Question about Frigidaire Affinity ATF7000E Front Load Washer
I am geeting The LOC 50 on the washer when we press start
The washer will not start. We get the LOC 50 on the display panel when we try to start the washer
  • obone Oct 25, 2008
    Cannot start the washer. It displays a LOC 50 on the display panel
    President:
  • Frigidaire Master
  • 2,651 Answers
Your "control lock" is on, look cllsely at the control panel there should be a button {or 2 butttons} that need to be pressed and held for 3 secs to unlock the control.
Posted on Oct 25, 2008
Was does LOC mean
Hi Holly...your control panel maybe in LOCKED mode....
close detergent tray....press OPTIONS and SELECT
buttons at the same time for about 3 seconds to
unlock. I hope this works for you.
Regards,
Dennis
Sep 28, 2014 | Kenmore Elite 45986 Front Load Washer
Loc error code on Frigidaire frontloader
To avoid having someone accidentally start or stop the washer, press OPTIONS and Select at the same time and hold for about 10 seconds until the Control Lock) lights up. "LOC" will be displayed alternately with the estimated cycle time. Turning the Cycle Selector knob or pressing any button will produce flashing indicator lights and/or beeping. To unlock the controls, press and hold OPTIONS and Select for about 10 seconds. Frigidaire GLTF2940ES3 Quick Start Manual Page 3
Jul 24, 2014 | Frigidaire GLTF2940ES Front Load Washer
My frigidaire GLTF2940ES0 displays LOC when i press start
Hello & Welcome to FixYa
LOC error code is displayed when the control panel is locked, to unlock it press the OPTION & SELECT button and hold them for 20 seconds. This should reset the control, if it does not then replacing the control is recommended repair. Please get back to me if you have any other questions.
Kevin
Oct 02, 2011 | Frigidaire GLTF2940ES Front Load Washer
FRIGIDAIRE WASHER GLTF2940FS / WASHER HAS POWER BUT WON'T START/ IT DISPLAYS LOC IN THE ESTIMATED TIME WINDOW
means display is locked look for little lock symbol on panel,
press and hold key for 5 seconds
Sep 01, 2010 | Frigidaire GLTF2940F Front Load Washer
I bought this washer 5 years ago and it did not come with a book. It is now displaying LOC when I try and start it!! How can this be fixed????
"LOC" indicates that the control panel settings are locked. Press the SELECT and OPTION button simultaneously to toggle this 'feature' on or off. This will fix the issue.
Thank you !!
Aug 16, 2010 | Kenmore 3.5 cu. ft. Front Load Electric...
ERR LOC on display
Your door lock switch needs replacing.
Jul 07, 2010 | Frigidaire GLTF2940ES Front Load Washer
My friidaire washer will not start. The door lock light will not come on. The door closes properly. The error LOC comes on. Not sure what else to do. Doesn't seem to be any problem closing the door. Help...
washer, press Options and Select at the same time and
hold for 10 seconds until “LOC” is displayed alternately
with the estimated cycle time. To unlock the controls,
press Options and Select at the same time and hold 10
seconds until ”LOC” is no longer displayed.
Apr 03, 2010 | Frigidaire ATF6000ES Front Load Washer
When start is pressed ERR LOC displays, door
You can try clearing the code and then running the machine. Try colding down the pause and clear button simultaneously for three second s and the faul should clear Or try turning the knob around 9 times to clear the fault.
Jan 08, 2010 | Frigidaire ATF6000ES Front Load Washer
LOC Blinking
Control Lock
Jun 05, 2008 | Frigidaire Affinity ATF7000E Front Load...
LOC-Can't start my washer
Ok, press Options and Select at the same time and hold for 10 seconds until "LOC" is no longer displayed. Your control lock was engaged.
Nov 10, 2007 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity ATF7000E Front Load Washer Logo
144 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
