Question about Plumbing
Placing a TFM-18 water filter membrane into the casing
I have a 5- stage Reverse Osmosis system and am concerned about the large filter, which is the membrane. I have the membrane to place into the casing but am not sure which end goes in first. Can you help me with this issue?
Thanks,
Rich A.
    Problem Solver:
  • 5 Answers
The end with the two small black "O" rings will slide in first.
Posted on Dec 04, 2008
Microorganism class 8 question answer
No. The filters sold for faucet application are not certified to remove microorganisms removal from raw water to make it safe to drink. Even a reverse osmosis (RO) membrane isn't certified for microorganism removal to protect health. Although the RO membrane pore size is small enough to filter out parasites, cysts, bacteria, and viruses, there is always a potential for a breach in the membrane. To remove microorganisms from a raw water source you need to add an NSF/ANSI Standard 55 Class-A certified ultraviolet disinfection system.
Apr 10, 2014 | Camping, Backpacking & Hiking
Always regenerates
I believe the ratio is 5-1, so when you use 1 cup it uses 5 cups to replace that cup. The reject water will slowly run down the drain, the extra four cups.
Mar 11, 2014 | General Electric Profile Smartwater Ultra...
How do I fix pressure on ge ro system
Use this chart to pinpoint your issue and a possible fix. Most replacement parts if necessary can be found at https://www.freshwatersystems.com/c-67-parts-accessories.aspx.
Aug 09, 2013 | GE RO Compatilbe PNRV18 Compatible Reverse...
Ro filters going bad in 60 days
IF THE RO OR ANY T33 FILTER HAS BEEN INSTALLED HORIZONTALLY, TRY TO INSTALL IT VERTICALLY WHERE THE OUTPUT IS ON TOP. GOD BLESS.
Jan 29, 2012 | General Electric Profile Smartwater Ultra...
How do you know if you need to replace the RO membrane filter in the culligan good water machine
A TDS (total dissolved solids)meter is needed to test the Reverse Osmosis water and compare it to the feed water to determine how much TDS is being removed. Reverse osmosis membranes are designed to remove 80-95% of the TDS in your water supply.
For example: If your water has 500ppm of TDS the minimum TDS removal should be 400ppm leaving 100ppm. If the TDS from the Reverse Osmosis System drops to these levels it is time to change the Membrane.
Typically an RO system will consistently remove 90+% of TDS for many years. The normal lifespan for a membrane can be anywhere from 3-10 years. It all depends on the TDS of your water and your water usage. The higher the TDS the more frequently the membrane needs replacing. The other filters should be replaced every 6 months to keep the quality up and protect the membrane.
A TDS of 1000ppm compared to 100ppm is much more difficult remove to acceptable levels. I like to compare 1000TDS to taking muddy water, forcing it through a filter and getting drinking water. Where 100TDS may be more like a clear glass of water. Consequently a reverse osmosis system on high TDS will be less efficient, less gallons produced and filters will need to be changed more frequently to keep the quality and quantity up.
RJ
Oct 04, 2010 | Culligan Under Sink Water Filter
What line do you tap into to add an icemaker to a GE Reverse Osmosis water system?
If you want the reverse osmosis water to go to the ice maker then you tap in to the line that feeds the spiget on the sink.
Mar 03, 2010 | General Electric Profile Smartwater Ultra...
I bought a new tank for my reverse osmosis water treatment and it did not come with directions. It's supposed to be ''charged,'' whatever that means. When I hook it up to my system it does not fill with...
Typically a reverse osmosis storage tank should have a precharge of approximately 7 psi. Depending on the make/model of your tank it may have a higher charge currently which would cause the tank to not fill. There should be a schrader valve on the bottom or side of the tank. Using a tire gauge and bicycle pump you should be able to check the current pressure in the tank and adjust it up or down to 7 psi.
reverse osmosis storage tanks: http://www.freshwatersystems.com/c-32-reverse-osmosis-storage-tanks.aspx
Geoff D., CWS-I - WQA Certified Water Specialist
Fresh Water Systems, Inc - http://www.freshwatersystems.com 1.877.335.3339
Nov 04, 2009 | General Electric FX18M GE SmartWater...
Is it possible to contaminate the membrane and filters by placing drain under pressure in order to clear and forcing water out the overflow on the side of the faucet of the whre 25 Reverse osmosis system
OK, now I understand. First, on the Reverse Osmosis Membrane Housing Outlet Ports there is only a Check Valve attached to the Permeate (Pure Water) Port, not the Concentrate Port (Drain Water). The Permeate line is what fills the storage tank, so you don't want back pressure from the tank reversing into the membrane filter which could severely damage it. So, there is a high Risk for Sewer Water to Back-flow into the Membrane Filter and Contaminate it as it is discharging water to the sewer drain if there is any noticeable pressure restriction in the drain distribution manifold. Second, this is why "Air-Gap" Faucets are supposed to be used when installing Reverse Osmosis Systems. With an Air-Gap Faucet, there are three (3) attachments for tubing at the base of the faucet, and a small hole drilled out underneath the lever or handle of the faucet. The 1/4" pressurized drain line tube from the RO System attaches to the 1/4" barbed fitting under the faucet base, then a 3/8" drain line tube attaches to the 3/8" barbed fitting. So when the drain water is pumped up to the faucet under pressure, it returns to the sewer line under Gravity, or No Back Pressure. Then, if the plumbing becomes restricted in any way that the RO Unit can't drain into the sewer under gravity feed, the hole drilled in the base of the faucet allows the back pressure to be escaped to the atmosphere, and if necessary drain water out of the hole until the plumbing pressure restriction can be resolved. This eliminates the possibility of a reverse flow pressure situation from occurring. Hope this helps, and you can always visit us online at www.puresafe.com We have filter cartridges for all makes and models of RO Systems, and 1/2 micron filters that no one else in the trade is using at this time. Thanks, Victor
Aug 05, 2009 | Whirlpool WED6400S Electric Dryer
Plumbing Logo
108 people viewed this question
Top Plumbing Experts
Tom Chichester
Paul Carew
Are you a Plumbing Expert? Answer questions, earn points and help others
