Have you checked the ink levels to ensure that they aren't low? You may need to replace the ink. It is also possible you have a paper jam, I'd check that as well.
Just remove the ink cartridge from the printer and clean the surface contact using a cotton moistened dipped in an alcohol . Return back the cartridge and try to print again.
Try also to Press and Hold the STOP/RESET button until printer restart. Release the button when to completely initialize the printer
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you.
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there. And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it. Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
6A00 means the purge assembly is stuck, on the right where the printhead rests when turned off. impossible to clean without disassembly. Best to replace #qm2-3032-000, about $19.95
Try removing all ink bins except black then you won't have any problems. You should also be able to go into your printer settings and select "Black and White" or "No Color" and it will print ok. Removing the ink trays is the easiest way though.
nem tudom feltenni a gépre mert nincs CD a dobozhoz
