Question about Refrigerators
Beaumark refrigerator model 31396-1 clogged drain pipe.How to access the drain pipe?
docjohn174
  • 943 Answers
SOURCE: CLOG DRAIN FOR REFRIGERATOR
Hi, thanks for the question. these new ,or older fridges have the drain tube, between the walls of the fridge , and what happens is the water in that drain tube freezes. so the water in the defrost cycle ,cant go down to the drain pan. to repair fridge must be turned off. for at least 24 hrs. insert a small plastic tube, from the drain tray up to the freezer, an blow up the tube to clear. thanks the appliance doc. please rate my answer thanks..
Posted on Oct 08, 2008
  • 93 Answers
SOURCE: Water accumulates inside the refrigerator, Kenmore, Mod. 71194100
You get to it from the freezer. Remove the back wall in the freezer and you will see it there. Unclog it with some wire or check to see if it has ice over it.
Posted on Sep 14, 2009
heatman101
  • 43501 Answers
SOURCE: I have an amana abb2522feb bottom freezer
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 11, 2010
  • 4793 Answers
SOURCE: model LRTX18311WW Water on the bottom
i use a basting syringe filled with clorine bleach..........works for me.
Posted on Jan 23, 2011
  • 5370 Answers
SOURCE: Refrigerator top freezer model with
Click this link below:---
http://technoanswers.blogspot.com/2011/06/where-is-defrost-drain-tube-located-on.html --------- This should help.thanks.Helpmech.
Posted on Jun 20, 2011
DRAIN PIPE CLOGGED
hi Calculas.
A few different methods can clear the drain pipe of debris and get it back to draining water the way it was designed to.
  • Locate your drain behind or under the washing machine and detach the tubing or pipe to access the actual drain. ...
  • Clean out any blockage inside the pipe with a plumber's snake
  • try this link for more info on this matter.
How to Fix Clogged Laundry Drain
Dec 12, 2017 | Washing Machines
Water leaks from out of refrigerator.
Hello
Check the drain hole. It gets clogged with food particles:
Locate the drain tubes at the rear of the refrigerator
Push a pipe cleaner through the tubes.
Pour a mild solution of soapy water and ammonia down the drain to clean it.
Check the drain pan under the refrigerator, on the left side, by removing the front grill
If the soapy water hasn't drained into it, it is still clogged
Repeat the steps again until the water drains into the pan
Jun 04, 2015 | Refrigerators
I have an amana abb2522feb bottom freezer refrigerator and need to access the drain pipe. How do I access this? The problem seems to be the drain line is clogged because we get a pool of water about...
heatman101
Sep 10, 2010 | Amana ARB9059CS Bottom Freezer...
Water in bottom of refrigerator
Firs make sure that the drain exit in ur fridge and its receptacle are clear
Oct 26, 2009 | Refrigerators
What is error 002 on Beaumark Dishwasher BM-DW 9702-SS
Error 2 = Longer Draining Time. The installation of the Drain Pipe is too high.
Apr 21, 2009 | Dishwashers
Ice maker has a clog
Unplug refrigerator first and then try defrosting the pipe or remove the blockage. I think most times water freezes in pipe diverting the flow. Let me know what you find blocking flow. Also need the complete model number, Thanks, Sea Breeze
Mar 24, 2009 | GE GSH25JFR Side by Side Refrigerator
Refrigerators Logo
66 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
