Question about Kitchen Ranges
Need instruction manual for Bosch DKE 995 FAU Canopy Rangehood
Showing an error sign, not sure what is wrong!
3 Suggested Answers
SOURCE: BABT83.2AL Canopy Rangehood The fan/suction is
These units have a history of fan failure due to inferior 220 volt Italian fan.
I have just had fan fail and retrofitted a ebmpapst blower fan model D2E146HT6702 which is readily available in Aus for around $120.
The fan speed control is by inverter variable output so you don't use all the speed select wires that this fan has. Connect the Red wire on the range hood to the Black on the motor (High speed winding) and the Black on the range hood to the Blue on the motor (Neutral) and the earth to the earth (Green).
Disconnect and toss the cap in the white enclosure under the PC board enclosure (the new fan has the cap on board). Don't know how easy to fit in the range hood as mine is in an acoustic fan housing in the roof (makes it wisper quiet when running)
Posted on Aug 16, 2008
  • 72 Answers
SOURCE: bosch dke 935 90cm hood. light and extractor not working
The fuse will be located in the switch or socket that the hood is connected to. This is sometimes inside the flue on the back wall. There should be two small screws either side of the chimney located at the top, unscrew and slide one part of the chimney down, please be careful as stainless steel has very sharp edges.
Posted on Jan 04, 2010
Bosch range hood is making noise but not sucking air. DKE 645 / DKE 945. Any advice welcomed.
There's a backdraft damper located in the ductwork either right at the fan, or where it exits the building. The grease filters could be plugged, or the fan itself could be plugged with grease also. If vented to the outdoors, the vent could be blocked by birds or other critters. Does the fan sound 'normal'?
May 01, 2017 | Bosch Kitchen Ranges
Please can someone advise how to get at the switch board for a Bosch cooker hood E-Nr DKE 995 A GB and FD 8009.
many of the switches used are of the push in type and have little clips on the sides that need depressed to extract the switch . without the ability to see exactly what you have make it impossible for us to assist . contact an electrician locally .
Sep 21, 2016 | Bosch Kitchen Ranges
Bosch dke 935 90cm hood. light and extractor not working
Dec 09, 2009 | Bosch DKE93xxUC Stainless Steel Kitchen...
How to install a rangehood on a glass splashback with no pre-drilled holes in the glass
If the glass is frosted you can use a clear glass adhesive. Put blobs approximately 6 inches appart on the rear of the glass and push to wall.
Nov 18, 2009 | Faber 36quot; Stainless Wall Canopy...
Problem changing halogen bulbs on perla rangehood
The more I worked with it, the more I discovered that the real problem was that a screw was not all the way screwed in and it was preventing the panel from sliding. Another problem I may have is finding the glass covered halogen bulb.
May 13, 2009 | Faber Perla 602599 Kitchen Hood
Change light bulbs in rangehood
I found the instruction manual on the Baumatic website.
Thanks anyway
Apr 18, 2009 | Kitchen Ranges
Am buying a Bosch cooker hood - does it come with filters?
filters required only if you are venting inside your house (ie recirculating the air), if it is going outside, then you don't need them.
Jul 26, 2008 | Bosch DKE 9306 / DKE 9302 / DKE 9307...
Extractor hood
Unfortunately NO, use the template provided. Please ensure there are no cables running through the walls before you drill.
Aug 07, 2007 | Bosch DKE 9306 / DKE 9302 / DKE 9307...
Kitchen Ranges Logo
66 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
