Question about Dell Inspiron E1505 Notebook
How fix error code 1000-1041 in dell inspiron e 1505 no drive detecte
antiochpc
  • 1314 Answers
SOURCE: dell inspiron 1520 error code 2000-0146
Yes, it is a hard drive issue and there is no fixing it temporarily without losing your data. The best thing to get your data is to get a USB enclosure for the type of drive it is (if it's a sata drive or a pata drive) or get an adapter that's an all in one (for 3.5, 2.5, and SATA). Then you hook your failing drive up to the converter, put it in the usb port of another computer and then it will show up as another drive that you can open and explore.
Posted on May 27, 2009
spike888ph
  • 77 Answers
SOURCE: No drive detected
Try inserting another SATA hdd (hope you have an extra) and see if your laptop computer detects it or not.
if it does, then your old hdd is confirmed to have totally crashed
if it does not detect still, then you are faced with a bigger problem which is the board.
Posted on Apr 09, 2008
ziraffa
  • 827 Answers
SOURCE: my dell inspiron 1505, has very slow start ups, use to be fast
download ncleaner
http://www.nkprods.com/ncleaner/
i use it for cleaning up my computer but after you install it you can click on the far right button concerning 'startup items'
uncheck boxes for programs such as messenger, skype, 4od, iplayer, limewire, utorrent etc but do not uncheck any programs that you are not sure of what they do. most slow boots are to do with people installing programs and not unchecking the box that says 'run when windows starts'.
there is a method for deleting 'prefetch' in startup too, but i would suggest you try the first method i mentioned first, as the 'prefetch' option can cause all sorts of problems if you are not 100% sure what you are doing..
ncleaner is a great program anyway, you should definitely use it to clean up your computer, although when i first ran it, it deleted everything in My Received Files, so copy everything out of there to somewhere else first. :)
good luck
chris
Posted on Dec 13, 2008
  • 3 Answers
SOURCE: My dell inspiron 1525 notebook comes up with error
WHEN COMPUTR STARTS PRES THE F2 BUTTON , IT WILL TAKE U TO THE SYSTEM SETUP , GO TO ONBOARD DEVICES , OPEN AND GO TO FLASH CACHE MODULE AND DISABLE ( OFF ) THEN GO TO SATA OPERATION ALSO IN ONBOARD DEVICES , SET IT TO BE ON ATA NOT AHCI , THAN AND SAVE !!!! DONE ,NOW U CAN DO WHAT THATS IN UR MIND FUTHER QUESTION OR WANT TO EXCHANGE IDEAS EMAIL ME ON JAYSPRUNG@GMAIL.COM HALLA AT ME
Posted on Jun 16, 2009
  • 4 Answers
I had the same problem and came across this solution that worked for me as well:
Re: windows Vista will not start 18 Aug 2009 07:28PM I was getting a the same error codes and couldn't get Windows to boot up at all. I went to BIOS set up (restart your computer and hit F12 when the BIOS screen comes up), went to onboard devices and changed the SATA Operations from ACHSI (don't know how it got there) to the factory default setting ATA. Then I started up in "repair mode" (which was an option that was coming up when I tried to boot up before but never worked) - it went through a repair check and went to login screen.
Prior to finding this - I tried several things including start up from the Reinstallation disc, but nothing worked. I was ready to buy a new hard drive, but don't have to. Works fine!
Not sure what caused the problem to start with. It is an "Inspiron 1520"
Posted on Aug 21, 2009
Error 0141 msg:error code 2000-0141
The hard drive has failed. If you're in warranty, contact Dell for a warranty replacement of the drive - it's a customer-replaceable part.
If you're out of warranty, look on ebay for a good deal on a brand new hard drive for your Dell Inspiron 1525
Nov 09, 2009 | Dell Inspiron 1525 Notebook
Error message 0141
This error comes when the system is not detecting the hard drive. just remove the battery and hard disk drive and connect it again.
Sep 15, 2009 | Dell Inspiron 6400 Notebook
Error code 0146
Alot of times when Dell replaces a hard drive, its usually one thats been refurbished and NOT brand new. Since you have been definitely been having issues with more then one of there hard drives, defiinitely call them back and have them walk you thru all the steps to verify and the once they verify it tell them because you have had lots of problems with hard drives in that unit to please make sure to ask that a BRAND NEW one is installed instead of a REFURBISHED one.
Hopefully they will do this seeing as how there has been lots of problems. Hope this info helps.
May 17, 2009 | Dell Inspiron 6400 Notebook
Dell Inspiron 6400 Vista CD Drive Does Not Recognize CDs
Try to use dvd cleaner disk to clean the lens, if it doesnot work, i think you have to replace your drive , this happens with Dell alot. but try to clean it, uninstall then install the driver back and check if its work.
Best Regards
Mar 14, 2009 | Dell Inspiron 6400 Notebook
How to get factory settings for my Dell Inspiron 1505
If you have Windows Vista you can press F8 while booting to access the Windows Startup Repair and then select the Factory Image Restor.
Dec 09, 2008 | Dell Inspiron 1501 Notebook
Code error 0146 and 0148
Both of these are hard drive errors. Error 0146 is a failed hard drive or bad drive sector, and 0148 is that thew machine is no longer detecting the hard drive. Basically, your hard drive has failed and will need replaced. Replace the hard drive and you will be set. The best place I've found to buy hard drives is at pricewatch.com, they have the best prices on the market.
Jul 29, 2008 | Dell Inspiron 1150 Notebook
Dell Inspiron E1505 Notebook Logo
200 people viewed this question
Alun Cox
