Question about Canon PIXMA MP780 All-In-One InkJet Printer
Photo's print with lines through them
When I print a photo there are two tone horizontal lines that run through the picture.
When I do a nozzle check, the 3eBK looks fine, but then all the rest of the colors are half solid dark and half solid light of their color. The wording is half black and half pinky/red.
  • cheme1232003 Dec 24, 2008
    Hi, when I turn on my printer mp780, alarm go off and noise is cracking from the bottom tray feeder. I checked tray, no paper stuck on the feeder, press reset and ok, then alarm went off again, it is still does not work. It was respond except flashing light "Alarm, check printer". I took out the cover at both sides and don't know what to do next.
  • xxlithxx Dec 26, 2008
    When I print photos there are bars running through the photo or greeting card picture. Regular black printings are pinkish. We have run nozzle cleanings etc. and nothing has changed but continually has become pale to the point of near disappearance and is pinkish in color. Color printing is pale and pinkish with bars through photos.
  • 33 Answers
Useually if your printing has lines through it it means that the head (where the ink comes out ) is had it & your up for another head. Sorry but useally big bucks I hope it's still under warranty
Posted on Oct 27, 2008
Black banding 1280
Do nozzle check. Is it perfect? If only one or two nozzle missing, it must be "good result" in photo quality mode printing. But if, there is too much nozzle missing, result is no good. If nozzle check is perfect, but the result is not satisfied, check the PF scale and PF scale sensor.
Jan 26, 2013 | Epson Stylus Photo 1280 InkJet Printer
Lines in photo
If you have white horizontal lines in your prints then most likely you have some blocked print head nozzles.
Inkjet printers need to be used frequently to prevent blocked print head nozzles. You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required.
A new print head maybe expensive and it maybe more cost effective to purchase a new printer.
Oct 21, 2012 | Epson Stylus Photo R1900 InkJet Printer
Lots of tiny white horizontal lines on the printed picture.
Run a nozzle check. If there are gaps do head cleaning. When printing pictures it best to set the setting to best photo to get good print outs.
Goodluck.
Jul 15, 2010 | Epson Stylus Photo 1290 InkJet Printer
Horizontal lines in photos
Do head cleaning. Print at best photo quality.
May 04, 2010 | Epson Stylus 1400 InkJet Photo Printer
When printing photos, several horizontal lines lines appear. How can I remove/prevent them?
It must the nozzle check is not perfect. Check nozzle and do head cleaning procedure. If there is just little nozzle clog ( 1 - 2 lines missing), you can get good result with best photo/photo rpm setting.
Jul 23, 2009 | Epson Stylus R380 InkJet Photo Printer
Epson Stylus r220 prints with white lines... i installed a CIS and it worked fine for about 6 months, now i'm getting prints with white lines (or fine spots) i tried nozzle check, which comes out good......
Nozzle check must perfect for perfect output. There are tranversal lines at vertical straight lines that represent same point of head micro piezo. If tranversal lines no clog at all, but vertical straight lines not perfectly straight, the result not good (like horizontal white banding). Check it? Head aligment is for vertical banding. If your result is horizontal banding, you don't need to realign head. It's caused by some residual at the output of head sprayer. So, the spray of ink not straight to paper. Try to print with photo/best photo.
Jul 18, 2009 | Epson Stylus Photo R220 InkJet Printer
Epson Stylus Photo R340 Faces in photo are printing day-glo green
Possible printhead or driver issue.
Are you using Adobe photoshop? Please try to print also using a different application to isolate the issue.
Make sure that you are using correct epson cartridges.
Please print a nozzle check pattern. If you see gaps, missing colors or missing lines on the pattern, clean the printhead using the driver.
If the nozzle check pattern printed out successfully, please trash and re-install the drivers. The driver is available on epson.com
Apr 29, 2009 | Epson Stylus Photo R340 InkJet Printer
Printing lines across the picture
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Overview&oid=90584
Q: How can I tell if the computer or the printer is causing a print quality problem? A: You can print a nozzle check pattern to determine whether the print quality problem is caused by the Epson Stylus Photo RX680 Series or some other source.
Above under FAQ
Dec 10, 2008 | Epson Stylus RX680 Color All-in-One InkJet...
Epson stylus photo R2400
I had this trouble, went through cleaning & realignment, then various print options. What i found was that dark colours had faint dark horizontal lines 5mm apart when printing on Photo in the epson driver. Changing it to Best Photo solved it.
Jul 31, 2008 | Epson Stylus Photo R2400 InkJet Printer
Epson Photo R265 Lines every 2.5 cm
check if those lines matches the positions of the rollers inside the printer - you can see some of them by opening the cover
Dec 24, 2007 | Epson Stylus Photo R340 InkJet Printer
Canon PIXMA MP780 All-In-One InkJet Printer Logo
377 people viewed this question
old marine
old marine
