Question about Ricoh Aficio SP 3410SF Laser Multifunction MonochromeDesktop Scanner Copier Fax Printer
Service call sc547 error
This error display at the first time , so printing , xerox can not be process how can solve this problem
2 Suggested Answers
drichards
  • 87 Answers
SOURCE: SC547
Press clear modes, 1, 0, 7, and press and hold the clear/stop key. Enter copy sp. Select mode (5), and scroll to 5810 if it exists, and execute. exit back to the copy sp screen. Press data log (7), and scroll to 7807, and execure. Exit all the way back out to the SC547 screen. Turn the power switch off and on. Not the button on the control panel, but the actual switch. If it comes to ready, great, if not, there is somethong wrong with the fuser.
Posted on Apr 25, 2008
Tip
Xerox system error
If you are using a Xerox printer, you might have faced a system error problem, similar to "System error 09.038.46:113334" or something within that line.
I faced a similar error message like this a few months ago and i solved it using the following steps.
The ink count sensor flags were stuck.
Verify that the ink is correct and genuine and then reset the system and error message by performing the following steps:
1- Turn on the printer
2- Wait for the xerox logo to begin moving across the display
3- Before the logo is centered on the display (stops moving) press and hold the "back" and "help" buttons on the control panel.
4- Hold both buttons until the display reads "beginning service mode initialization".Release the buttons and the printer reboots into service mode with the "Service Diagnostics" menu displayed
5- Then scroll until you find function menu then click "OK"
6- Scroll until you find "Clear ISC" fault and press "OK"
7- Click back several times and then reboot the machine.
If you follow these exact steps your problem should be solved.
Thank you for using Fixya,
Kenneth.
on Apr 07, 2010 | Office Equipment & Supplies
Xerox error code
Try this:
Enter Service mode:
1. On the Control Panel, press the Down Arrow button to select
Troubleshooting and then press OK.
2. Press the Down Arrow button to select Service Tools, and then press
OK.
3. While pressing and holding down the Up Arrow button, press the Down
Arrow button to display the Hidden Service Menu.
Select Reset Error Log
Reboot the machine? Yes
Wait for about 15 min.
Should be all right after that.
Last time did work just fine for me!
If don't work mail me at:
innovaprinters@hotmail.com or
impressaodigital.poa@hotmail.com
And we try something else.
Jul 22, 2014 | Xerox Corporation Xerox ColorQube 8570DT...
Eror code 093-555
Get in touch with the friendly Xerox Engineer, I think I remember this error code being the Cyan print head is not performing as it should. A bad batch of Cyan was allowed onto the market a lot time back and the plumbing and print heads became bunged up, due to crystallisation within the hot wax.
Hope you have a service contract!
Good Luck.
Mar 12, 2014 | Xerox Corporation ColorQube CQ9302 9302/P...
Help with error code SC547-01
sc 547 mean fixing unit error ,you can reset by simply getting into simulation mode and then switch off an the machine ,getting into the simulation mode is simply by pressing 107 and press and hold c ,
Jun 19, 2013 | Ricoh Aficio 450 Copier
Xerox 560 error code 127-212
Error Codes
If an error caused the printing to end abnormally or a malfunction occurred in the printer, then an error message code (***-***) is displayed.
If an error code not described in the following tables is displayed, or the problem persists even after you have tried the following solutions, contact the Customer Support Center.
Tip
If an error code is displayed, all print data of the printer as well as print data stored in the built-in memory of the machine is discarded.
Error Code: 127-212
Error Category: Print; Other Problems
Cause: Detected an internal print check error by the FreeFlow
Print Services Controller.
Remedy: Remove and reinsert the command/video cable between the FreeFlow Print Services Controller and the printer. Power off and on both the printer and the FreeFlow Print Services Controller. If the problem persists, call the Customer Support Center.
*** extracted from my Fuji Xerox Color 560 Printer - Printing Systems User Guide
*** I assume we have the same printer
Jul 13, 2012 | Lenovo ThickCentre M58p Desktop 7479A3U
Xerox Phaser 8860 says "Maintainance Kit is Missing"
Most likely it needs service. Here is the service provider finder from Xerox.
Aug 24, 2009 | Xerox Phaser 8500/DN Printer
Xerox c2424 error code
the error code is "printhead stuck in the tilted position or not tilting properly over the CAM, due to problems with the process motor gearbox" the 6375 is your print count, are you under warranty still by xerox?
-Carl, please let me know if this helps.
Jun 20, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox 8500 Error 07,101.43:20955
That has to do with the process drive gear box. May be mis timed or a gear broken.
Apr 11, 2008 | Xerox Phaser 8500/DN Printer
Ricoh Aficio SP 3410SF Laser Multifunction  MonochromeDesktop  Scanner Copier Fax Printer Logo
54 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
