No picture on tv
When I turn on the tv everything works except picture. When I fool around with power button, unplug and plug back in jiggle and wiggle things the picture comes on. When there is no picture the lamp is on in the back of the cabinet. When I do get the picture I leave the set on for long periods of time and everything is fine. Help.
  • prop_r Oct 25, 2008
    samsung #HL-S6187W
  • 19,396 Answers
Sounds like a faulty power board, that suffer from electrostatic charges, probably some of the capacitors in the power board is defective, the board should be replaced.
Posted on Oct 25, 2008
  • 6,487 Answers
Can you please provide us the brand and model for this unit so we can help you better...
Last night about 3 am I turned off my tv. when I usewd my remote to turn it back on it would not ( t v) come on and no picture or sound . I turned it around to see the back of it but it has no reset
Your TV have faults on Horizontal deflections, the oscillator and the Flyback might be the problems. If you are not familiar with TV circuits?... call tecnician to check your set.
Oct 03, 2014 | Televison & Video
No picture on Vizio 60" E601i-A3
yes take it back 6 weeks i would return it
Dec 30, 2012 | Vizio 60" E601I-A3 Full HD LED-LCD TV
All buttons control tv/video, remote stopped working
Unplugged it for an hour.... buttons changed.....Unplugged it for four hours and everything worked......Left it plugged in overnight and back to original problem....
Oct 02, 2009 | Toshiba 32A33 32" TV
Panasonic remote and volume/channel buttons do not work
My son put a penny in the SD card slot of my Pansonic flat screen tv. I finally got the penny out but now the volume and tv controls do not work. I can change the channels through my cable box but that is it. The volume does not work on my cable remote or the flatscreen. What do you suggest I do to fix this problem?? Thanks, Josh
Jun 06, 2009 | Panasonic TH-42PX60U Television
My XBOX 360 has a Sound but no picture issue.
Well the main solution that you're going to get from Microsoft is to unplug everything from your console and your TV and then wait a couple minutes and plug it back in while everything is off. If the problem still persists, instead of buying a new 360, try borrowing a friend's AV cable and see if that works. Try not to unplug or replug anything while the console or TV is still on. Or it could just possibly be all of the jostling around in your suitcase and nothing has come loose enough to stop working until now. Sorry I can't be more helpful, these are just some ideas.
Jan 09, 2009 | Microsoft Xbox 360 Console
Have sound, no picture
After fooling around with all of the buttons, and disconnecting the power to the TV, it occured to me that it may be the Comcast digital cable box. I unplugged the cable box for a few minutes, plugged it back in and the TV works just fine!
Jul 22, 2008 | Panasonic PT-50LC13 50" Rear Projection...
TV won't turn on
When I try to turn the tv on, the green light flashes and eventually goes back to red. A very faint picture came across the tv a few times but didn't stay. The tv is only 3.5 years old.
Jul 10, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Panasonic th-50pz85u problem
My problem turned out to be silly but simple. I recently took my TV off the wall and mounted it on a stand alone platform. I snaked the power plug through the back tube and left too much tension at the entry point for power. If you leave the slightest tension the female connector will jiggle and it will shut off. It normally takes 3 minutes before you can retry and then the problem persists. Try allowing more slack and/or buying a new power connector to make sure the plug connects correctly. Good Luck!
Jun 24, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
NO PICTURE
there is a broken conductor strip or broken solder joint on the circuit board near the power input jack. do this: 1.) disconnect tv and open panel to expose circuit board. 2.) using a flashlight and magnifying glass, look carefully for this broken solder strip or solder joint. Flex board slightly if necessary to aid in finding the break. 3.) repair it using solder iron and flux solder and scratch copper conductor slightly to aid in "wetting" the solder fix.
Jun 09, 2007 | Daewoo DTQ-26S1FC 25" TV
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
