E116921 power not work
Elkot+q7+zd4 changed> +5v ok, +12v and +24v no!
  • 191 Answers
SOURCE: Polaroid " 3211 TLXB red light no power
hi remove the supply to the main board & inverter, now power your psu if give you this same above voltages , go for new power supply unit. change your power
Posted on Oct 12, 2008
  • 267 Answers
SOURCE: No power to viewsonic N3252W lcd
TRY THIS SITE OR GOOGLE YOUR MODEL #
http://www.free-service-manuals.com/
Posted on Apr 10, 2009
  • 2336 Answers
SOURCE: FSP194-3F01 NOPOWER 5V OK NO 16V OR 24V
The 5 volts is the standby voltage that should always be present, the other voltages should be there when you try to turn the LCD ON.
If the 5 volts standby are not steady when connected to the main board, Q7 might be defective.
Check all the capacitors in the secondary circuitry for bulging or leaking conditions.
Posted on Aug 28, 2010
budmrtn
  • 11361 Answers
SOURCE: insignia ns-lcd47hd09 i check voltages again solid
It means the feedback circuits for regulating the 12/24vdc is not working, use 12v car bulb (1157) to load down the 12vdc supply and two 1157 is series to load down the 24vdc power supply and see it if still rises up, the stange thing is that you said it rises to 36vdc (12 + 24 = 36), is it being measure correctly?
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Posted on Sep 07, 2010
Testimonial: "great were almost there A+++"
  • 2336 Answers
SOURCE: de antemano un saludo, espero
Aqui te esta la informacion que necesitas:
Q7= 2N2222, o 2N4401 es un NPN transistor
ZD4= 15V 1/2W ZENER
Posted on Dec 04, 2010
Actually its a printer that gives out 3.3v, 5v, 12v, 24v and 47v. But the 24v and 47v is not coming, any good answer?
If you measures at the power supply module and the voltages are DC then you probably have some bad regulators. Parts are usually not coded so replace the power supply module.
Jul 02, 2016 | Televison & Video
Repair tips
does all the vlotages come from the psu you have to mesaure stby voltage 12v 24v and 5v if all these are ok there a great possibility that your mainboard cannot start then try changing the flash memory
Jul 09, 2014 | LG 47 47LK520 47 LCD TV
Hi there, i have a baird lcd model j047baird\r\nthe fault i am having is, it stuck in stby. power supply look fine all voltage is there. if i disconnect the lead j5 from main board to invertor the screen...
there is 2 problems that makes this tv have standby fault.. so here they are,!
1.)main av board ---the 8 leg eeprom loses programing just under LVD CABLE TO SCREEN -£14.99 from a guy or if you can program yourself 4.99 for the flash to reprogram,.
2.)POWER SUPPLY FAULT IS MLT199TL PSU. (UA4)AREA, SG3525AN (16 leg) Regulating pulse width modulator.
the first fault all votage at psu will be there ,, 5v / 12v / 24v
the second fault psu will have 5v standby but no 12v or 24v this will stop the secondary from fireing up.. hope this helps.
Jul 31, 2011 | Televison & Video
Aug 28, 2010 | Protron PLTV3250 32 in. LCD Television
Fuse and power supply look ok to the eye slight static sound on audio tiny flash intermitent inright corner on video, any clues? power diods check good ,nothing looks hot or burnt There is a second board...
Your power supply on the dc output should have the floowing DC voltages, 5v, 12v, and 24v. Just start probing the connectors of the power supply. 24v is needed for the backlights inverter board, 12v for sounds, 5v for logic board.
Dec 09, 2009 | Audiovox FPE3206 32 in. LCD Television
Viewsonic N3250W won't power on
Got the same problem for a N3250. I'm not an electronic engineer and will attempt to fix my TV. Therefore I got the FSP2123F02 ($49.75)and now they have a harness 4WT0062302GP ($8.90) that will do a quick plug and play and will avoid any solder of the pins. That is my understanding can anyone corroborate this procedure. By the way I got both products from electronica-usa.com
I repaired it on June 28th with the lsit of parts above
More deatil information here (of the problem) http://forum.eserviceinfo.com/viewtopic.php?p=149367#149367
List of photos
B) new Power supply and new 12 pin connector (plug and play)
C) old board
D) TV picture in HD
Jan 15, 2008 | ViewSonic N3250W Television
Televison & Video Logo
505 people viewed this question
Top Televison & Video Experts
