I need manual for hoover sensor dry 9+6 dynamic washer dryer
gittos73
  • 244 Answers
SOURCE: Hoover WDM120
this will be your carbon brushes which are situated at your motor in a plastic cover with a wire is attached if these are low then it will not spin must be at least 8ml long for it to work they start off about an 1inch in length
Posted on Aug 22, 2007
barkencoa
  • 3463 Answers
SOURCE: User manual needed for Hoover washer/dryer
Hi.
In you browser box type in Hoover user manual.
Then scroll down to Hoover after sales service instruction manuals.. Click on this, and then on Laundry.then on Waher -dryers, follow instructions
You will find your model listed there,.
Please leave good feedback.
Thanks
Posted on Nov 29, 2008
rylee_smith
  • 8619 Answers
SOURCE: Hoover Tumble Dryer trips out
Hi
Thanks for using FixYa. It seems to be the issue with the Thermal Fuse going bad and needs to be replaced. It is mounted to the exhaust duct inside the back cover panel. Whenever this fuse goes bad it'll either trip the circuit breaker or the dryer wont heat. You can also check it for continuity with an ohm meter, no continuity means the fuse is bad and you need to replace it. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 21, 2010
Testimonial: "Thanks for your quick response I will try and work out whch one it is and replace it"
blueextc3221
  • 15935 Answers
SOURCE: Water not heating & no heat when drying.
It appears your heater has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
SOURCE: I have a Hoover vhd sensor Dry Washer Dryer and
Hi I had the same problem about once a week and every time it happened I had to turn off the washer off and leave for a while and start new wash cycle. It worked for a while but eventually it started to throw E11 once I put it on (not the middle of cycle it used to do). I had to result to call the repair man. He checked all the hardware and nothing was wrong and re-install the program on the board and it stopped throwing errors. After 4 month of problem free period, it gave me E11 again today though..
Posted on Oct 03, 2010
I have electric current going into the hoover DYN 9144DG washing machine but no display
board inside these washer has internal safety devices fuses on there pcb
you need to let a tech look at this
sounds like the psu to the controller board has failed
and you need to either replace or repair the controller board
Oct 03, 2014 | Hoover Dynamic 9 DYN9144DG White 600 mm...
Lent removal hoover dynamic 9+6
I have H02 on my washer dryer, all i can do is turn it on and off, i wont do anything else, what can i do to get it to work?
May 05, 2012 | Washing Machines
User's Guide HOOVER HNWL 7146 Nextra 6 Washer Dryer
Hi if you give me your email address I will send you a nextra 6 user guide
Dec 01, 2011 | Washing Machines
My Hoover tumble dryer is not heating up - is there a cut out switch that needs to be re-set? - filter and hoses are clear
Typically there is a sensor that keeps the temp of the drying clothes at the proper range.
This sensor may be faulty.
Jan 08, 2011 | Hoover Dryers
I have a hoover hnwl 6136, and it's not drying properly. Presume I need to clean the filter but I cant find it?! Help?!
I have the same problem. Do you have a manual for this washing machine/dryer (HOOVER HNWL 6136)? I looked everywhere for a manual and I couldnt find one. If you can email it to lettings@fesamuels.com it will he much appreciated.
Oct 07, 2009 | Hoover Nextra HNWL 3166 Front Load Washer...
Hoover Washer/Dryer WM120 : Dryer function - drum not turning
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
treru
Jan 25, 2009 | Hoover H120M Front Load Washer / Dryer
Hi.
Thanks
Nov 29, 2008 | Hoover Washing Machines
Hoover washer dryer saver 1300
I have inherited a hoover saver 1300 in new flat, the dials have worn away and it goes onto drying mode after wash, how can i have it on wash and spin only - NO DRYING? Thanks
Apr 12, 2008 | Hoover H120M Front Load Washer / Dryer
Washing Machines Logo
532 people viewed this question
Top Washing Machines Experts
