Question about Kenmore Sewing Machines
Thread is clumping underneath
The thread is getting stuck underneath and freezing the machine. There are big clumps of thread stuck to the underside of the fabric. The bobbin also wound too loosely. I opened the needle plate and blew it out with compressed air, but that didn't help. It began freezing after I sewed too close the edge of the fabric and the fabric got sucked down into the needle plate and 'froze'. I had to yank and pull on the fabric and jiggle then cut away what i could. There was a piece of fabric that got sucked down into the hinderlands I think. Then it sewed for a bit, I rewound the bobbin, it was loose, then began sewing again using stich 69 (honeycomb) and it froze with lots of thread again under the fabric. Help please.
  • Kenmore Master
  • 9,953 Answers
Unfortunately, the machine's timing may have been adversely affected during the jam and removal of the fabric. Here's something that may resolve the issue if it is not timing-related:
Install a brand new needle.
Remove all the thread from the machine.
ALWAYS RAISE the presser foot when threading the top thread!
Rethread from the beginning and verify the thread path is correct.
If you have a smoothly-wound bobbin, try that. (A bobbin that you describe will contribute to sewing issues.)
Install and thread the bobbin--confirm the bobbin is spinning the right direction in the bobbin case.
Re-test your machine.
If you are having issues with the bobbin not winding smoothly, there are standalone bobbin winders for about $30 on the market (local JoAnn's or on the internet) called Sidewinder. Confirm that your machine bobbins will work (there are a few machines that won't, I think Singer). This is a very good accessory to have since you can wind bobbins without having to unthread the machine and also saves wear & tear on your machine.
Amazon com Simplicity SideWinder Portable Bobbin Winder
Simplicity Sidewinder Portable Bobbin Winder
Posted on Mar 24, 2017
bargainbox
  • 1388 Answers
SOURCE: bobbin threading
You may have put the timing out, however, try this before you despair too much......
Ensure the presser foot is firm enough for the fabric you are using and that it will not just pull through easily by hand with the foot and feeddogs together (as the needle ascends), or things will not proceed, and you will be stitching in the same spot.
Generally a setting of 3 seems to work for general purposes, but if you are using very light or very heavy fabric, a sample is always a good idea before you start in earnest....also match the needle to the work for best results.
Ensure that all is clean and free of lint jams....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistant diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Feb 24, 2008
  • 45 Answers
SOURCE: Bernina 1008 sewing machine making
Hi: You have threaded the machine incorrectly. Rethread the machine with the presser foot up to the needle, pull the thread (loose) and drop the presser foot while pulling thread, thread should get tighter, then thread needle and machine will work fine. Make sure the top tension is set at where you normally have it, probably about #4 or #5
Posted on Jan 08, 2009
  • 22 Answers
SOURCE: thread keeps wrapping around bobbin
frustrating huh?  it happens!  even to us that have been sewing for 50+ years, but the solution is very simple.  Top thread tension is the culprit.  pull the spool all the way off and rethread the top, follow the threading path precisely and make sure the thread goes down into the tension discs.
one more thing - when that happens often times the piece has to be removed from the machine by cutting those annoying loops on the bottom.  if this is the case, make sure you have removed all the thread clippings from in and around the bobbin case.  sometimes one little piece of thread will make you want to use swear words.
good luck and happy stitching.
Posted on Jan 17, 2009
WonderTech
  • 268 Answers
SOURCE: every time i sew something the bottom thread keeps
Here are a couple of things to try.
Re-thread your machine. It may be threaded incorrectly.
Raise your feed dogs. If your machine has this feature.
When you start to sew a seam, hold on the upper and bobbin thread tails. Hold them back and out of the way as you sew your first couple of stitches. This will keep them from getting hung up.
I hope this helps you out.
Posted on Sep 19, 2009
WonderTech
  • 268 Answers
SOURCE: I am trying to sew and the thread keeps clumping
Try these solutions.
