Question about GE WSXH208A Front Load Washer
WSXH208V1WW front load washer won't drain - faulty pump?
I have a WSXH208V1WW front load washer that will not fully drain. I have taken apart all the tubes and cleaned out as much as I can. I cannot seem to access any filters. There were a few coins and papers in the tubes but nothing significant (like I have read about in other forums). I tried to run again and still will not drain.
I think the pump may be broken? But I can't seem to easily get it out. So now I feel like my options are to hire the GE service person for $80 bucks plus a $100+ part? Am I missing something? Anything more I can do from home? Is there a way to test/tell if the pump is broken w/o taking it out?
Thanks!!
    Problem Solver:
  • 7 Answers
I found the solution to clean the lint filter on the GE Adora. Go to http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
I just did this and my washer is now running instead of the flashing start/pause and door unlocking. It was fairly easy. Make sure you have towels and a flat pan to catch the water if you don't have the machine on a riser. There may be water inside so a wet vac may be helpful too. Once my washer finishes what was in it, I have these funky towels to clean. You'll be very surprised what you find in the filter! Best of luck!
Posted on Oct 26, 2008
    Genius:
  • 1,028 Answers
Remove lower panel behind panel will be pump after removing as much water as possible in tub remove access port on pump and clean also ckd as far into pump as possible ..pump can be removed and taken apart if necessary ..if pump is clean may be issue with pump impeller they will sometimes break or come loose on motor shaft if impeller free wheels replace pump
  • vickie Davenport Sep 28, 2013
    how to tell if pump needs replaced. Cleaned out coin collector.
Does the pump make a funny sound when you have a clogged filter?
sometimes coins get stuck in the pump which causes noise when draining. Front of machine has to come off and pump taken apart and cleaned out.
Mar 02, 2015 | Frigidaire Affinity ATF7000E Front Load...
How to replace the drain boot on a maytag front load washer
I have taken many apart over the years, and I still refer to YouTube for advise.... Fixing a No-Drain Problem in a Front Load Washer http://youtu.be/b3kL3daLZ9g
Feb 24, 2015 | Maytag Neptune MAH5500B Front Load Washer
Amana front load washer how to clean water pump
remove the hoses and and remove the pump then use coat hanger to try to clean inside pump and try to turn propeller by hand depending on ur model some pumps cant be taken apart depending on either direct or belt driven ones
Aug 09, 2014 | Amana NFW7200TW 27-in. Washer Front...
Washer won't drain. How do I get to the pump
first chec in the pump ,, a coin may obturate..
Nov 05, 2012 | LG WM1814CW Front Load Washer
Won't drain. Motor wont come on.
Possible fault with the program controller unit. Now if there is no power to the drain then it can be due to the controller and if there is power with no drain then it can be due to faulty drain motor or the drain valve beingg choked or clogged;
click this link for tips: Drain valve cleaning
Jun 25, 2012 | LG WM-2277HW Front Load Washer
GE WSXH208V1WW
Usually when you have a washer that will not drain, first check if the drain hose is kinked or too high above the washer (8 ft is the limit of the washer pump). Next check if there is a blockage in your drain (often a stand pipe) or if the air can't get into the stand pipe. The final thing to check is for foreign objects in the pump to drain hose area that block the drain. (This requires getting into the pump and disconnecting the hose. Keep a bucket ready to catch the water that will pour out of the washer.)
GE has the manuals for many of their appliances on their support site: http://www.geappliances.com/service_and_support/literature/ . Enter the model number and click submit. The direct link to the manual for the WSXH208V1WW is http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-90256.pdf .
I hope this helps.
(at least my washer won't spin if the water can't pump out. On a few washers (non-high efficiency) the solenoid has failed to open for the pump to drain the water.)
Nov 22, 2011 | Washing Machines
Error: nd Water won't drain; Sounds possibly like motor on pump may not be working.
This washer uses an electric pump. Sometimes objects get into the pump. Take it apart and look for objects.
Jul 20, 2011 | Maytag MAH9700AWM Neptune Front Load...
Water won"t drain out. i have taken the front panel off what do i look for.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 24, 2010 | GE Washing Machines
Won't complete cycle
It sounds like your water pump is going bad or is bad.
Nov 08, 2008 | GE WCVH6260F Front Load Washer
GE WSXH208A Front Load Washer Logo
777 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
