Question about Hardware & Accessories
How do I program a Cat D817/2 Timer
I have had this timer for some time and have just moved house and can't find the instructions. The timer is 240 vac 50 Hz 10 A (2400w max) resistive 030301/2/5
  • 4 Answers
SOURCE: Timex 250 Vac 25 Amp 24 Hour Timer Switch Won't Keep Time
Can the clock be repair or replace, my will not keep time.
Posted on May 23, 2009
SOURCE: HPM D817/2 electronic
1) I have located a similar timer, with similar buttons.
Tork 451D with manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#seven
The buttons are in different order, and Tork is 120Volt timer, not 240Volt like HPM.
This information may help if you have HPM timer and can experiment.
I doubt this information will help if you are simply looking for a clear cut 1:1 manual to sell on-line.
2) The HPM timer does not sell in US, but the timer is inexpensive and you can purchase the timer for $27 and scan manual into pdf format.
3) HPM also has a contact us page, but I don't know if they will send manual of if link is good:
http://www.hpm.com.au/Products.aspx?pid=18#Timers/Timers/7-Day-Timers
Posted on Jan 10, 2011
SOURCE: I need operating manual for
I found a timer with similar buttons.
Tork 451 D, with manual
1) Tork 451D manual might work if you have the HPM to experiment with.
2) If you are looking for exact 1:1 manual that you can sell on the internet, I have been unable to find the manual.
3) For 27$ you can buy the timer, but it's not available in the US.
Buy the timer, scan the manual with your pdf software, and then post it on your website, and then add a comment to this thread with web location of the manual so you can help others looking for the manual, for free.
4) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on any do-it-yourself project.
Posted on Jan 12, 2011
SOURCE: instructions to set timer on. DIGITAL TIMER CAT.
TD2200 image and links:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59377
TD2200 manual
http://waterheatertimer.org/pdf/Woods-49377-TD2200-manual.pdf
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Jan 30, 2011
SOURCE: Is it possible to buy the timer motor for a
1) Paragon is no longer making timers or parts except defrost timers.
7008-20 240V 24-hour mechanical timer is not a defrost timer.
Link below shows folks who might still have Paragon parts
http://portalgb.knowledgebase.net/display/1/index.aspx?c=15121&cpc=XobrEdQ5Lsnv624T2PBS4Exx6S5VyiL7gw3am4YYt6&cid=13013&cat=&catURL=&r=0.485034763813019
2) To see Paragon timers and manuals:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#7000
3) If you want to buy new timer: Intermatic cross-reference guide shows T7802B is correct replacement timer
http://www.intermatic.com/customer%20service/competitive%20cross%20reference.aspx
4) Electric supplies online shows T7802B 4 pole 2NO/2NC
http://www.electricsuppliesonline.com/int7tidp20t.html
5) Manual for T7802B
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/t7802b%20-%20english.ashx
Posted on Feb 09, 2011
I have bose wave with input voltage 110 volts but i want to change it 220 volts where i can buy a transformer
Check the back or the bottom of the Wave unit for the input voltage rating. If it has a universal power supply, it will show something like "Input voltage 97-243 VAC 50-60 Hz," i. e., the input voltage rating spans the full range from 110 VAC US to 240VAC Europe. In that case, all you have to do is get a power cord suitable for the power in your area.
I checked the specification in the on-line owner's manual, but it wasn't helpful; it said the input power rating is "220V-240V
50/60Hz 60W max" We know it works on 120 V, so the 220V in manual may be a typographical error. Go with the information on the unit case. If it says "120 V 60Hz" and nothing about 240 V, then you would need a transformer rated for at least 70 Volt-Amps (60 Watts plus a reserve factor so you don't have to worry about overloading it).
