Question about Kenmore 70088 Air Conditioner
Kenmore Window A/C model 580.76129300
Hello;this unit quit working and showed no power at all. I replaced the main control board and worked for about 30 second and quit again. The boards looks clean with no sign of any short.I tried to buy the display control board but it was discontinue.Any ideas of the problem? Is it possible to replace the controls for another type or make?? I'm sure the compressor and fan are in good working order.Any help or recomemdations will be apreciated.
Thanks in advance;
Angel Nazario
  • 75 Answers
SOURCE: No Power to unit
Hi, How old is the unit? Is there a warrenty on it. If so, anything you do to it may void the warrenty. First, check to make sure breaker on the end of the plug is not tripped. It will probably have a reset button on it. If it will not reset it can be replaced with a regular 110 plug if needed. (If this is a 110 unit) If you are talking about the control panel on the AC when you say control box I think you are getting into more than you can handle and not sure that what you ordered is even what you need. If you want to get into it, first make sure it is unplugged, Take off the front cover and slide the unit from the outer cover, there may need to be a few screws removed to do this. Look at the wiring and see if there is anything burned or loose. Other than this you would have to get a meter and talk with someone on here familiar with your particular unit to troubleshoot it. I really don't think you should order any parts before you find out what the problem is. If there isn't anything that you can see that's wrong with it I would suggest taking it to Sears and letting then determine if it would be better to fix it or replace it. Hope I have helped. kstfas
Posted on Sep 08, 2007
  • 262 Answers
SOURCE: Kenmore Fridge- all lights blinking
sorry to say this but the mother board has took a hit replace this and all will be well
Posted on Jan 01, 2008
  • 185 Answers
SOURCE: Kenmore 72189 Air Conditioner not power on
inspect for any broken or burnt wires check thermastat compressor overload/relay selector switch and the control board
Posted on Mar 27, 2008
SOURCE: Kenmore Elite bottom freezer refridgerator
I just went through this with my refridgerator and actually posted one of the questions. Here is what I found ........
In the freezer compartment behind the panel there is an evaporator fan which pulls cold air from the freezer and pushes it up into the refrridgerator compartment. If the fan is not working it is one of three things.. 1) there is so much frost in the fan area the fan blade is stopped and cannot push the cold air into the refridgerator compartment or the air channel is blocked. 2) there is no electricity going to the fan (usually tied to the door switch of the refirdgerator compartment, and 3) the motor is dead and will have to be replaced.
Solution to #1 - defrost but there is another problem in the "frost-free" part of the system which must be addressed or the frost will return and it will happen again in the future.
Solution #2 - check to see there is power to the fan. (most are 110VAC but some are 100VDC. Use a meter and check)
Solution #3 - If there is power, the motor is dead. Replace the motor. Be aware that AC and DC motors are different and replace per manufacture's specifications.
Posted on Nov 23, 2008
SOURCE: Need Front Control Board, Kenmore Refrigerator Model 106.4410230
Solved it through parts isolation and identification.
Posted on Apr 06, 2009
Kenmore electric range model 911.95875790, no heat to either baking and broiler elements.
Hello. I looked carefully at the service manual for your unit--surprisingly, there is no thermal switch inline with the bake/broil elements. Usually, if the bake or broil elements pop, this blows out the thermal switch, killing power to the elements for safety. The main control board can get damaged due to the high current draw during a short-circuit. The part number for the main board is WB27T10008. The overlay(the decorative sticker with the button/names on it) numbers are as follows: almond WB27T10022, black WB27T10023, and white WB27T10021. I hope this helps you!
Sep 18, 2015 | Kenmore Ovens
My old Kenmore window unit has all of a sudden stopped working. Was working fine then just stopped coming on. The wall outlet checks out fine. Is there a re-set on the unit? What else can I check?
Hello, if the unit is receiving power check the capacitor, this is a round or oval can located inside the control panel of the Ac, it controls the fan and compressor operation.
