Question about Video Game Consoles & Games
Psp n1003 battery wont charge
PSP GO kindly given to my grandson by his cousin. Battery ran out and will not recharge by AC adaptor or USB cable to PC. I suppose the problem might be the cable and/or the battery. Worry is it is something else!
SOURCE: psp turns on but there is a blank screen
probably you bricked it... it might need a modchip to come back to life..
Posted on Jul 27, 2007
top50
  • 134 Answers
SOURCE: psp not working
This problem occurs when there is some problem with the firmware, it can be happen If you turn off the system or remove the memory stick during an update. If an update is cancelled before completion, the system software may become damaged. if so, you''ll have psp with blank on screen. try remove all plugin MS, Umd, etc, then press bright button of psp. if isn't work you need pandora battery to downgrading your firmware. hope this help.
Posted on Oct 31, 2007
pin_0018
  • 77 Answers
SOURCE: psp wont charge at all
please check ur battery if it is holding any charge with a Multimeter or has it leeked.Try a differ PSP battery.B ecause the PSP needs the battery to start.
Posted on May 24, 2009
  • 51 Answers
SOURCE: psp wont charge, no usb. battery empty after last game.
believe it or not, if the psp works you can play it with out a battery using thee charger. Try that and see if it works at all. If it does then you may need to replace your battery, or leav it and let it charge for about 5-6 hours.
If it's 4 months old and it does not work at all you should still be under your manufacturer's warranty.
here is a link: https://service1.us.playstation.com/rma.htm?_flowExecutionKey=_c85468FC2-00F1-73C8-F8E5-75CD6F7D29EA_kA93A8E0B-D0A2-DB00-D631-BB67FD1DF0A2
Posted on Jun 02, 2009
  • 24 Answers
SOURCE: psp won't turn on or charge
There is a lot of things that might be rong 1 it might be the psp slot where the charger goes it might be damaged in the inside and the more u put the charger in the worse i might get. 2 it could just be the charger something might be rong with it from the wire to the top where it goes into the psp slot . 3 There might be something rong with ur psp battery it might just be damaged . Hope i helped . Go 2 a shop and ask them 2 check it for u. L8a
Posted on Aug 25, 2009
Psp is not charging
  • Make sure the AC adaptor is properly inserted in the PSP system and that the AC power cord is properly inserted in a working electrical outlet.
  • Make sure the AC adaptor for this product is being used.
  • Make sure the AC adaptor is clean. If not, wipe it with a dry, soft cloth.
  • Make sure the wireless (WLAN) network function is not in use while charging. The battery pack cannot be recharged when the WLAN function is being used.
  • If you are charging the battery pack in an extremely cold location, it might take longer to charge.
  • There might be a problem with the battery pack. For the PSP system, try using a replacement battery pack of the same type. For the PSPgo, the battery is built-in, you may need to send your system in for service.
If you need further help, reach me via phone at https://www.6ya.com/expert/eric_5b00a5ceab1c0cd2
Jun 28, 2011 | Sony PlayStation Portable (PSP) Console
I tried to charge my psp with a few 9 volt batteries and i think i fried the motherboard it wont turn on with the battery or without the battery and connected to the AC adaptor. When i try to plug the AC...
You could try another battery.But if another battery doesn't work,sorry mate I think it's dead.In future make sure you only use what you know is compatible,also NEVER try to run the PSP with the AC adaptor without the battery in.The PSP safety and support booklet states: Do not use the PSP system with the AC Adaptor when the Battery Pack is not inserted in the system.If the AC Adaptor is disconnected suddenly,it may result in damage to the system.
If it is the motherboard that's burnt out I think you can replace it but they're expensive I think,I saw one for a PSP1000 for
Oct 04, 2010 | Sony PlayStation Portable (PSP) Console
My usb cable will not charge my psp
Are you plugging the charging plug into the PSP?There are two plugs on the USB cable 1.the USB plug. 2.the charger plug itself. The USB cable looks like the other end that plugs into the computer only smaller.The charger plug looks like the ordinary AC adaptor.
Also note that You need the computer/device that the PSP is connected to,must be turned on,well this is true with mine anyway.
Also the USB does not charge the PSP as fast as the AC adaptor.
Oct 02, 2010 | Sony PlayStation Portable (PSP) Console
My psp wont charge
The psp isn't made to charge from usb by default, if you see that small yellow plug in on the either the side or the bottom, you should have a ac adaptor that came with it to plug in there.
Jun 14, 2010 | Sony PlayStation Portable (PSP) Slim...
