goes to Video Out, red and white go to audio out. Recording from the cable box is much easier because you wiull always have a signal going into the DVD-VCR recorder no matter what happens at the TV.  Now look for the Video out connection on the DVD-VCR recorder. Connect the Yellow plug to video out and the red and white plugs to audio out. Ignore the other connections at this point. They are for RGB component video. Your DVD -VCR should have one output for both functions. Use that one.
Now connect that cord to a Video one or Video 2 input on your TV.
Test the set-up. Play a DVD or a VHS tape and try to bring it in using the TV remote.
Then turn on a program and try to record it on  the DVD-VCR, then play it back.
This sounds very complicated, but all that's involved are two patch cords with three plugs on each end - 12 connections in all and color-coded. YELLOW is always video.
Dec 13, 2008 | Philips Magnavox DVD/VCR Dual Player
Philips 17MD255V Combo Logo
321 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
