Question about Roper Washing Machines
Top agitator stopped moving on Roper Model AL6245VWO
The bottom agitator works but the top part quit moving back n forth like it used to.
jumptrout51
  • 3361 Answers
SOURCE: Top agitator won't spin
Your agitator dogs must be replaced.
With a flat blade screwdriver pry off the top cover on the agitator.
Remove the 7/16 bolt inside.
Pull up on the agitator and remove it.
Purchase the agitator dog kit from the appliance parts store.About $10.00.
Posted on Mar 10, 2009
milten1
  • 1304 Answers
SOURCE: My top load washer will not agitate or spin, but
if you have aaccess to the belt already,
start the machine let it fill
then keeping an eye on the motor and the clutch underneath it, sounds like your clutch might be slipping..
you will notice immediately the motor will be spinnging but the clutch will not engage
ive included the part number
and phone number to call
AP2045377
1-800-477-7278
aplliancepartspros.com
runs about 120.00
but its a pretty easy repair especailly since you figured out how to open the cabinet
Posted on Oct 09, 2009
FixinFax
  • 3085 Answers
SOURCE: agitator not moving like it should
Pull off the softener cup
remove the small cap
unscrew the bolt
remove top half of agitator
replace the plastic DOGS
Posted on Feb 07, 2010
jsrock516
  • 5911 Answers
SOURCE: i have a roper top load model RAS7133kq1. It
The problem may actually be much simpler than what you think. Before you go wasting money on a bunch of parts you may not need, check your lid switch. The most common cause of the problem you are experiencing is a lid switch malfunction. Symptoms may include, filling and stopping on the intial fill cycle, a wash tub that will not drain, and stopping right after the wash cycle and not advancing to rinse or spin cycles.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
NOTE: You do not have to drain or bail the water from the washer tub to perform this repair. Once a defective lid switch is replaced, the washer should drain normally.
A replacement lid switch (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average price is about $20 - $30 if you perform the repair yourself. Prices differ between sites so shop and compare.
If you have questions, or need additional assistance, please post back and let me know. The lid switch is a very simple repair that you can easily perform without the assistance of a repairman. I hope this information is helpful. NOTE: The pumps on these washers are strictly MECHANICAL. It consists of one moving part, the impeller. Usually, when the pump goes bad, the drive motor will STILL run, but the impeller won't turn. Or, the pump leaks, or it becomes clogged. Since you lowered the drain hose and water began to drain, the pump is not clogged. Since the washer IS agitating, this means the drive motor is still working. Without the drive motor, the washer would fill, but would never agitate.
Posted on Apr 16, 2010
marka19
  • 1430 Answers
SOURCE: WHIRLPOOL MODEL LSQ8543J TOP AGITATOR DOESNT MOVE
This is usually the agitator dogs have worn out or broke. These are very inexpensive and easy to replace. There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru the proper inspecting and replacement of these parts. You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Posted on May 15, 2010
Agitator quit working during wash cycle. If I move timer to rinse and fill with water then move timer to spin the agitator works fine and drains water from the tub
depends on what u mean by agitator works fine on spin? it doesnt do anything on spin cycle cause its not suppose to? if ur saying ur not getting any wash agitation? then I suspect ur cam dogs inside agitator are bad? remove the 7/16 bolt nut and remove top of agitator and u will see the cam dogs underneath it. there fairly cheap like 5-10 bucks for a set, if u can push the agitator back and forth when its all together in tub, and its catching the teeth and not easy to move back in forth, their not bad, but if u have no resistance then they are bad
Feb 19, 2015 | Washing Machines
My roper washers top half of the agitator stoped
you will need a flat blade screwdriver long plyers 7/16 socket and ratchet, the verry top of the agitator prys off look verry close you will see a spot to put the screwdriver, then take the plyers and carfully reach in side and pull on handle of the domed shaped piece gently. then remove the 7/16/ nut. then lift off the corkscrew top portion of the agitator. you will see 4 tear drop shaped pieces called dogs part # 80040, look at the way there in there so they can be put back right later, use a camera take pictures as you go to each step for reasembly.the thrust washer will probly need replacing to, it's the plastic washer that the cork screw part sits on. when you go to put it back together use some vasaline where the dogs go in the holder, this will help hold them in place durring assembly. look close at holder for square holes they need to line up with the flat pins on top of lower portion of agitator. use an exstention and a large socket to hold dog holder in top in agitator top wile puting it on lower half. use the bag the dogs came it to hold the bolt in the socket til you get it started, then pull bag off before tightening. use two exstentions to put inner cover back in then put main cover on you are done,be pacient this may test your pacients.
