Question about Canon imageRUNNER C6800 Copier
Canon ir 6800 error codes E00061-0003 - Canon imageRUNNER C6800 Copier
KyoDoc
  • 38 Answers
SOURCE: Canon imagerunner 2200 error code E000602-0003
This is hard drive failure. If you another code other than 003 you may have gotten away with a scan disk, but not always. in your case the hard drive has died. a Canon Technician will need to replace it and re-install the machine's system software
Posted on May 08, 2008
spinal
  • 287 Answers
SOURCE: CANON IR C6800
Hello Jc.Let me start by saying that despite the fact that you have properly been specific with the error code you have submitted, Canon is "fairly" specific in regards to the amount on detail in provides. I say fairly in really loose terms. The error 602 means that for any number of reasons when the copier went to boot" (begin to start up and read its directions as to what it is, who it is, and what it is capable of, it failed to get the instruction set (or failed to recognize the instructions) and therefore said "what"?!) as the copier sought to retrieve this info from the hard drive.That can mean that the partition of the hard drive that is was looking at contained corrupt information, or there was a communication interruption, or that the hard drive is going or gone bad. I know this sounds like a bunch of technical goblidy gook but you don't want to know what the 0101 means after the 602. It may not be too bad but brace yourself for the worst. That is that the hard drive may have went wheels up, or at a minimum all stored custom information is gone. The latter may be the best you can hope for. I am afraid that a "hail Mary" might be to power the copier of by way of the rear switch (or unplug if you are not familliar) and wait a few minutes.Restart and hope for he best. Otherwise you WILL need a technician to replace the hard drive and then they will have to reload the system software. I was reluctant to respond to your request for help as I cannot "fixya" and I will get a bad grade from the guys that run this site since I left ya hangin. But I could not resist trying to help you and to at least make sure you did not get raped by some "hungry for money" company. Please at least give a decent rating and I will keep my fingers crossed for you..................SPINAL
Posted on Jan 25, 2008
SOURCE: Canon IR 8500 Error code E000069-0000
You have a high-voltage leak to the transfer corona. This could be due to several different things, usually it's a dirty corona, maybe excessive dust or toner in the corona assembly. Toner conducts electricity and can leak voltage from the transfer corona to the frame. It may also be the "end-blocks," the thing in the back of the machine into which the transfer corona plugs when you close the drawer and lift up on the green handle. These crack and can cause intermittant failure.
I would start by taking a can of air and thoroughly blowing out the corona assembly and see what that does for you...
Posted on Aug 05, 2008
  • 168 Answers
SOURCE: canon clc 1180 error code 073-0003
this is an error for the transfer unit or its cleaning section not in proper place slide out the unit as far as it will go.. look inside to the lower left rear frame. there are 2 halfmoon gears sticking out reach in and turn both of those clockwise till they stop . slide unit back in close doors see if it resets good luck
Posted on Dec 29, 2008
SOURCE: vinod canon ir6000 error e00061-00001 i cant
hai,one ir6000machine in oneand most problem eo61-01 please solution in this problem thnk you.
Posted on Jan 13, 2010
How do i get the factory default setting for canon ir 6800?
Go to service and and clear the error
Asterisk * press
then press 2 & 8(Two buttons single time)
Again press Asterisk *
COPIER>FUNCTION>CLEAR>ERR
Then press ok an off the machine wait 1 minute and on the machine..
Jun 23, 2016 | Canon Office Equipment & Supplies
First i changed the fuse gear canon ir 6800 and put the fuse unit back to machine . when i turn it on the machine show the error 000005-000010 what can i do ?
hi . that error indicate that the cleaner roll ( in the fixing unit )is over . maybe there is a sensor disconnected or misplaced. check That section and clear error from service mode
copier / function / clear / err ok.
Feb 27, 2016 | Canon Office Equipment & Supplies
Error 100 ir canon 6800
This is a laser scanner beam detection error.
It will need a service technician to fix it.
Dec 03, 2009 | Canon imageRUNNER C6800 Copier
ERROR E000078-0001 PARA CANON IR C 6800
the HP sensor does not turn on within 5 sec after the of a HP search turn off then on the main power
May 31, 2009 | Canon imageRUNNER C6800 Copier
Error code E000070 0001
this is a error code for the transferf sheet either it is ripped or not turning anymore
Feb 02, 2009 | Office Equipment & Supplies
Canon pixma mp600
If its still under warranty send it back.
Solutions for error code 6800 Issue: Error code 6800 appears on the display (multifunction printers MFP)
1. Contact Canon for 6800 error - MP600 2. The MP600 may require repair
Oct 28, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Canon imageRUNNER C6800 Copier Logo
187 people viewed this question
old marine
old marine
