Question about Ranging 400 Rangefinder
Need manual need operating manual for Ranging 400 range finder.
  • sherwood61 Dec 02, 2009
    how do adjust the setting on Ranging 50 rangefinder?
  • Anonymous Mar 24, 2014
    Operational instruction manual
What are you looking for in the manual? Maybe I can provide you some guidance from my manual.
Posted on Dec 21, 2008
Usmc71 could you scan your manual and send me an email copy? russwagner7@gmail.com
Posted on Aug 14, 2010
3 Suggested Answers
SOURCE: Do not know how to operate
First, be sure and focus the eyepiece on what you desire to measure distance to. Begin the measurement with the range dial set to minimum. Slowly tury the dial until the grey-blue image and the yellow image overlap each other. Read the measurement. If you suspect it is in error, you can calibrate the 400 or 1000 or 1200 by turning the screw slot within the range dial using an object you know the distance to. If the two images are off in the vertical direction, there's a screw below the range finder to adjust that. Turn it very little. Regarding the model 610, mostly the same except to calibrate it, merely spread the adjustment knob apart (spring loaded) and turn the part of it nearest your eyes so the yardage matches the distance.
Posted on Jan 03, 2008
  • 75 Answers
SOURCE: Need to know how to operate a Ranging 600.
Go to; www.konus.com, they are the maker of this rangefinder, or call them in Miami,Fl. at; 1'305-592-5500, they should be able to assist you with a Owners Manual.
Good luck. :)
Posted on May 05, 2009
I have a ranging 100 i need the manual for
I just got one complete with manual and original box. It was not working, so I disassembled it and repaired the internal mechanism and recalibrated it for distance and vertical image coincidence.
Disassembly is easy (two screws at front and rear) and the "repair" for mine was to lubricate two pads that the mechanism rests on that were "sticky." I removed the mechanism, but that is not required -- just manual manipulation of the distancing arm should be sufficient to expose the lubrication points. Do not use 3-in-One or similar oil -- that thickens with time. Lacking the "proper" oil type (watch maker's), I would use a small drop of motor oil.
Calibration is simple -- use an object with a known distance that is about half the range of your unit. Adjust the "focus" knob to make the two images coincide (don't worry about vertical coincidence yet). Hold the thinner of the two distance adjuster knobs and turn the thicker one until the tape displaying the distance reads the actual distance to the known object. I would then adjust the image coincidence vertically by turning the screw on the bottom of the unit on the right (near the loop for a lanyard). It will be stiff! Turn it about a quarter of a turn and recheck vertical image coincidence -- if worse, turn it back the other direction a half-turn. Repeat with small turn increments until the images coincide vertically. Once that is done, recheck the distance calibration.
Dec 21, 2010 | Ranging 400 Rangefinder
How many qrt of motor oil do i need to use
1996 Isuzu Truck Trooper 3.2L MFI SOHC 6cyl
The Engine Oil Capacity 5 7/10 Quarts (including filter)
Engine Oil Type and Weight
Oil for use in temperatures ranging from -13 to 100 degrees
5
Application:
Note :
Quarts without filter change
Oil for use in temperatures ranging from 32 to 100 degrees
5
Application:
Note :
VALHD30
Application:
Note :
Valvoline Premium Conventional 30 Motor Oil
Hope this help (remember rated and comment this). Good luck.
Mar 29, 2010 | 1996 Isuzu Trooper
Basic operation of the 50/2 mini rangefinder
look through view finder and see the two images and turn wheel til it becomes one and then look at wheel to see the distance. this is a pretty accurate piece of equipment. classic range finder and will be worth some money someday if in good shape.
Oct 03, 2009 | Ranging Optics
Ranging inc. model 50 rangefinder
I have one still in the box with manual. Do you still need one?
Oct 26, 2008 | Ranging 400 Rangefinder
No Ranging Response received - T3 time-out
below 55dBmv TX is a lot better. Could be a bad service line. Also if you call the cable company and have them come out again. Have them put their DSAM meters on the house lines as well as the service tap and have them check for upstream ingress. a lot of things can cause this. It could be a loose fitting somewhere in the house. A t.v.'s shielding may be going out causing unwanted frequencies bleeding in and creating all kinds of noise on the upstream spectrum going back to the node. It could even be a neighbor causing this with their own equipment. If that's the case their maintenance techs should be able to find that.
Mar 13, 2008 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Mar 16, 2007 | Ranging 400 Rangefinder
Ranging 400 Rangefinder Logo
983 people viewed this question
Top Ranging Optics Experts
james laughton
james laughton
ray gallant
Are you a Ranging Optic Expert? Answer questions, earn points and help others
