Question about Xerox Office Equipment & Supplies
Error code 11-902
The machine is saying output tray 1 is out of service, i have checked the finisher and all is clear, this is a brand new machine please help.
4 Suggested Answers
CompuGuy44
  • 432 Answers
SOURCE: HP COLOR LASREJET 3500 41.3 ERROR
Check your settings under the properties menu. and in the software your using.
Posted on Jun 26, 2007
SOURCE: Canon Pixma IP600D - error code 6502
Sometimes the Canon printers which use PG-5BK/CL-8 colour cartridges with chips will give error massages like 6502 or other types of error message to do with the cartridges, which has the orange light flashing and the printer will not work. Follow this procedure which quite often resets the printer and allows it to resume printing.
When error is indicated, turn power switch off so green light is extinguished.
First hold down resume button and then hold down power button so both are held down at same time
When green light comes on, continue holding down power button and let resume button go, then press resume button twice. Then let power button go.
Then press resume button four times, power button should be released before doing this.
Wait until printer settles down, if power is off, turn on. If power will not come on, remove power cord from back of printer, then wait 15 seconds before plugging back in again and turn power on. This normally solves the error problem - if not go through same procedure again.
Incidentally, you may find that if the chips had previously been disabled, the low ink warnings are showing again and they will have to be disabled once more. This would indicate that the above procedure clears the firmware memory of the disabling of the chips, this may be useful if you need some warranty work done on your
printer after the chips had been disabled.
Posted on Jun 10, 2009
SOURCE: MX338 output tray problem,
please help me...how to reset the following ink cartridge cannot be recognized U051 canon mx338
Posted on Apr 14, 2010
I am getting an area R jam followed by SC726-00 service code. The paper is cleared but the machine won't run with the service code notification. Turning off and on again recycles through the R jam and...
SC726: Finisher Shift/Lift Motor Error
Definition [B']
1) Tray shift does not finish within a certain time after the shift motor turned on.
2) The stack height sensor does not activate within a certain time after the shift
tray lift motor turned on.
Possible Causes
• Shift motor defective
• Shift tray lift motor defective
This is a problem with the finisher shift motor normally.
Feb 21, 2011 | Ricoh Aficio 450 Copier
A paper jam was not cleared in a timely manner, now the machine will only display "Error Code C0202, Call Technician" It is Saturday and I can not get a hold of anyone at our support center. How can I...
C0202= tray 1 elevator failure.
Open tray 1, check and make sure paper is loaded correctly.
With tray open, open and close front door. This will reset error code. With tray 1 open look to see if paper is stuck behind tray in back of machine, if so remove it ( this will block the lift motor for the tray).
Close tray 1, if you hear a popping noise the lift motor is damaged and will have to be replaced. Until it is replaced operate machine with tray 1 out to prevent error code.
Sep 18, 2010 | Konica Minolta Bizhub 362 Copier
My brand new machine Bizhub 211 have paper jam problem
COF32 means the ATDC sensor has detected some unusually high or low readings.
The ATDC sensor measure the toner lever inside the developer unit.
Try swithcing on/off, open/close the front door to clear the code.
If this doesn't work, you'll need an engineer to reset the ATDC level.
Good luck
Tam
Apr 12, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
Ricoh Aficio 1045 error message SC726
Hi
Thanks for using FixYa. Error Code SC726 means the Finisher shift tray 1 lift motor error. You need to enter service mode and reset the unit by following the instructions given below.
To enter service mode (SP): Press the clear mode key then enter 1-0-7 hold down the c/s for three seconds. To enter the special service mode you’ll need to hold the # key down while pressing Copy SP. Exit service mode: by pressing exit twice. It will reset the and cycling the power.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 24, 2009 | Ricoh Aficio 1035 Copier
KONICA MINOLTA BIZHUB C350 WITH ERROR CODE C0960
Check your bypass tray, the tray is on the right side of the machine, the tray flips out for legal and 11x17 paper sizes. Check that there is nothing jamed inside, code says that the tray can't lift. so check for anything jamed inside down there. As to reset the code open then close the front door where you put the toner. Turning the machine on and off will not reset the code. but open and closing the front door will clear about 80% of the service codes.
Apr 02, 2009 | Konica Minolta Office Equipment & Supplies
Can not get the output tray to use the finishing tray.
Do you mean you have internal finisher? Try to make any copy with staple it should comes out from there, if not you have to go to machine setting or copy setting , you do this by pressing menu buttom, and change the output paper to the internal finisher.
Let me know wat happen after.
Mar 24, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
Sharp AR-5127, the error code U2-40
U2-40 is a board error, F1-15 is finisher lift motor error.
To reset: #, interrupt, clear, interrupt. (screen should say service mode), enter 16, print, are you sure? , yes.
For the finisher error, follow above procudure, entering 14 instead of 16. if error returns, disconnect the finisher
Nov 26, 2008 | Office Equipment & Supplies
Konica Minolta Bizhub c-353 has an error code c-1183 which will not clear for me It's Saturday and I have a HUGE project with lots of people coming to help.
The finisher output trays hit something like a trash can or boxes stored under the trays. to fix must remove the rear of the finisher reset the elevation drive assy. Be careful don't let the trays fall down tech would be good on this project
Nov 01, 2008 | Minolta Office Equipment & Supplies
Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Jun 07, 2008 | Minolta bizhub 200 All-In-One Printer
Canon iR8500 with Error E000583-0001
Hello Jeremy,
This error code has to do with your finisher. The auxillary tray is not finding its home position or does not leave the home position within the alotted time. Check for binds. I have limited exposure to the K4/3 finisher but try this. Turn the copier off, and open one of the finisher doors. Now turn the copier back on with the finisher door open so it cannot initialize. Once the copier is basically ready except the finisher door is open, close the finisher door and observe all the **** (and theres alot) initialize. This may help determine the problem. I hope this helps...........................SPINAL
Mar 12, 2008 | Canon imageRUNNER 8500 Copier
604 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
