Question about Exercise & Fitness
GINTELL treadmill stops by its own after 5 seconds it starts to work... what should i do
SOURCE: Treadmill stops running
I had simillar problem. I have proform 830 QT. My trademill stops after 10 minutes of work out. Everything shuts down and the circuit breaker pops out.
Root cause:- no lubrication under walking belt. Caused the moter to over work (over heat) and hence te circuit breaker popped out to prevent blowing of motor.
Solution:- Apply the lubricant under walking belt and adjust the belt tension if needed.
Back ground:- Contact proform customer service at 1-888-533-1333 (http://www.iconservice.com/proform/faq_tread.html) and buy the treadmil cleaning kit or lubricant kit which comes with a wand for easy application. It may cost you 35 dollars including shipping. If you need to fix your treadmil right away, use NAPA silicon spray 8300. Proform actually tells do not use it as it may damage your belt. However the specialst who came to fix my treadmill just sprayed it and collected 100 dollars. When I called proform they told me lubricating will fix it and its my mistake to not trust them. I guess they knew exactly what they were saying.
Posted on Jan 03, 2009
If you don't have the manual, see if the proform website has a PDF version available for download. They seem to have a lot of past models available. On our system (ProForm T10.0, PFTL0505.0) an E2 error meant the belt speed (according to the sensor) was too slow. The treadmill should come up to the selected speed within 7 seconds or this error is triggered.
Icon service turned out to be knowledgable and fair, although they can be hard to get ahold of on the phone. If you hold too long, then you are given a chance to enter your phone number. I had to contact them several times, and they did call me back each time I left my number.
Unfortunately several things can cause the belt not to run or not run well, so start with the easiest to fix items first like lubrication and tension adjustment (get a manual from the website if you don't have one--it covers this adjustment). Maybe clean the speed sensor wheel with compressed air or a q-tip (our model had a slotted wheel on the drive shaft which spins through an LED light detector).
If the speed is off, try calibrating the treadmill. Icon service can tell you how to do it (it's not in the manual).
Posted on Jan 12, 2009
bwinton
  • 83 Answers
SOURCE: error 1 message on older life fitness t3 treadmill
Error 1 - Start up error. This is caused because the belt was commanded to move and the opto (speed sensor on the motor) has not seen any movement or the belts movement was interrupted prior to it reaching its commanded speed. To fix Verify opto operation in Diagnostics, Motor Test
Mode, Section 2. Verify DC voltage at connector P6 pins 1 and 2. Verify that LED 4 on the Motor Controller flashes as the motor moves. Let me know if you need any more help. Fitness Fix-It
Posted on Mar 24, 2010
ercupa190
  • 12223 Answers
SOURCE: my treadmill start and about 5 seconds it shows L5 and stop
Lube inmediately the deck belt, the shut down is for to protect the electronic system.maybe you have deck worn.
2) Lube the rollers bearing very well
3) Test the input voltage motor, if there are the motor need repair.
4) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Posted on May 10, 2012
ercupa190
  • 12223 Answers
SOURCE: Precor 9.35 Error 5
please see the details and proceed according. God bless you
Posted on Dec 12, 2012
How do I calibrate a Trimline 4650.1 treadmill?
WARNING: DURING THE ENTIRE CALIBRATION PROCESS, STAND ON THE PLASTIC SIDE RAILS ONLY!
DO NOT STAND ON TREADMILL WALKING BELT!
CALIBRATION
1. Turn off treadmill.
2. Simultaneously press PROGRAM, ENTER, and START/STOP for about 3 seconds.
3. Maximum speed will be shown in the TIME/PACE display followed by an "E" for English units or an "N" for metric
units. Press START/STOP to change from English units to metric units.
4. Press ENTER.
5. Press START/STOP. Incline and speed will calibrate simultaneously.
6. When successfully completed, TIME/PACE display will show CAL PASS.
7. Press POWER. Your treadmill is ready for use
Jan 02, 2017 | Exercise & Fitness
I have a Kettler Olympic 7892-000 treadmill that has just stopped working.
If you wish to get some details about treadmill repair ; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Dec 31, 2016 | Kettler Exercise & Fitness
Why doesn't start button start it?
