Question about Car Audio & Video
Help i need to find out how to instal my sub in my truck.. i have a adiobom 420w. it has 2 positive and 2 neg. on each side of the sub. what do i need to hook up right. thanks mark
  • 1,586 Answers
That's a dual voice coil sub. You'll need a two-channel amp (which you probably have - if not, get one and make sure it has a low-pass crossover on it, which you want to turn on and set around 100 Hz). Each voice coil has a + and - connection. Use one channel to power each voicecoil. Make sure you pay attention to the polarities - wire the + of each amp's channels to the + of each voice coil's connections, so that the two coils fire in phase (in the same direction).
Posted on Oct 26, 2008
How to wire a 12inch 4ohm dvc sub to 2ohm
Take two wires, equal length. Reach from positive of 1 coil and hook too positive of 2nd coil, now do the same with negative, neg to neg.. Then pos of sub to amp. And neg of sub too amp.
Jan 03, 2013 | Rockford Fosgate T1d212 12" Power T1 2-ohm...
I have 2 audiobahn 12 inch 500 watt awc12t dvc woofers with 2 pos and 2 neg hook ups on each side of the speakers like this (- -) (+ +) and the same on opp side i need to know how to wire them to each...
OK. Sometimes manufacturers put two flat prongs to each of the positives and negatives of the voice coils. This allows for daisy chaining multiple subs to be easier. Here is how you want to wire your subs in the box.
From the positive post of the box to the positive posts of both voice coils (just choose one prong on each of them, you do not have to connect all 4 of them). So you will have 2 wires going from one post on the box to 2 posts on the sub. Got it. Not go from the negative post on the box, to both negative posts on the subs. Repeat this with the other sub. Now you can hook each channel of the amp to the box regularly pos of amp to pos of box and neg of amp to neg of box.
This set up is called parallel and will drop the ohms resistance of two 4 ohm voice coils to a 2 ohm load. You will get 2 ohms for each sub, thus connecting one sub to each channel. This will allow you to get the max power out of the amp or 150w RMS per your post. Hope this helps.
Aug 23, 2011 | AudioBahn AWC12 Car Subwoofer
Have 2 4+4ohm avi sl500 subs how do i wire it to this amp and what setings on this amp alpine mdr m1005 1000watt amp
using these subs will limit you to a 4 oh load to the amp witch will only let the amp produce half of it's power. the lowest ohm load that amp can handle is 2 ohm and the next lowest you can wire the subs is 1 ohm and that will over heat the amp and destroy it. so to answer your question first wire each sub like this diagram shows...
Wiring Option #1
then once both subs are wired this way you wire both positives from each sub to the positive side of the amps speakers terminals and wire each subs neg. to the amps neg speakers terminal. the wire is series parrelle and will present a 4 ohm load witch will be the safest to run with your amp.
Jan 19, 2010 | Alpine MRD-M1005 1000 Watt Mono Amplifier...
I own a mtx 1501d.Also own a 18
THE AMPLIFIER NEEDS A 1 OHM LOAD AND YOU HAVE THE RIGHT SPEAKER TO PROVIDE THIS LOAD. THE AMPLIFIERS TERMINAL STRIP PROVIDES YOU WITH 2 POSITIVES AND 2 NEGATIVES, BUT THEY ARE ONLY FOR CONVENIENCE WHEN WIRING 2 DRIVERS. ACTUALLY THE 2 POSITIVES ARE THE SAME CONNECTION INTERNALLY ON THE BOARD, AS WELL AS THE 2 NEGATIVES. THAT BEING SAID, THE SIMPLEST WAY TO CONNECT YOUR SPEAKER IS TO PARALLEL THE VOICECOILS IN THE BOX BY CONNECTING THE 2 POS. TOGETHER AND THE 2 NEG. TOGETHER THEN RUN THAT POS. AND NEG. OUT OF THE BOX AND SIMPLY CHOOSE EITHER OF THE 2 POS AND NEG. OF YOUR CHOICE AT THE AMP. IF YOU EVER HAVE TO ADD A SUB, THEN YOU WILL HAVE 2 MORE TERMINAL LEFT OVER ON THE AMP. TO CONNECT IT TO AT THAT TIME. BY ALL MEANS, IF YOU WOULD LIKE TO RUN EACH COIL SEPARATELY OUT OF THE BOX AND CONNECT THEM TO ALL 4 TERMINALS, THEN THIS IS FINE TOO, AS EITHER WAY, THERE WILL BE NO DIFFERENCE WHATSOEVER. LET ME KNOW IF I CAN BE OF FURTHER ASSISTANCE....V
Nov 24, 2009 | MTX Thunder 1501D Car Audio Amplifier
How do i bridge 2-4ohm dvc's to a mono block
If you have a DVC 4ohm speaker, and you are using both voice coils, the amp is seeing a 2ohm load.