I tried checking my favorite site for electronic products such as travel transformers and adapters (MCM Electronics), but as of this time they were having server problems. Note: they may have the 240 V version of the power cord, or you can check whether Bose sells it separately.
https://www.mcmelectronics.com/
Aug 05, 2017 | Bose Audio Players & Recorders
My robin subaru r1100 can I run it at 240 as it has a UK plug on it I tried to run a kettle but it started to cut out thanks
You need to determine output frequency. Is your engine running at 3000 rpm (50 Hz)? At 50 Hz this generator only produces 700 VA (850 VA max).
I just look at my coffee pot here and it requires 1000 VA (watts) of power. If is more power requirement than this generator could produce even if it was operating in 120v mode at 60 hz.
Feb 09, 2015 | Garden
Utilitech TM-029 wall timer: I've installed the
Do not run any timer warm... replace with switch, and/or buy another timer.
Copy following link to identify timer and download instructions:
http://waterheatertimer.org/Program-wire-Utilitec-LW60418.html
This timer is rated 15 amp 1875 watts.
Safe maximum is always 80% rating plate: is 12 amp and 1440 watts.
Add up total watts on circuit.
Add a comment and say what you discover.
Jun 29, 2013 | Hardware & Accessories
4 station timer help
Copy following link to help identify timer:
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
Most major brands are linked here, including manuals for each.
Some brands such as yardworks, etc, repackage other brands and have no online support or clear resolution for warranty claim.
Open link, then add a comment with brand and model and voltage so expert can access same manual.
Replace battery. Reset timer. Check if unit is getting power. Check if outlet has correct polarity. Are some basic troubleshoot steps.
Most timers have 1 year limited warranty, and timer that came with used house may no longer be functioning. Or the sprinkler hear has gone bad.
For replacement, I think Intermatic mechanical sprinkler timers are better value than digital timers, since the mechanicals have repair motors and trippers and can last 25 years.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
Add a comment for more information on timers.
May 22, 2013 | Hardware & Accessories
Timer programming help
Maybe the sprinkler head is not advancing.
May 22, 2013 | Orbit Hardware & Accessories
Noma digital timer cat td1000
Copy following link to help identify timer and download possible manual.
http://waterheatertimer.org/Woods-timers-and-manuals.html#Oval
Timer brand numbers and designs change.
Add a comment and describe timer in detail if your timer does not show on link above.
Nov 28, 2012 | Hardware & Accessories
How do I program the H5CX ASN timer to turn on 5 mins and off 25 mins in an endless cycle. I don't understand the term Output Mode so from that point the instructions become meaningless.
Omron:
https://www.ia.omron.com/support/
http://waterheatertimer.org/pdf/h5cx_sell-sheet-wiring.pdf
I believe you have 230Volt 50 Hz electric power.
Omron is rated 50-60 hz
US timers are rated 60 Hz.
Maximum load on Omron timer is 5amp at 230 volt
Timer should be connected to 2-pole contactor (relay) instead of directly connected to pump.
http://waterheatertimer.org/images/contactor-drawing.gif
Does Amazon sell percentage cycle timer in your country?
A cycle timer makes one full revolution each hour, or 4-hours, or 12 hours. Then percentage is set for 8% for 1 hour cycle.
Contact Intermatic and ask if they have 50 cycle percentage cycle timer, or ordinary cycle timer in 50 Hz.
Nov 22, 2012 | Omron H5CX A AC100-240 Multifunction...
Vocalist Live 4
U.S and Canada: 20 VAC, 60 Hz Adapter: PS093B-20
Japan: 00 VAC, 50/60 Hz Adapter: PS093B-00
Europe: 230 VAC, 50 Hz Adapter: PS093B-230
UK: 240 VAC, 50 Hz Adapter: PS093B-240
Power adapter requirement straight from the user manual. I am sure you are aware that a simple plug adapter in a tourist shop does nothing to convert 120v US to 240v AUS. Note you unit does not like temperatures above 40C. And you can get that in Australia.
Bear in mind the timezone difference if you try Digitech support in the US.
DIGITECH VOCALIST LIVE 4 Owner Manual Page 36
Dec 30, 2017 | Digi-Tech Digitech Vocalist Live 4...
Hardware & Accessories Logo
83 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
