Question about Sharp Microwave Ovens
How to use microware oven model R360j
Sharp micro wave oven model R360j dont no how to use
MicrowaveSvc
  • 9098 Answers
SOURCE: Micro Wave shuts down
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Posted on Nov 24, 2008
  • 8404 Answers
SOURCE: How many micro wave ovens will a 20 amp circuit support?
Please stick with me to the end ... some examples are for example only. There is no 1000 watt circuit per'ci.
This will not be possible overload, this is an accident waiting to jump on you, my friend
Install dedicated circuits for these ovens, my friend. It will cost you a little but will be better than having dissatisfied guests or talking to the zoning board or boarding house authority or (gasp) the fire inspector after the fire.
If you don't do this, when the breakers start flipping off, tenants will run extension cords to outlets that have power. A whole different and worse, problem!
Rule of thumb, lighting circuits should be designed to operate at 80%, for example, if you have 800 watts of lights on a 1000 watt circuit, you are at the max.
So, there is a possibility that your circuit for lights is already near max. Adding ovens is trouble. Don't forget the iPOds and cell phone chargers as well as lap top chargers, walkman chargers (older students), little TV's, DVD players, clock radio's, electric shavers, curling irons, steamers, popcorn makers, lava lamps and occasional electric heaters that will be snuck into the room.
What is a 1000 watt circuit ... good question. Ohms law comes into play here.
Volts X Amps = Watts
120 volts X 8.333 amps = 500 watts (a smoothie blender) 300 watts (slow cooker) 200 watts (hand mixer) = 1000 watts.
A 15 amp circuit will protect #14 wire and can carry about 1800 watts (a toaster (1500 watts), for example).
A 20 amp circuit will protect #12 wire and can carry about 2400 watts (i am using a big paint brush here. these numbers are pretty close but not exact and I am not a licensed electrician.)
When I wire, I aim lots lower, preferring to OVER build than to under build.
10 amp circuits are rare in modern homes. In general practice, if the need was to be protected at 10 amps, the wire used in the circuit would be #14 and it would be protected by the breaker at 10 amps. In this case, it is the device plugged into this 10 amp circuit that needs protection rather than the #14 wire (which would be technically oversized)
Another consideration for you is where is the water? If you have an outlet that is 5 feet from a water source (bath - kitchen - etc) it must be protected by a GFIC
A 30 amp circut will protect #10 wire --- but this is not a normal household circuit.
Maybe the best option is for you to have your electrician install a sub panel in the vicinity of use and run several 20 amp circuits from that location to the various rooms.
The answer to your question "How many (1150 watt)micro wave ovens will a 20 (amp circuit handle)" is TWO with nothing else on the line. The National Code requires dedicated circuits for micro wave ovens, BTW. A commercial application may have a different (more stringent) standard in your town.
Thanks for the opportunity to answer your question and thanks for your interest in FixYa.com
Please vote - positive comments appreciated by volunteer question catchers.
thanks
a
Posted on Dec 13, 2009
  • 10865 Answers
SOURCE: outer door frame cracked
Hello. That frame is decorative only so you need not worry that there is a radiation leak. You may be able to order a part for it or you may be able to use some clear epoxy and a couple of furniture clamps to repair it. It you choose a clear epoxy get the 5 minute type as that will give you time to position the clamps. The 1 minute won't give you enough time.
Posted on Mar 11, 2010
  • 949 Answers
SOURCE: micro wave not working jen air
The Transformer is part number 56001221. I have run a search for the part and I am coming up with the same results, the pat is discontinued and no longer available.
Sorry
Posted on Apr 24, 2010
SOURCE: I cannot set the clock on my LG MS1949G Micro wave
After spending 25 minutes on hold while LG try to find out how their own product sets the clock, I now know that the LG MS1949G Microwave open does NOT have the ability to set a clock that shows the time of day.
Posted on Jul 05, 2010
Where do I find manual for Sharp Model SPC314 clock?
As an answer I post often.
Micro waves are now throw away items , but if you want to go down the route to fix in England you need a REETRA qualification .
Next go to a parts centre , show your REETRA then you will find all you need.
Oct 14, 2014 | Microwave Ovens
Try2910227 serial ywmh2205xvb-0 model arcing on the back corner were the rack sits.Is there a way to repair this seen is the unit was purchaced in June of 2011.
Yes, take the rack out and recycle it. I do not know why these micro-wave company put racks in the micro wave ovens. You get some insulation on the inside the micro flaking off next the rack.
The mega-tron tube is a very high energy transmitter. The energy will come out of the top inside the micro wave oven in a wave guide. Micro wave energy that generation by the tube is high frequency into Gega Hertz. You have a metal tray in side the micro wave acts like a big capacitor it stores energy in form of heat the next you know it look like Marconi is putting on a lighting display.
Leave the wire tie on a loft of bread and put in you micro wave oven to defrost. The next thing you might see is a load bread burning, instant toast. ----The use of micro wave were invented by the British before WWII. The mega tron tube generation very high frequency radio wave and these wave struck an object 100 miles away some of this beam energy would balance back to a receiver-----You have Radar.... I wish you and your family well being and be careful of micro wave ovens it can burn from inside out. GB you...stewbison
Aug 22, 2011 | Microwave Ovens
My micro wave stop heating food, every thing dislay work fine. when start it make loud sound. Sharp carousel II, model = R-3A54, Manufacture jan,1993
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jul 27, 2011 | Maytag MMC5000 Microwave Oven
The 'Start' button was pushed in too far, and it's now just sitting in there loosely. How do I fix this?
mcdevito75, You may have to replace the entire circut board containing all the micro wave ovens controls. Look for an small appliance repair shop in your area, or any place that sells microwave ovens for help.
Jun 20, 2010 | Sharp R-310A Microwave Oven
I have a Sharp micro wave model R-1492. It turns on, but nothing cooks. Do you think I may need to replace the magnatron
first before you replace the most expensive part of the unit,check the h.v. diode and h.v. capacitor, the thermistor on the magnetron tubes outer case side, you will need to remove the top cover to accomplish these things
Nov 14, 2009 | Sharp R-1492 Microwave Oven
No power. but it is pluged in and checked breaker
Try plugging a lamp intothe same socket and see if it comes on if it does the fuse in the micro wave has blown but there are up to 5 fuses on some models so I need a model and serial number to help you fix the problem.
Sep 28, 2009 | Sharp Microwave Ovens
Instructions for Sharp R953 900wt jet convection grill microwave
i have need instruction book how i can use sharp micro wave oven r953
Dec 27, 2008 | Microwave Ovens
Sharp carosel micro wave Model R-9h54
I'm very sorry to tell you that keypads for all Sharp R-9H-type models are no longer available.
When the oven becomes unusable, it will simply have to be retired.
Sorry we couldn't bring you better news, but we're happy to help you and we'd appreciate your thoughtful rating of our answer.
Aug 01, 2008 | Microwave Ovens
I have a sharp micro wave oven. Occasionally, when some foods are cooked or heated, you can see small bursts of blue flame. What I should do ? I only use microwave safe containers.
You probably have a burnt wave guide cover. Look inside the microwave either on the side or on the top, it's a square piece of mica board, and you should see a burnt spot on it. You should be able to replace it fairly easy with the model number I can check on a replacement for you.
Jul 09, 2008 | Sharp R-220HW Microwave Oven
I WISH TO REGISTER MY GUARANTEE AFTER PURCHASING A SHARP MICRO WAVE
You can contact Sharp at 1-800-BE-SHARP (1-800-237-4277).
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Apr 14, 2008 | Microwave Ovens
Microwave Ovens Logo
101 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