Jan 08, 2010 | Roper Washing Machines
It makes a noise but the agitator will not turn--
You need to replace the icemaker module.
The heater has gone bad that releases the cubes.
Nov 25, 2009 | Roper RT21SKXLQ Top Freezer Refrigerator
Not fully agitating
2 things
First is that I assume this not to be a 1 piece agitator. If it was the whole thing should turn back n forth Make sure its top (nut) fastner is tight. Usually just push down slightly and turn Clockwise.
A sectioned agitator has a lower section separate fro the upper. The lower can be attached to the agitator shaft and will move back n forth but the top has teeth that engage 1 way and allow slippage when the agitator comes back the other way. This "ratchet" action (some whirlpool older models that i have seen) if it has teeth ground off or grease build up under the teeth can cause them to stop agitating and just kind of sit there.
Drain and remove the clothes,
Take the top by hand and try turn it back n forth see if bottom moves. If the top is slipping and the bottom stays put remove the top nut (turn Counter Clock Wise) and try remove the upper section. If you can get it off you may be able to see why its not turning, and get the part to fix it.
Please let me know if this helped you. Rate me with as high a mark as you can. thanks and good luck.
Apr 02, 2009 | Washing Machines
Top of agitator not conncted to bottom
not quite sure as to how your agitator is nol onger connected??? but i looked up by model number and you can order and replace the complete agitator for about $50... ifhte agitator no longer "agitated" and was reemoved to replace teh agitator dogs (which is the most common issue) the the 2 halves of the agitaotr click back together by lining up slots betweeen the two halves.hoping this was a little helpful
Feb 21, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Machine will not aggitate
remove center cap on agitator remove 7/16 bolt in middle of agitator replace pull center of agitator up sharply replace agitator dogs in center section whirlpool part #80040
Dec 19, 2008 | Roper RAS8445KQ Top Load Washer
Whirlpool GSQ9632LW0 problem
looks like the agitator dogs are broken. these are the pieces between the bearing and the top of the agitator. since this agitator is a 2 piece, you can just replace the dogs.
go to www.whirlpoolparts.ca and put in your model #. it will give you a parts breakdown.
hope this helps.
c
Sep 23, 2008 | Whirlpool AWM6120 Front Load Washer
Agitator stopped moving back and forth
dismantle the agitator and see if the shaft of the gearbox is moving.its either the gearbox or the agitator
Feb 23, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Agitator-How do you get it off?
(Roper is actually made by Whirlpool) This is simpler than it sounds, just takes time and a few steps. Do you have a fabric softener dispenser that resides on top of the agitator? This dispenser simply snaps onto the top of the agitator. Some styles use a decorative cap. To remove the dispenser, simply grab it and firmly pull up. There is a cap that covers the bolt or nut that holds the agitator in place. To remove the agitator cap, insert a small flat-head screw driver into the seam between the agitator cap and the upper agitator (the part that moves). Use a twisting or prying action to pop the cap off of the agitator. Sometimes there is a little slot where you can insert the screwdriver. Look for it first. There maybe an internal debris cap under this: Inside the agitator you will see a cap with a raised handle. Simply reach into the agitator and twist the cap while pulling up. This will remove the cap and its o-ring. Removing the agitator: When looking into the agitator assembly, you will notice a single nut in the center of the agitator. Use a socket kit or nut driver to remove this bolt or nut from the agitator stud. Don't use plyers, it'll just mess up the nut. With the bolt removed you should be able to remove the agitator by simply pulling up. Twist back and forth CW & CCW when lifting. Some are a 2 piece design, so pulling up will actually remove either the whole agitator assembly or only half of it. If whole assy comes up and you may need to seperate the two for your new parts. Place the Lower Agitator on the floor and stand on the flat lip. Then Pull up to separate the Upper Agitator (mover) from the Lower Agitator. As far as your parts go I'm not sure where they go without seeing it myself. There is a spline or ratch assembly which causes the agitator to move back and forth. They are usually made of plastic and get worn or break. This might be what you are replacing. It's not clear as to what parts they gave you. Good Luck
Jul 17, 2007 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
73 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
