Question about Xerox Phaser 7750DN Laser Printer
Xerox Phaser 7750, Error code 44
Error code 44
  • 2072 Answers
SOURCE: xerox Phaser 7750 code 35
Somehow you jarred the fuser. Turn the machine off and reseat the fuser. Open the left side door, there will be 2 thumb screws.
Remove and reseat the fuser, if that doesnt work you have to replace the fuser.
Posted on Apr 05, 2008
  • 2072 Answers
SOURCE: I keep getting Error code
That is the fuser fan. It is either running slow or stalled.
You have to remove the rear and top cover to access it. It is located on the upper right back side of the machine looking from the rear.
You can remove the fan, peel off the silver label then remove the small rubber cap in the middle. Behind that rubber cap is the fan bearing, It is dirty and needs to be cleaned.
You can flush it with alcohol then add a highly refined oil to that bearing, Replace the rubber cap and then clean the outside with alcohol, then put a small piece of tape over the rubber cap to keep it in place. Most of the time. I would say 75 % of the time that will fix the problem. If it doesn't fix it in the long term you wol have to replace the fan. Don't call Xerox directly, Go onto google and look up a business called " the parts drop". Call them and ask for Britt or Joe> I dont work for them, but have purchased parts from them for years. They are reliable, fairly priced and honest. Great people to do business with.
Posted on Sep 26, 2008
  • 2072 Answers
SOURCE: Grainy image quality on my Phaser 7750
Try something, Send a job with 5 pages to it.
Shut the machine off as a page it halfway out of the exit area.. Open the machine and look at the jammed copies. Are they clear in the imaging unit areas but not upon exiting the machine?
If the image is clear around the drums and imaging unit, then the problem would be in the fuser. If the image is grainy and fuzzy in the image area, You could have a bad second BTR roller, the soft black roller on the left side door. One of the developer housings could be bad. You have to remove the imaging units and look in the opening with a flashlight to see if the developer housing brush is thick on the developer roll.
Could have a bad transfer belt or one of the color housings could be bad.
Less likely is a bad laser. But have you taken the wand that is on the front cover and cleaned the laser exposure slots?
Posted on May 15, 2009
wrinaldo
  • 185 Answers
SOURCE: Error code 7-402
Tray 2 rollers near end of life. Buy a new set of rollers 600K78460, and then reset the counter in the diags.
Some 7750's can't be reset, in which case you need to buy an Engine Controller Board 116-1811-00
Whit :)
Posted on Jul 31, 2009
  • 110 Answers
SOURCE: hi i got xerox phaser 7750 and i have error code
Cheap fix : reset the Developer Life Count in the Service
Tools menu. Hold down the back ARROW key with the "i" them with your other hand turn on the machine.
Expensive fix : What has happen is that the developers have come to the end of the life and once it gets to a certain page count it will print out no more until you have replace the developers. One thing xerox forgot to do is reset the engine control board too for this machine. So you might need a new engine cotrol board too.
Procedure
1. Replace the Developer
2. After the Developer has been replaced, reset the Developer Life Count in the Service
Tools menu.
NOTE: It is recommended that all the Developers and Beads be replaced at one time rather
than on sccessive visits.
Good luck.
Posted on Oct 29, 2009
I have xerox phaser 7750 by mistake i bought 7760 yellow toner shall install it to 7750
Not yet, check with the supplier and ask if it is compatible with the 7750, if not then exchange the 7760 for a 7750 yellow toner cartridge. Once you open the cartridge the supplier will not exchange.
Apr 22, 2013 | Xerox Phaser 7750DN Laser Printer
Tip
XEROX PHASER 7750 7760 FAN ERROR.
Hey guys this is a Xerox Phaser 7750 and 7760 fan error video tutorial.
In this video you will learn how to fix the error code 48 on the Xerox phaser 7750.
Also you will learn how to fix the error codes 010-391,010-392,010-398 that are related to the Xerox Phaser 7760.
This video shows how to remove covers.
All the wires that you need to disconnect from the machine to fix these errors.
There is also another video part two that shows you how to reinstall everything back
in it’s place. Step by step tutorial hope you enjoy.
http://www.youtube.com/watch?v=yMud-Md2xpc
on Dec 30, 2009 | Office Equipment & Supplies
Error code 14 ; says cyan sensor malfunction. Where is sensor and how might I clean it?
E-mail me at rak458@aol.com.
I can't post all of it on here.
Just put Phaser 7750 in the subject line.
Jan 15, 2010 | Xerox Phaser 7750DN Laser Printer
Xerox Phaser 7750 error code 14 & 15.
try to hold down the on/reset button a few seconds when you power it up ...on most printers this resets them ..about 10 sec it is enough ...
Nov 26, 2009 | Office Equipment & Supplies
Hi i got xerox phaser 7750 and i have error code
Procedure
Tools menu.
Good luck.
Oct 29, 2009 | Xerox Phaser 7750DN Laser Printer
Error code 7-402
Error codes 7-401 to 7-404 are life end for the tray rollers. If no jamming probs then enter diags mode (Back and'i' buttons and switch on) scroll down to NVRAM access and select. find CRU counters and select, clear each tray counter and then exit.
Jun 01, 2009 | Xerox Phaser 7750DN Laser Printer
Tektronix Phaser 840 Model Z840 shows error 08 001 44 215264
Check for broken Maintenance Drawer Guides, or the Printhead Cap/Wipe/Purge assembly is defective. (If it is for a Phaser 840)
Dec 05, 2008 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 7750 code 35
Apr 05, 2008 | Xerox Phaser 7750DN Laser Printer
Phaser 860 error code 07.003.45:116163
It is a print head tilt error.
Most likely ink is in the stainless steel pivot block at the bottom of the print head.
Also the printer could have been unplugged and the cleaning blade is stuck to the print head.
Or a cable is binding the print head movement.
Nov 12, 2007 | Tektronix Phaser 860DP Thermal Printer
Xerox Phaser 7750DN Laser Printer Logo
32 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