May 23, 2012 | Kenmore Heating & Cooling
Bake, broil & clean buttons do not function, all others (timer, cook time,end time, clock) work fine. Therefore I cannot light the oven. The stove burners work fine.
check the main power terminal block and make sure the power is correct.if the power is correct then you will need to change the main control ever unplug the unit and check all the wiring to the control board and the bake and broil elements.if the unit is gas then you may need to replace the ignitor unit if it does not draw enough power during the light up it will not open the gas valve.replace the main main control board still applies if the other items check out fine.
Nov 03, 2010 | Kenmore Ovens
No power
The main PSU is part of the control board. You may be lucky to find an aged fuse to replace, but it's more likely a power transistor that's fried.
Unplug and remove the control board to see which bit's toasted. Chances are it's cheaper to replace the control board - but check the probable cause - the motors are not short circuited.
May 02, 2010 | Samsung DMR77LHS Tall Tub Dishwasher
My Kenmore Elite, Model 11062042100, has been working fine but now the control panel is totally dead. The interior light is working, so I know it is getting power. Any ideas? Thanks!Shaun
OK, if you are certain that the unit is receiving a power current, this will most defiantly confirm a major chip fault in in the main control board.
Try to wake the control by cutting the power to the unit for 5 minutes. if the damage isn't severe, this will either, reset the program or, render and error code. if both do not appear and the control remains blank or dead, after the reset, replace the main control board.
Jun 19, 2009 | Kenmore Elite HE4 Electric Dryer
Unit will not turn on
I have two of these units (actually it is my sister and brother in law's) but they come to me to fix stuff.
Last year they came to me with this unit not working. No indication of power on the display. I diagnosed it down to the PWB Assmebly, Main. I believe they are referring to it as a Power printed circuit board (part #6871A20271A). The new board worked for about 4 months and then quit in the same manner. Also, the second unit quit in the same manner also indicating the circuit board is bad.
I don't want to throw a board at it till I know why they are burning out. Also, want to try to diagnose the board to component level ($33.28/board last year). Let me know if this helps if you have the same symptoms?
You can replace the board but my experience says it will only last for a short time till we find the real cause (Sears must know this problem exist).
Apr 21, 2009 | Kenmore 76129 Air Conditioner
Kenmore Elite quiet pack washer quit. Please help!
The F70 and F71 error codes on this model of washer indicates a communication problem between the user interface control board and the central control unit (main control board). These error codes can sometimes be caused by a power surge or glitch through the electrical lines. Try unplugging the washer to completely disconnect electrical power. Wait 1 minute and then plug the washer back in to the see if the fault code clears. If it does, then the washer may work normally.
If the code reappears, then you could have a wire harness connection problem, a failed user interface control board or a failed central control unit. I recommend calling a service technician to properly diagnose and repair this type of problem so that the correct component can be replaced.
Be sure your unit is plugged into a 3 prong grounded outlet as well.
F71 is a "heatbeat failure" which means that your front interface control board is shorted and will need to be replaced. it's actually fairly easy to replace and can definitely be done by yourself. To access the part, just pull the unit forward and remove the 3 screws coming in from the back of the top panel. Remove the top panel by pulling it back, up, and off. Then remove all the screws going into the top of the control panel. Remove the dispenser drawer and remove the screws coming in through the dispenser. Remove the screws coming from the inside of the dryer going forward into the control panel, then remove the control panel (it's just clipped in on the bottom. After that you can disconnect the wire harnesses to the front interface control board and replace that part.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 18, 2009 | Kenmore Elite HE4 Electric Dryer
Does the 76129 Kenmore Air Conditioner have a reset button
There is no reset button on this unit that I have located. I don't think cleaning the filter will help since you could just set the unit to run without the filter.
Aug 06, 2008 | Kenmore 76129 Air Conditioner
Kenmore 70088 Air Conditioner Logo
560 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
