Question about Garden
Instuction manual for a tt-cs5800 chain saw
I cant find out where the spark plug is
SOURCE: I need a repair manual for a McCullough gas, 35 chain saw
Mc chain saw fuel lines rotted away need to know where they go
How the primer lines go! There are 2 outlets on carb. two tank lines two primer lines
Posted on Feb 04, 2009
  • 10865 Answers
SOURCE: spark plug gap
hi kathy. this is an easy one. first of all you will need a spark plug gapping tool, about a dollar at any auto parts store. Your chain saw most likely calls for PLUG TYPE: Champion CJ6 SPARK PLUG GAP: 0.025 in. (0.63 mm).
Here is the website of a short video to show you exactly how to gap the spark plug. write back if you need any more info.
www.expertvillage.com/video/6078_spark-plugs-gap.htm
Posted on Feb 07, 2009
steve_lima
  • 181 Answers
SOURCE: weak spark on 55 rancher chain saw/ airgap on magneto
the air gap is .010 to .012 inches,hope this helps, if not contact me and i'll help you with anything i can
Posted on Mar 12, 2009
SOURCE: Chain Saw, Stihl Model 011, cutting off
I've been messin with my poulan 2150 that was doing the same thing. Good, fresh gas, good spark,etc. I noticed whenever I loosened the fuel cap it would literally spray gas out! alas, I removed the muiffler assy and the darn thing fired up the first pull! I've got the muffler parts soaking in gas right now and I'm sure this the problem. It just makes sense especially if you use the same 'mixed fuel' can for weed eater, blower,etc. Check your's out, it could very well be your problem too! GOOD LUCK
Posted on Apr 29, 2009
  • 109 Answers
SOURCE: how to check the spark plug is ok on a McCULLOCH
Chain saws are still two-cycle engines (gas and oil mix) and they foul the spark plug pretty rapidly if not in perfect tune. Remove the spark plug and re-attach the wire and let the plug contact any metal part such as the cylinder head. Make sure the gas petcock is off and the start switch is on. Pull on the recoil starter and see if you have a spark jumping from the center electrode of the plug to the outer electrode of the plug. Clean and re-gap the plug and try it again. If no spark, the center electrode could be broken up inside the ceramic insulator and you can't see it. Try a new plug. If still no spark, another component of the simple electrical system could be bad. If your saw has a capacitor, change that out also. Sometimes the small coil that rides very close to the magnets on the flywheel comes out of adjustment. Proper gap for that is a small piece cut from a cereal box and placed between the coil and flywheel while re-tightening the coil bolts. Do not let the coil scrape on the flywheel. If any of this has helped, please rate accordingly. Good luck.
Posted on Jul 06, 2009
Spark plug Gap, Stihl o26, chain saw
These things may be found on Stihl's website. Accordingly it says the spark plug gap should be 0.020". You may also download or request a hard copy of a manual for your saw at the same site.
Oct 08, 2014 | Garden
Echo chain saw has no spark how to fix
Not being facetious here... change the spark plug as a first step. They require regular replacement. If that doesn't work, use a multimeter to check that the spark plug wire is actually releasing electrical pulses. If it isn't, you'll need to keep moving further up the line to the coil.
Sep 01, 2014 | Echo Chain Saw Service Repair Manual...
Craftsman chain saw repair manual
Its not hard! You need to purchase a tool that goes into your spark plug hole. You remove the spark plug, put this tool in the hole. This tool stops the piston from moving so you can remove the nut holding the clutch. The clutch is what the drive sprocket is attached to. The drive sprocket is where the chain fits on at the engine side. remive the bar and chain and you will see the clutch. Use the tool and then use a wrench that fits the nut on the clutch. be sure you know which way removes the nut. It could be opposite of what you think. some are left hand threads some are not. I think these are not. After you replace the clutch be sure to lube the clutch bearings. Most people don't know this! use a grease gun made for saws and insert it into the hole at the end of the shaft that holds the clutch. Also next time your saw cant saw through a piece of wood, do not give it gas to make the chain try and move.This is what burns up the clutch! If your saw stalls out, and you press the throttle and it still doesn't turn. Always allow the chain to move, pull back and lift up on the saw slightly to get the chain moving again.
Jul 09, 2012 | Garden
Respected Sir, I purchase a Husqvarna's chainsaw last week Model 236- 14". but I cant start it. I read manual carefully, every thing is OK. but Chainsaw can't start yet. So I request you,...
Checklist:
2-cycle oil mixed with FRESH gasoline
Spark plug wire pushed onto spark plug
Chain tight but you can still move it forward with your hand
Switch turned on
Pull the cord a few times, and then let it sit for a few minutes in case it's 'flooded' with fuel
If a new chain saw won't start, it probably has defective spark coil
Chain saws usually don't cause problems fresh out of the box, they stop working if people leave gasoline in the tank for a couple months each time.
Here's what I would do
Empty the tank of gas. Put fresh gas-n-oil into tank (not gas from an old can that was sitting there for a while)
Try starting again.
If no luck, then take it back and exchange for another.
Good luck sir.
Oct 15, 2010 | Husqvarna Garden
Describe your Husqvarna "Chain Saw -
Remove the spark plug and test for spark. If ok, try some starting fluid in the plug hole, install the plug, and try to start. If it runs a short time, it is not getting fuel. Check fuel lines including inside the tank. Clean or replace the air filter. If this saw is fairly old, the carburetor probably needs a re-kit and cleaning. Does it have good compression? Check the muffler for plugging. Make sure the fuel/oil mix is fresh. Good luck!
Sep 12, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Poulan saw wont start has spark and fuel
Look for a pinched/bare stop-switch wire (I assume that you don't have spark now). Also, check the ignition coil core gap to the flywheel magnets (I use card stock to set the gap). Make sure the plug wire was not damaged again.
Aug 25, 2009 | Poulan Pro Chain Saw 46cc 20"
Spark plug gap
Feb 07, 2009 | Homelite ZR10926 16 Chain Saw
Change Spark Plug on Eager ****** Chain Saw
yea you have to take it apart sorry
Oct 06, 2008 | Garden
Garden Logo
659 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
