Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
Admiral HMG 62163 water leaking internally & freezing in lower basket
I have a Admiral HMG 62163 side by side. Its has a possible internal water leak, it freezes in the bottom floor of the freezer and the basket is half full of ice. Some times their is water on the floor in front of the freezer door. Is this a problem with the ice maker feature or when the freezer defrosts it self. I turned off the water to the freezer (ice maker, etc) and cleared out the ice dam & basket. Maybe I can eliminate one of the two possible causes. I will give this a couple of days and see what happens. Thanks for looking and any help you can provide.
Ron
Brownstown, Mi
  • rmiller249 Oct 26, 2008
    I did as you suggested and found a ice jam - plug in the defrost drain. This was removed with the hot water and I cleared out the drain tube with compressed air. I reassembled the freezer and turn on the ice maker (water). I will seen what happens later today. I will keep you posted.
    Thanks Again for your help,
    Ron
    Brownstown, Mi
I have a admiral GC2027HXKW AND THE TEMPERTURE KEEPS DROPPING LIKE ITS DEFROSTING CAN YOU HELP THANKS PADME
Posted on Nov 05, 2008
    President:
  • Admiral Master
  • 2,651 Answers
Good attempt, its actually a clogged drain thats backing up and your drain water is not able to leave refrig so it falls to bottom of freezer floor and eventually out the door. romve the items from the freezer and take the lower back wall off form inside, directly under the evaporator under all that ice there is a drain hole, youll need to clear that hole of iec( pouring boiling water down until you get a free flow of water then you can reassemble uint problem solved
Posted on Oct 26, 2008
My admiral model hmg-64184 is leaking water from the bottom of freezer
It sounds like you have a broken place in the door gasket that is allowing warm air to enter the freezer.
May 29, 2015 | Admiral 26 cu. ft. Side-By-Side...
GE side by side leaks water from underneath when you use the water from front door
you need to remove the toe kick panel grille below the front doors on the refrigerator behind this grille there is a connector and it can come loose,also possibly the water valve in the lower rear behind the back panel can leak,have a helper press the door paddle for water and check all these areas for leaks,if it leaks from the door stem where the water line goes up the door to the dispenser,then you will need to pull new hose up to the dispenser from the collar mentioned at first,some refrigerators can not have new hose installed due to the door has been foamed internally at the factory and cant be dis-assembled,then you would need a new door with the hose installed
Apr 08, 2013 | GE (PSS26MSRSS) Side by Side Refrigerator
Samsung fridge water leaking and freezing
you might want to post this in the refrigerator section
Aug 01, 2012 | Cars & Trucks
I have an Admiral designer series refrigerator side by side HMG65158. I don't have a book for it and I need to know how to hook it up to water so the refreshment center will work?
There are 3 models of this unit:
HMG651580
HMG651581
HMG651587
That does not matter for hooking up water. Look on the back of the unit. You should see a 1/4 inch copper tube sticking out with a black rubber cap. Pull off the cap and connect your water supply using an icemaker connection kit available at any hardware. Most kits come with instuctions but it really rather simple. The key is to ensure there are no leaks at the saddle valve or compression fittings when your finished.
If you do not see a copper tube sticking out... carefully remove first the right side of the lower rear fiberboard cover and look for a water valve connection. It is usually on the rt side but since this unit is actually made by Sharp... I am not sure. Check both sides.
The
See this net search:
http://www.google.com/search?q=ice%20maker%20connection%20kit&rls=com.microsoft:en-ph&oe=UTF-8&startIndex=&startPage=1&um=1&ie=UTF-8&tbm=isch&source=og&sa=N&hl=en&tab=wi
The kits run from around $10.00 for the plastic line kits and up to $35.00 for the copper line kits.
All kits use compression fittings and saddle valves for making the water connections. It is recommeded that you also install an external in line water filter even if your refrigerator has an internal filter. The external filters are dirt cheap compared to the internal filters and will make the internal filters last 5 - 6 times longer.
Thanks for choosing FixYa,
Kelly
Jun 02, 2011 | Admiral Refrigerators
The ice/watermachine is leaking water at the bottom on the until- what could be wrong?
I'd re-check the water line from the water source to the fridge itself. There maybe a loose tube, or do vise versa and check the tube coming from the fridge to the faucet. If you can't find a leak, then it's internal. May have to call in a specialist for that to open up the back panels of the fridge to check further.
Feb 07, 2010 | Admiral 26 cu. ft. Side-By-Side...
I have a maytag fridge,its maybe 3 years old,lately it keeps forming a pool of water in the front,the drain pan underneath is always dry,seems to be leaking fron the sises,a drain hose plugged or came off...
This is one of the most common problems that the maytag side by side has. ( Admiral ) The drain in the interior rear gets plugged and all of the defrost cycles over a week or so produces enough water to freeze up and the run over and come out under the basket then on to the floor in front left. If this is your problem, shut of the ref., remove the 2 or 3 baskets and remove the 2 screws holding the lower panel on. Remove the panel, careful not to cut yourself on the coil fins, remove the ice carefully, then use some hot/warm water to the drain area with a baster or something to apply and remove the water until it thaws and the drain clears of ice. Its about a 15 to 20 min. job. good luck.
May 07, 2009 | Refrigerators
Need a water filter for my ice maker
you can go to any appliances parts store and get an in line filter it in stalls in the incoming water line before it screws on the water valves comes with instructions if you get the kit
Jan 14, 2008 | Admiral 26 cu. ft. Side-By-Side...
Admiral Ice maker water filter, which one?
I have an admiral HMG19149 refrgerator with an ice maker. my problem is that the ice tast horable and cant be used. I looked for a filter to change but can't find it. Please help
Leak
Is there ice build up under the bottom basket in the freezer??
sounds like the defrost drain is frozen up. especially since your cleaning up once or twice a day. simply defrost the drain and flush the drain line with warm water. you will likely have to remove the freezer cover inside the freezer compartment to do this.
if there is no ice build up under the baskets then its likely there is a leak in the water line for your water dispenser line that runs in the door. if thats teh case you will most likely need a service company to fix it for you..
Dec 19, 2007 | Admiral 26 cu. ft. Side-By-Side...
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
701 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