Psp wont charge at all
May 24, 2009 | Sony Video Game Consoles & Games
PSP won't come on.
yes. the problem here is that adaptors dont convert voltage. so when you put the psp on charge in ireland it must have fried the circuits so that they wouldn't work. this means that the psp is ruined
sorry to be the one to tell you
Apr 21, 2009 | Sony PlayStation Portable (PSP) Console
Ac adaptor for psp
this i'm afraid is a problem with the psp. to charge the psp off a computer usb mode doesn't need to be entered. so it will charge automatically and if not either the battery or psp charge port are stuffed. try a borrowed battery first then if that doesn't change it trade it in to eb games and get yourself a new one
My psp wont turn on!
  • Hi! TRY THESE TO SEE IF WE CAN GET YOU POWERED UP! :)
    Confirm the system is not in HOLD mode
    Make sure the PSP system is not in Hold Mode (in the down position). Slide the Power/Hold switch up to clear Hold Mode. Or try sliding the Power/Hold switch up and holding it there until the power indicator light turns off and the PSP system is completely turned off. Then try turning the PSP on again.
    • Confirm the backlight is ON
      Make sure the LCD screen's backlight is not turned off. If it is, press any button to turn ON the backlight.
    • Confirm use of only licensed products (AC Adaptor, battery pack and charger)
      The AC Adaptor, battery pack and battery charger must be licensed for use with the PSP system. All licensed products for use with the PSP will have the following logos displayed directly on the product and/or the packaging:
      pslogor.gif global_logos_psplogo_168x35.jpg global_logos_scealogowhite_60x73.gif
      If any of the products you are using does not have these logos on them, we recommend that you immediately discontinue the use of these products, as they void the PSP system's warranty, and can cause damage to the system. See compatible peripherals for the PSP system for a full list of supported products.
      There are some products that can be used with the PSP system that may not display our logos. Products such as San Disk 1GB Memory Sticks, or various USB cables, needs only to be genuinely certified. Look for the genuine certified logos on these products or contact the company which manufactures these products for more information.
    • Confirm the battery pack is correctly inserted
      Make sure the battery pack is in its proper position (see inserting the battery pack for details).
    • Try the battery pack only
      Unplug the AC adaptor from the PSP system. Make sure a charged PSP battery pack is inserted inside the PSP system. Turn on the unit. If you get power, then the problem may be with the AC adaptor and power cord.
    • Try the battery pack in a different PSP system
      If possible, try your PSP battery pack in a different PSP system. If your battery works on a different PSP system, it may indicate an issue with your PSP system.
    • Try a different PSP battery pack
      If possible, try a different battery in your PSP system. If a different battery pack does work on your PSP system, it may indicate an issue with the original battery pack.
    • Try the AC adaptor and the PSP battery pack
      Insert the battery pack and plug in the AC adaptor. If you still do not get any power, your PSP system may need to be sent in for service (see PSP Service for details).
    • Try the AC adaptor / power cord only
      Turn off the PSP system, unplug the AC adaptor, and remove the battery. Now plug in the AC adaptor to the PSP system with the battery removed. Confirm the AC adaptor and power cord are firmly connected to each other. Now make sure they are also firmly connected to the PSP system and the electrical outlet.
      If the PSP system powers on, the battery may need to be replaced.
    • Check AC adaptor and power cord for damage
      Visually inspect the AC adaptor and the power cord for damage. Do not use if frayed, cut, or damaged in any way.
    • Check the electrical outlet
      Confirm the electrical outlet that you are using is active (receiving power). Try using a different electrical outlet.
    • Try a different AC adaptor and power cord
      If possible, try a different AC adaptor and power cord. If a different AC adaptor and power cord does not work, the PSP system may need to be sent in for service (see PSP Service for details).
    • Confirm no unauthorized system software or downloads were used
      Confirm that you have not used any unauthorized system software updates or downloads on the PSP system. Use of such unauthorized firmware updates voids the warranty and can damage the PSP system.
    • WLAN turned off
    • Power surge
      If you experienced a power surge, shortage, or a lightning storm in your geographical area recently, this may have affected the PSP system's power supply. Please contact Consumer Services below for information.
    Sep 03, 2008 | Sony PlayStation Portable (PSP) Console
    Charging PSP Problem.
    Never use a higher voltage than is recommende for sensitive electronics,sounds as if when you used the higher voltage you completely overloaded the battery so it won't hold a charge either way,sounds like you will need a new battery if nothing else is damaged.
    May 09, 2008 | Sony PlayStation Portable (PSP) Console
    Video Game Consoles & Games Logo
    70 people viewed this question
    Top Video Game Consoles & Games Experts
    James Wishart
    Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
