Question about HP Scanjet G2710 Flatbed Scanner
The scanner can not scan and makes some sound (HP scanjet G2710) model FCLSD-0512
My scanner can't work its used hocked along the way and makes some sound.
bandana_gyrl
  • 181 Answers
SOURCE: HP Scan Jet 3200C scanning problem
I would say the most likely cause of the issue is either that the scanner is no longer functioning or that it is experiencing power issues. Make sure that the scanner is plugged in directly to the wall and not into a surge protector or a power strip. The scanner does not share power well and pulls it in large amounts - when it can't get it it throws little power fits and sometimes will not turn on at all. Try another wall outlet and see if you can get it to power on and do a scan without the yellow strip showing up.
Posted on Feb 28, 2008
ziraffa
  • 827 Answers
SOURCE: Unable to scan using HP Scanjet 3200C in Win XP Pro
Hi Shantala,
HP advises that, on some systems, the scanner hardware may get into an error state that will keep the scanning software from finding the 3200c ScanJet. If your scanner still isn't found after installing this driver and software update, please follow the directions below:
  1. Unplug the power cable from the 3200c ScanJet.
  2. Unplug the parallel cable(s) from the 3200c ScanJet.
  3. Shut down the PC and wait for ten seconds.
  4. Plug in the power cable to the 3200c ScanJet.
  5. Plug in the parallel cable(s) to the 3200c ScanJet.
  6. Power your PC on.
If you still have the problem, uninstall the driver from device manager, and download and run this .exe file version of the driver instead.. and if necessary, repeat the above steps..
ftp://ftp.hp.com/pub/softlib/software4/sj648/sj-1436-3/sj648en.exe
Hope this helps
Chris (ziraffa)
Posted on Dec 22, 2008
  • 489 Answers
SOURCE: Software for HP Scanjet 3200C, OS = WinXP
ftp://ftp.hp.com/pub/softlib/software4/sj648/sj-24149-1/sj648en.exe
try this
rate pls.
Posted on May 28, 2009
  • 310 Answers
SOURCE: driver and software for HP Scanjet flatbed scanner is outdated
Go here to download: http://welcome.hp.com/country/us/en/support.html
Posted on Sep 30, 2009
AldRezaine
  • 995 Answers
SOURCE: ARE THERE REPLACEMENT bulbs for an hp scanjet
Yes it has a replacement. Try to find it in some computer stores.
Posted on Oct 30, 2009
Hp Scanjet Tma Fclsd 0508 C9911b drivers downloads
ALGUIEN PODRIA DECIRME EN DONDE CONSIGO LOS DRIVERS PARA EL SCANER hp MODELO FCLSD-0508
MUCHAS GRACIAS
May 21, 2012 | Office Equipment & Supplies
How do put ink in a priner when its finished please
RTM - Read The Manual
Get online and got to www.google.com Inthe google search box type: "HP Support" (without the quotes andput your manufacturer name before Support). Look for downloads anddrivers. Enter your model number and operating system whenrequested. Look for Manuals and documents.
Apr 23, 2012 | HP Scanjet G2710 Flatbed Scanner
Twain driver for hp scanjet G2710
I just wonder how to choose the right twain scanning API for the scanner. By the way, you can ask your question at HP support forum, also, like
http://h30499.www3.hp.com/t5/Scanners-Experts-Online-Now/64-bit-Twain-driver-for-HP-ScanJet-G2710/td-p/2337525#.U3k8IHYoZ2M
VB NET TWAIN TWAIN Scanning Using VB NET
Jan 18, 2012 | HP Scanjet G2710 Flatbed Scanner
I can"t scan to PDF
Hi
Use the Scan to PDF software to direct convert your scan page to PDF, download the software to click hear
and simple to install to this software, after installing you get the shortcut in your desktop double click that one and open your scaner is automatic install there put the document in scanner and click scan after scanning click save to PDF and give the save file name and save.
Nice one may it is resolve you problem.
Cheer
Jun 23, 2011 | HP Scanjet G2710 Flatbed Scanner
Scanjet G2710 on XP sp3. After full install, only driver is installed. No error messages. Uninstall offers only driver uninstall, no sofware.
First install the required drivers for the HP Scanjet G2710 Flatbed Scanner.
Simple way is to scan is use PICASA
GOTO http://picasa.google.com/
Download picasa 3.8
  1. Make sure everything is connected and turned on!
  2. Put the photo on the glass of the scanner - face down
  3. In Picasa, click 'Import'
  4. Click the arrow for the drop down list of devices. You should see your scanner listed ... select it
  5. Now you will see a screen that depends on your scanner. There should be an option to 'Preview'. Click that.
  6. You should now see your picture, there may be some settings you want to change here, but if it looks OK then
  7. Click the button to Scan
  8. When it's done scanning, you're back at the standard Picasa Import screen. Click Import all.
  9. Select a folder to put it in. I made a folder called 'Old Photos' for the first one, then, for each subsequent scanned photo, I selected that existing folder from the drop-down list.
If you satisfy with my solution please rate/vote for me.
Rating/Voting will encourage me to help others
Jun 09, 2011 | HP Scanjet G2710 Flatbed Scanner
I need a HP Scanjet G2710 Operating Manual
http://h20000.www2.hp.com/bizsupport/TechSupport/CoreRedirect.jsp?redirectReason=DocIndexPDF&prodSeriesId=3423844&targetPage=http%3A%2F%2Fbizsupport2.austin.hp.com%2Fbc%2Fdocs%2Fsupport%2FSupportManual%2Fc01825496%2Fc01825496.pdf
Apr 17, 2010 | HP Scanjet G2710 Flatbed Scanner
Hp scanjet G2710 scanner isnt scanning the whole document.the light only moves half way then stops
If you are scanning via software then the software could be looking for a smaller image. Check the preview and adjust the size as necessary.
Apr 30, 2009 | Office Equipment & Supplies
HP Scanjet G2710 Flatbed Scanner Logo
56 people viewed this question
Seeker5211
Seeker5211
