Question about Onkyo SKS-HT520 System
SkW-520 SUBWOOFER stoped working
For a few days subwoofer resonated as if the volume was to the max and now it is dead. I follwed the usual troubleshooting routine from the user manual, but the problem appears to be internal. I will appreciate any ideas of tips in order to identify the damaged component. Thanks,
2 Suggested Answers
SOURCE: onkyo skw 150 powered subwoofer output code
whatisthe codewriten behindtheoutput of the onkyo subwoofer skw 150my ou6666088.jpgt put is bad in sucha way that ican not retrieve the the code
Posted on Feb 12, 2010
How do you connect the skw 360 subwoofer to the onkyo tx-sr505 av receiver
Hi Kenny, sorry you can't. The TX=SR505 requires a powered subwoofer. The SKW-360 is passive. Thank you, Onkyo USA
Dec 02, 2016 | Onkyo Audio Players & Recorders
SKW 540. green power light turns on but why no sound?
Hello Johnny, As a test to see if the subwoofer is working I would have you run one simple test. Unplug the subwoofer from the receiver and apply your finger to the end of the cable. If the subwoofer is working then you will hear feedback through the receiver as you put your finger on it. If there is no feedback this is usually a good indication that the subwoofer is no longer working. Thanks, FJD
Feb 29, 2016 | Onkyo Audio Players & Recorders
What is the buzzing in my subwoofer?
It has being a long, long time since I've work with a subwoofer.
Check to see if it's making ground inside the subwoofer. Not sure if this will fix it, but it works in mine.
Dec 19, 2015 | Audio Players & Recorders
I have 2 onkyo home theater systems, one is an older ht-r8230 with an skw-8230 powered subwoofer & the other system is a ht-r420 with s powered skw-420 sub. all i did was change the rooms the 2 systems...
It's possible that you have accidentally switched off the sub-woofer outputs on the receivers. Onkyo have a speaker set up test. You should run that and see if the speakers are on and that a signal is getting through to them.
May 28, 2017 | Onkyo SKW-110 Subwoofer
Subwoofer stops working at times and will not work.have had it about 4 or 5 days just started doing it today
many pple have the same problem.... that subwoofer stops working sometimes when playing music or something else... I also faced the same problem .... I did the following things..
open your subwoofer. checked all connections for any loose contacts... and then check the wire of the main speaker.....
IF YOU FIND DIFFICULTIES IN OPENING OR IF YOU DONT KNOW MORE ABOUT THE INTERNAL PARTS OF SUBWOOFERS.. THEN DONT TRY TO OPEN IT.. YOU MAY CAUSE DAMAGE TO IT...IN THIS CASE :
GIVE YOUR SUBWOOFERS TO THE SERVICE CENTRE FOR REPAIRING...
Dec 15, 2010 | Onkyo SKW-200 Subwoofer
How do i connect my boston acoustics pv800 subwoofer to my Harmon Kardon AVR 520 reciever?
You need to use the LINE LEVEL connection on the pv800 (usually a rca type connector cable) and run this cable into the back of the HK 520 Subwoofer PRE-OUT connector, be sure the HK Receiver menu speaker set-up option is set to SUBWOOFER "YES"
Jun 06, 2010 | Boston Acoustics PV800 Subwoofer
Onkyo skw 150 powered subwoofer output code
Feb 12, 2010 | Onkyo SKW-200 Subwoofer
What are specs for a ported subwoofer enclosure for a 12" pioneer champ series
TS-W307D2
Design and Specifications
12” Dual Voice Coil (DVC) Subwoofer for Enclosure applications 1,200 Watts Max. Power Handling 400 Watts Nominal Rating Qts = 0.44 Xmax = 8.7mm Fs = 33.9 Hz Vas = 42.2 litres Frequency Response : 18 ~ 500 Hz. Efficiency : 89 dB Impedance : 2 x 2 Ohm (Total 1 or 4 Ohms) Delivered with “jumper link”: ready for 4 Ohm use f0 (Lowest Resonant Frequency) : 33.9 Hz. Recommended Sealed Enclosure : 24 ~ 49.6 Litres RECOMMENDED sealed enclosure, not Ported. 24 Litres = 1464.569 cu. inches 49.6 Litres = 3026.777 cu. inches
Nov 23, 2009 | Pioneer TS-W307D2 12" 1200 Watt Champion...
Onkyo subwoofer not working
I fixed my subwoofer. The resistor at R16 (right next to the fuse) was the fried component. I removed it and replaced it with a 13K ohm 5 watt metal oxide resistor (from Mouser Electronics if not available locally). Works fine now. I got the solution and the circuit schematic from an audio hobbiest at diyAudio.com. This is, evidently, a fairly common problem.
Sep 17, 2007 | Onkyo HT-S780 System
Onkyo SKS-HT520 System Logo
356 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