Hi I had the same problem, 1st I checked the fuse and eventually needed to replace the console mat....
Mar 22, 2016 | Proform ZT4 Treadmill with LCD Window...
Pro form 320x treadmill stops working when you get on it
How can I get my Proform 320X treadmill from stopping a ...
www.shopyourway.com > Manage My Life > Questions
How can I get my Proform 320X treadmill from stopping a few seconds after starting? ... -why-does-my-proform-treadmill-belt-only-move-a-few-seconds-stops
ProForm Treadmill 320x User's Guide ' ManualsOnline.com
fitness.manualsonline.com > ... > ProForm Treadmill
ProForm 320x Treadmill User Manual. Page 1. Page 2. Page 3. Page 4. Page 5. Page 6. Page 7. Page 8. Page 9. Page 10. Page 11. Page 12. Page 13.
Nov 03, 2015 | Exercise & Fitness
My Sole F63 will slow down a few seconds after I start it then I get a low speed displayed on my control panel
please LUBE the deck belt+ rollers bearings too. You must do it evey 150 miles apros. This happen because the lack of maintenance schedule.
God bless you
Jan 21, 2013 | Sole Fitness Sole F63 Treadmill
Precor 9.35 Error 5
Dec 12, 2012 | Precor 9.35 Premium Series Treadmill
My tunturi T 20 gets error code E 7. it starts up, and after 5 or 10 seconds, it stops and flashed the error code. I have tried the recommended solution, which is to unplug the treadmill, wait a minute to...
From time to time, error codes will pop up on your treadmill. It just takes a quick second to clear the error log and get the treadmill up and running again.
1.When the treadmill is not in use, press the "Stop," "ENTER" and "QUICK START" buttons in rapid succession. The "RESET" button can also be used, in place of the "Stop" button.
2.Press the "ENTER" button three times to access the treadmill's error log.
3.Press the up or down arrows to scroll through the error codes, if necessary for club or personal logging purposes.
4.To view the treadmill's odometer reading when a particular error code was elicited, press "SELECT" while a particular error code is displayed.
5.To clear the error log, press "QUICKSTART" for a minimum of four seconds while viewing the list. Prompts will appear on the display and let you know when the log has been deleted.
I hope you find it very helpful.
Sep 04, 2011 | Exercise & Fitness
Screen states Lube Belt , do not have user Manual , Where are lubrication points and what type "lube" can I use ?
hi,
It is necessary to lubricate your treadmill running deck every six months or 150 miles to maintain optimal performance. Once the treadmill reaches 150 miles, the console will display the message "LUBE" or "LUBE BELT". The treadmill will not operate while the message is showing. Hold Stop for 5 seconds to suspend message for 5 miles. Your treadmill came with a bottle of lubricant which can be used for two applications. If you need lubricant, contact Horizon Fitness. Only use lubricant provided by Horizon Fitness.
• Turn off the treadmill with the on/off switch, then unplug the power
cord at the wall outlet.
• Loosen both the rear roller bolts. (For best results, place two removable
marks on both sides of the frame and note roller position). Once the
belt is loosened, take the bottle of lubricant and apply it to the entire
top surface of the running deck. Tighten both rear roller bolts
(matching up the marks for proper position) to original position. After
you have applied lubricant, plug in the power cord, insert the safety
key, start the treadmill and walk on the belt for two minutes to spread
the lubricant.
• Lubricate the air shocks with Teflon based spray.
• Once lubrication is complete, reset the console by pressing and holding 'STOP' and Speed '+' buttons for 5 seconds.
ok
Dec 26, 2010 | Horizon T91 Treadmill
Reebok RX100 won't work right
Sounds like you could possibly have a bad drive motor or something is wedged into the walk belt somewhere keeping it from turning. Check this out. One more question. How long does the walk belt turn for, seconds, before it stops. Is it like 3 to 5 seconds or less than that.
Jun 29, 2009 | Reebok Rt1000 Treadmill Walking Belt
Error code comes up after 5 seconds
hai,
please check the speed sensor
Jun 09, 2009 | Cyclone Folding Treadmill
Exercise & Fitness Logo
239 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