If you bridge the amp, you CAN run both subs as long as the amp is Two Ohms Stable.
Wire each subs voice coils in parallel.(Positive to positve, neg to neg.) (2ohms) each.
Then wire the two subs in series.(Neg from amp to neg of sub one, pos of sub one to neg of sub two. then pos of sub two to pos of amp.
If it sounds too hard, leave it as you are already running the amp at two ohms.
Sep 13, 2009 | Car Audio & Video
Need wiring diagram for sub
u should have two pos, an two neg. on the back of the sub run a wire from one pos to the other same with neg. now just run a pos an neg from the box to one side of the sub u should have one side with two wires runing to the pos. an neg. if u need more help let me know bertman285@hotmail.com
Apr 25, 2009 | Car Audio & Video
2 4ohm dvc subs to a bxi 608 ( 600watt mono)
take the positive on the sub and run a wire to the other positive the run a negative to the other negative then to your pos and neg on the box do the same on the other side then tie your two positives and two neg together and you got 1ohm and that amp willl handle it all day
Jan 29, 2009 | Hifonics Brutus BXi 606 Car Audio...
I bought a 500/1 jl audio amp and also a w7 10 sub
if its cutting off and right back on then check your ground and your power wire makes sure both are connected good and none of your fuse's are blown, either that or you got a wire hooked up backwards in the sub.. but my guess is that the sub is hooked up wrong... that sub should be hooked up in a series or in parallel,
ok if your running just one speaker, it should be hooked up like this and 2 speakers are a different way...
this is parallel :pos to pos , neg to neg, then one wire coming from pos on sub to pos on amp then neg on sub to neg on amp but bridge the amp on your amp should be 2 pos and 2 neg in two different channels take the pos off the sub into the pos on 1 channel and then the neg from sub to the neg on the other channel,
this is series : on the sub it will go pos to neg then the other neg and pos will go to the amp, but make sure the pos and neg r on different sides of the sub, dont hook them both to the same coil
if your need more help give me your email and ill send you a pic of how to do it...
Aug 12, 2008 | Jl Audio 500/1 Car Audio Amplifier
My JL subs just dont beat like the ONES IVE HAD before as well as the ones my friends have had
sounds like they have your sub amp in mono but they put the speakers in series which totally cancels the benefit of running your amp in mono. you will probably be happier if you just hook the left speaker to left plus and minus and the right to right plus and minus. Cuz even though subs aren't directional they do pass some higher frequencies that are and that dilutes the stereo effect.
Jan 19, 2008 | Jl Audio 500/1 Car Audio Amplifier
Rockford Fosgate 800a2 To 2 SVC 2ohm subs
Ok.. Bridge the two sub into 4ohm than bridge to amp.
So. this how it goes.
sub1 + -
to      | |
sub2 - +
=      4ohm
           From Sub
                Two
amp (L) - + (R)- +
This will use the full potiental of RF 800a2 amp. I believe it like 1153 watts max out.
Sep 26, 2007 | Rockford Fosgate Punch 800a2 Car Audio...
Car Audio & Video Logo
88 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