* Re-thread your machine as it may be threaded incorrectly.
* Raise your feed dogs If your machine has this feature.
* When you start to sew a seam, hold the upper and bobbin thread tails back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
I hope this helps.
Posted on Dec 30, 2009
How to fix bobbin thread on computered memorycraft 9000 sewing machine ?
1)Check that your bobbin does not have a nick in it where the thread can catch and won't feed smoothly.2) make sure the upper and bobbin threads are the same.3) pull out the bobbin case and chect to see if there is a clump of lint.4) make sure the feed dogs are moving the fabric through smoothly,some fabrics can get caught on the dogs and make the bottom thread get loopy.5) check your needle,if it's bent or has a bad tip,it can mess up the stitch.
Aug 15, 2014 | Janome Memory Craft 9000 Computerized...
Needle bar
clumping is caused by operator error and tension problems. First make sure you are grasping the threads when you start to sew. Then tighten the upper tension.
Aug 10, 2012 | Singer 3116 Simple
My new singer sewing machined gt jammed most of the time with the underneath thread all clumped.
try changing the needle
check to see if the top thread is coming off the thread take up lever
check to make sure the bobbin is turned the right way & inserted
into the needle case correctly
Aug 09, 2012 | Singer 4423 Sewing Machine
Singer Touch and Sew II Model 771 problems
rethread the machine top & bobbin
make sure the bobbin is inserted correctly into the bobbin case
make sure the bobbin is wound correctly
make sure the bobbin is not bent or damaged
May 10, 2012 | Sewing Machines
I have a Brother BC 2100 sewing machine. I have had this machine for approx 2 months. Recently, when I am sewing, usually when sewing slowly, stopping and restarting, the reel of thread jumps and loosens...
Ensure that the needle is installed correctly. If the needle moves down in the needle socket (only a little bit) it causes these clumps. Loosen the needle securing screw - push the needle up as far as it will go and tighten the screw again. Try again.
May 23, 2017 | Brother SE-270D Computerized Sewing...
Thread clumps and knots on the bottom of what I'm sewing. Sews smooth for a few seconds and more clumps. I've rethreaded and adjusted the tension....no help there.
It is because the thread is not going through the tension discs right. Rethread, then pull on the top thread with the presser foot up, it should feed smoothly, now lower the presser foot, the top thread should barely move. This usually seats the thread in the tension discs.
Nov 28, 2010 | Singer 3116 Simple
I am totally new to machine sewing and I have a Husqvarna Model 400, its been working perfect then suddenly when sewing the thread from underneath (the spool side) is just coming out in huge clumps, the...
When you say "the spool side" I assume you mean the bobbin. There are a couple of reasons why this could be happening. First re-thread your upper thread with the presser foot up and check to see if the top thread is firmly in the tension disc. Usually when you have looping of thread on the underside of your fabric, it is the upper thread that is out of whack. Just the opposite of what you would think! When you're sure the top thread is right check your bobbin to make sure that's wound tight and not "mushy." When you start by wrapping the thread around the bobbin by hand and then put it on the winder to fill it, it is not tight enough so the whole bobbin winds too loose. This can cause clumps underneath. The last thing to check is that the bobbin thread is caught in the tension slot in the bobbin case and that there is no stray threads in the bobbin case opening to cause trouble. Hope this helps. Good luck. You have a great machine!
Sep 10, 2010 | Husqvarna Sewing Machines
Bobbin thread comes out in a mass of threads
ENSURE you have threaded the bobbin properly and at the right tension. Also, ensure that you have routed the bobbin thread properly in the bobbin case.
Apr 02, 2010 | Brother CS6000i Computerized Sewing...
Bernina 1008 sewing machine making huge clumps of loops on underside of fabric. have tried moving screw on bobbin in two opposite directions without a sign of improvement.
Jan 08, 2009 | Bernina 1008
Sewing Machines Logo
27 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
