Question about KitchenAid KGRI801PBS Gas Kitchen Range
Kitchaid Gas range
After self cleaning my control panel went blank and door stays locked.
how do i fix
    President:
  • KitchenAid Master
  • 2,651 Answers
Heres the thermal fuses thats gone bad its mounted on the back wall of the unit youll need to get behind and remove the panel , unless of course its under 1 yr old then its a warr. issue part#8300802 - THRMST-FIX
Posted on Oct 26, 2008
Dacor Preference RSD30 Gas Range My wife put the
I don't see the make and model number of your unit. I only see part of your post. Please post the make and model number. It should be a simple fix. From what I do see in your post, it sounds like the control board will need to be replaced.
Regards,Richard
Oct 17, 2011 | Dacor Ovens
Door locked after self cleaning&panel went blank
NEVER use the self cleaning feature, again!!
Sounds like my problem two days ago. I have a Kitchen Aid free standing gas oven/range model
KGRI801PWH00. I read online that the thermo-fuse might've blown. I found the thermo-fuse after removing the rear panel. It was at the top/center. Mine is T-O-D (brand) 60F24; Westinghouse #8300802. I ordered mine from appliancepartspros.com for only $34.75; arrived in 36 hrs with regular shipping!! Easy to fix, sure beats several hundred $$ to repairman.
Don't bother to call Kitchen Aid - they'll just blow you off just like the hundreds of complaints said that I found online.
Jan 27, 2011 | KitchenAid KGRS807SSS Gas Kitchen Range
Self cleaning attempt has shut down the control panel.
You need an air flow kit, part 81911788 and a professional to install it.
Dec 23, 2009 | KitchenAid KGSA906PSS Gas Kitchen Range
Does Kitchenaid have a fix for this problem? Who do I contact? "After starting the Self Cleaning Mode the Display went blank and the Oven Door stayed locked. The Burner Igniters still work"
the hi-limit thermostat has been tripped. it needs to be replaced and also make sure that the cooling fan is working ok. thermostat is located behind the back panel. looks like a disk the size of a quarter with two wires on it
Nov 08, 2009 | KitchenAid KGSA906PSS Gas Kitchen Range
After using the self-clean cycle, display panel went black and oven door stayed locked.
Happens alot dont feel bad , self clean mode runs the elements at 500 deg. to cook off everything possible , what happens is the cabinet gets to hot and heats saftey temp. fuses until they go out and they are not resetable. they are always located in different areas of ranges but usaully in the back. you can ohm them out to check them if you have a meter.let me know if you have any other questions.
Phil
Apr 14, 2009 | KitchenAid KGSA906PSS Gas Kitchen Range
Control Panel went blank after self-clean cycle on gas range
youll need to pull unit out and remove the back cover, probalby 15 screws or so then youll find the thermal fuse located toawrd the top in the middle 2 wires leading to it, ble and white striped. heres the part number to order 8300802.. LIVE WIRES DISCONNECT POWER!!!!!!!!
Dec 02, 2008 | Kitchen Ranges
Kitchen Aid KGRA806PSS
hmmm....that interlock is dependent on a temperature sensor, to ensure that no one opens that door when it's too hot inside. I'm assuming that it's still locked, even after the temperature has dropped off?
Feb 26, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
Kitchenaid kgri801pbs
there is a thermal fuse in the back of the oven that more than likely has tripped during self clean poor air flow around can cause this power surges during self clean can too you have to pull the oven out and remove back panel to find it
Jan 10, 2008 | KitchenAid KGRI801PBS Gas Kitchen Range
Kitchen aid model# kgri801pbs
On most models, the door stays locked during a self clean, until the temperature returns to normal for safety reasons.
It sounds like your unit may have tripped a breaker during this self clean event. Check your panel for a tripped breaker. If the oven has cooled down, and the lock is still engaged, then we may have a different problem.
Let me know what you find out!
KitchenAid convection oven - panel went black during self-clean SOS
turn power off. take back off range. manually unlock door. it sounds like your control panel is shot.after you have it unlocked turn power on try your oven
Nov 22, 2007 | KitchenAid KGRA806PSS Gas Kitchen Range
KitchenAid KGRI801PBS Gas Kitchen Range Logo
186 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
