Question about Proscan 19LA25Q 19 in. LCD Television
REMOTE NOT WORKING
I went top use the remote & it's not working. I have changed out the battries wih new ones still havethe same problem. Is there a way I can get it fixed or replaced.
    President:
  • 2,712 Answers
If there is something wrong with the internal circuitry of the remote, then it would be cheaper to just get a replacement. You can try either
a) The store you bought the TV from
b) The manufacturer
c) http://replacementremotes.com
Hope that helps! Kindly rate this solution a Fixya! if it helped you in any way.
Cheers!
ID
Posted on Oct 25, 2008
How do i fix my remote to work my home theater. i have a htp-071 and my remote stopped working. the battries are brand new. I went away for the weekend and came home, remote didnt work. please help.
Test remote for operation. Problem is with either the remote or the receiver in the home theater.
Clean all battery contacts and install new, tested, working batteries in remote. Turn on am radio and tune AM dial to about 600 - turn up volume. Then bring remote to about one inch from radio and hit button on remote. You should hear a beep as long as you hold the button down. Every button will respond likewise. If nada at all remote is trashed, if works with some buttons then you have a partially operating remote. Try cleaning contacts for buttons that do not work or use some aluminum foil under those non working contacts.
Nov 22, 2015 | Pioneer HTP-071 5.1 3D Home Theater System...
AKAI 32 LEDHD tv remote stopped working changrd battries also?
some times the connectors for the the eye in front of the remote come loose due to cold solder take apart and with batteries in hold on off button and wiggle the eye see what happens or use a magnify glass and look at connections for circular cracks.and resolder.
Jan 27, 2015 | Akai Televison & Video
Remote not working as i moved tv into another room
If the remote control you've bought is a universal remote control, you have to set it with your TV, by TVs setup codes. The setup code list will be attached to the new remote controls' packing. If you wish to get more details, check the sites linked here. Set-up code list, and Set-up procedure to many popular brand remote controls are given.
http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Timeslide, can be selected by the drop-down list, by the top left of the display window, will make surf easy
Nov 06, 2013 | Grundig GU22DVDPX 22 in. LCD TV
I replaced my battery and now my gauges and turn signals do not work...someone said there is an inside fuse panel but i can't find it.
clean the terminals as well as te small wire connecter on the ground terminal, check all the connections under the battery, if this dose not work then go to chrysler and havethe POWER DISTRIBUTION MODUAL checked, if the service centre says you need a new one, haveit replaced, i went through all this wt my van, please do not try to purchase from salvage, ater buying 3 differnt ones @ a hundred bucks each, it is much easier and quicker to purchase new one from dealer for a thousand bucks . trust me i went through it all.
Feb 26, 2011 | 2001 Dodge Grand Caravan
The battries in remote are new. the remote wont change channels or turn power on and off.The buttons on the tv set wont work either.It keeps saying child lock is on.
As the remote is not working please
1.check the batteries are properly installed with correct polarity.(+ and -)
2.Check weather correct remote operating is set.(TV,VCR etc)
If both are OK then please programm your remote again with the TV.As you removed your battries it might reset the code
When using buttons on TV it says CHILD LOCK is ON.
Child lock fuction is to prevent children operating buttons in TV console. This can be set only by remote. Cannot set by TV console Buttons.If this fuction is activated you cannot use the TV console buttons.
Thanx
Jul 23, 2010 | LG 47LC7DF 47 in. LCD HDTV
SKODA FABIA REMOTE KEY PROBLEM
my skoda remote does not function, i have change the remote battry , yet the same. how do i go about it.
Jul 01, 2009 | Viper Vehicle Parts & Accessories
CAN'T SET TIME. TRIED TO CHANGE IT TO DAYLIGHT SAVINGS TIME MA AND IT DID NOT FUNCTION.WHEN I PLUGED IT ON, IT WENT OT 12:00 AM. DID NOT PICK UP THE TIME. I CHANGED THE BATTRIES AFTER CHECHING THE NEW...
On top of the radio is a slide bar for alarms. Slide to the far right, you will see a clock icon. Plug the phone in with it in the far right position.
Make sure your time zone is indicated. There is a switch DST, which stands for daylight savings time, which needs to be in the correct position - on or off.
Apr 05, 2009 | RCA RP5420 Clock Radio
Phillips 27 inch tv
did you check remote like battry, loose nothing is deposited near battry contact etc. if it is getting on from front board and not from remote then fault is due to remote. but if does not start from front also then problem is inside tv. like power supply or horizontal section failure. please do not forget to check plug & socket.
Oct 02, 2007 | Televison & Video
Proscan 19LA25Q 19 in. LCD Television Logo
44 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
