Question about Boating
Furuno processor unit rpu-015 manuals Problems
2 Suggested Answers
TechnoMarine
  • 132 Answers
SOURCE: Testing Simrad Autopilot RPU160 Reversible Pump (21118237)
yes, hook it to 12V it runs, reverse wires it runs opposite it will spit oil, watch out! shoulda coulda left it in place and tested with jumper cables or battery if pump is bad 1 find out why your boat eats pumps 2. call me, i have it in stock for less than you paid before (most likely) 3. you can replace the electric motor without disturbing the hydraulics!!!
847-746-0100
Posted on Jan 16, 2010
Furuno 1731 radar i purchased, the person i got it from extracted the pins from the plugs on the signal cables 3 plugs. all pins are still on the wires i just need the pinout to reassemble the plugs
Your only option here would be to contact Furuno support and talk to a tech from the people that actually designed and built the unit.
Furuno support can be contacted at:
http://www.furunousa.com/Support/FAQ.aspx
Should anyone require the owner's manual it is accessible at the link below.
Hope this helps.
-Steve
http://www.furunousa.com/ProductDocuments/1731%20OME.pdf
Apr 10, 2015 | Furuno Boating
No data at >1mile
If the unit is new and never been set up post installation, that's probably your problem. You have to go into the Installation Wizard and set the unit up properly. There are multiple choices of displays and scanner units to select to obtain the configuration you have. Then the radar has to be optimized (auto-tuned). If you don't have access to an installation manual and feel confident yourself, you'll need to contact a local Furuno authorized dealer or call Furuno USA tech support and they'll walk you through it. Their number is 360-834-9300
Dec 26, 2013 | Furuno Navnet 1834C/NT vx2 Radar C Map Nt
Where can i get a manual for a furuno gp1650 chartplotter
Here is a link for the manual.
http://www.furunousa.com/ProductDocuments/GP1650%20GP1650D%20Operator's%20Manual%20N3.pdf
If the link doesn't work go to furunousa.com and enter unit model number in search bar. Select the unit then select the manuals and documents tab. Operation manual is there and can be viewed and/or downloaded in pdf format.
Nov 04, 2013 | Furuno Boating
Furuno FCV627
Yes, using a NMEA connection between the two units. Refer to you owners manual on how to set this up.
Jul 24, 2013 | Furuno FCV627 5.7" Color Sounder 50/200KHZ
I need a manual for the Furuno ls 6000
Go to the website: http://www.furunousa.com. Search under the previous products, fishfinders, display size 6". Under either one you will be able to download the manual for free. If you have any problems email me: kevin@sun-me.net and I will email you the manual.
May 14, 2010 | Furuno 1623 Radar 16nm Range
FURUNO FAR- 2827W units and parts code numbers list required.
Call me at 847-746-0100. I have some things in stock and at a great price! Call Furuno directly to determine your needs, or call me, John Barry at the above number. I have a trackball and Monitor and Gearbox. www.technicalmarine.com
May 07, 2010 | Furuno 1715 LCD Radar System GPS Receiver
INSTALLATION MANUAL FURUNO FCV-585 BEST GROUND FOR THE UNIT SHOULD I GROUND IT TO ENGINE OR BELLHOUSING OF OUTDRIVE
Attach to engine grounding point with battery cable. Add a grounding plate for RF (green) ground.
May 03, 2010 | Furuno Fcv 585 Color Fishfinder
847-746-0100
Sep 13, 2009 | Simrad Rpu160 Reversible Pump 21118237
Furuno 4100 depth sounder shows depth twice what it really is
check your gain setting try auto gain and try manually gaining back to see if it resolves, if yes, send unit in to furuno, if no, ducer is probably at fault.
Aug 01, 2009 | Furuno Ls4100 5" Mono Lcd Fishfinder Temp...
Boating Logo
228 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
