Question about JVC HR-S9500 S-VHS VCR
Jvc HR-S9700 -TAPE JAMS, THEN SWITCHES OFF,CASSETE DOOR REMAINS OPEN,DOES NOT ACCEPT OR PLAY
Dear All, The tape suddenly jamms, the jvc hr-s9700 switches off, once I even could not eject it at all, had to open the cover and take it out.The cassette door remains open, cassette can not be inserted or played again. Happens for third time, the repair man ( in faraway different town, can't go anymore...have to repair it myself) said it is some sort of switch, which controls the tape mechanics, is the problem and needs replacement or cleaning. He did it last time, and after couple of hours play it stoped again.Managed to pull the tape out, the tape was not fully inside the cassette, door remains open. Opened the lid, can not find/do not know how the swich looks like to replace it or clean it. Also, where to get/download for free service manuals for jvc hr-s9700 ? Please, help !!! Thank you very much for your detailed answer and help !!!
  • 68 Answers
The switch is on the electronic board under the tape compartment. you have to unscrew the screws and unplug all the wires to take it out. be careful though, you have to put it back the way it was otherwise you will mess up the machanisim on that machine. good luck
Posted on Apr 06, 2007
SOURCE:
JVC HR-VP628U VCR does not load the tape into the machine. If I manually push it down it loads the tape onto the play head and plays etc. pressing Eject does not eject. replaced all belts already.
There seems to be some damage to the cassette holder. It could also be something connected to the mode switch, being faulty or in the wrong position. Pressing down on the tape would not have helped it either!
Jun 05, 2018 | JVC Televison & Video
Why does the jvc hr-s3800u shut off after about 8 seconds of tape play
It could be a tape end sensor problem, take up reel is not working, or a idler assembly issue.
Mar 20, 2012 | JVC HR-S3600 VCR
Tape loading mechanism jammed
Hi...Tape jam inside your Camcorder ...fi you look careful on the side of the door tray look for a little hole it release manually the door but carefully remove the tape.. it possible the tape is unroll around the mecanism see if you cant release the pinch roller inside it a little black roiling rubber,it holding the ribbon tape
Oct 18, 2010 | Sony HVR-Z1 Mini DV Digital Camcorder
JVC S-VHS VCR 2002 model
TRY A HEAD CLEANER,,AND BLOW IT OUT
May 14, 2009 | JVC HR-S9800 S-VHS VCR
JVC HR S5700AM S-VHS video recorder - won't accept tapes
Hey Lindsay
Yes the ejector is probably damaged inside maybe a bent arm or something mine is like that 2 and I didnt even bother fixing it I will be finding one very soon and I suggest you should 2 so just throw out the old and come in the new with your new vcr or dvd vcr combo..
Jul 23, 2008 | Televison & Video
Hrs9500 stop after 6 sec
Also have te same problem with a S9700.
Switches to stand by after 6 seconds again and again.
Please help!!!
Oct 29, 2007 | JVC HR-S9500 S-VHS VCR
Casset cover door will not open when pressed
You probably have one of two problems. Either the tape has been eaten by wrapping it around the capstan or else the head has not retracted to let the door open. If the tape will still play, then it is not the first problem. If the tape will not play, then it could be either problem. If it is the latter problem (head not retracted) then you may have a bad belt (broken or slipping). The tape wrapped around the capstan problem may be caused by a belt or tire being bad but a different belt or tire than the head not retracting problem. This may seem confusing to you but that is just the nature of the thing. In short, I'd bet you have a bad belt or tire that needs replacing. I hope this helps. Good luck.
Jan 24, 2007 | Aiwa Z-L520 Shelf System
JVC HR-S9700 TAPE STUCKS, HAVE TO BE PULLED OUT, CASSETTE DOOR REMAIND OPEN,VCR SWITCHES OFF-CAN NOT BE PLAYED AGAIN
Check out the drive that works the unloading and loading operation of your machine. Also check the switch that is activated by the presence of your cassette. If something is wrong with the latter, the tape will not load and unload properly. And under those circumstances your machine will not work.
Try Google search for your questions. You may get lucky and get the answers right there!
Mar 13, 2017 | JVC HR-S9600 S-VHS VCR
JVC HR-S9500 S-VHS VCR Logo
474 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
