Question about Tomtom GO 300 GPS Receiver
Splash screen froze
When i turn my tomtom on it does not get past the splash screen and will not turn off by the on/off button.The only way to get rid of this is to reset it. I recently downloaded a new voice for it and this problem occured after the download.I have erased the new voice from my sd card but i still have the problem.Has anyone encountered this problem before?
  • Anonymous Jan 19, 2009
    not working
I HAVE A TOM TOM ONE OF THE FIRST ITS A (4D00.001) GO
IT DOES THE STRANGEST THINGS THE VOLUME CONTROL WILL START TO MOVE BACK & FORTH ON THE SCREEN;#
& THEN THE THEN THE POINTER WILL START TO MOVE ON THE MAP THEN IT WILL SCROLL TO THEN NEXT MENU ,
YOU YOU GO BACK TO THE MAP & THEN IT WILL SCROLL AGAIN. ITS LIKE THERES SOMETHING TOUCHING THE SCREEN
PLEASE CAN YOU HELP
Posted on Apr 24, 2008
I had the same problem. The problem is with the ad card not the unit. If you made a copy of the sd card before you altered it delete the card and reload it with the back up info.
Posted on Nov 22, 2006
TomTom Boot up problem
i think u need to upgrade the software
Jun 09, 2008 | Tomtom GO 700 GPS Receiver
Tomtom ONE XL doesnt go past start up screen
You may want to try operating your TomTom from TomTom Home. This has seemed to work for a lot of people who do not have backups, as you are connected to their site. Apparently, a file or two are updated, and you are back in business. Here's an example:
"Though not using a 720 my 500 wouldn't startup after upgrade to 7.16. Always stuck on the first splash screen.
After conncting to Home I chose Operate my Go and another file was downloaded. After this the device would boot up norammly when not connected to my PC.
Might be worth a try."
Jan 26, 2009 | Tomtom ONE GPS Receiver
Start up screen
I had this same issue on my 930. You need to edit the bitmap with paint and make sure the dimensions are the exact same as the splash file. Rename the new splash screen with the same filename for the old startup screen and delete the old. That should fix it
Jan 04, 2009 | Tomtom One XL GPS Receiver
Frozen tomtom
You can get your original splash scren from here. You can also download free splash screens created by user through TomTom HOME.
To correct your device, try:
1. Hit the reset button on the back of the device - inside the serial connector.
2. Make sure the device is off and connect it to your computer via USB dock and connect the charging cable (green light should be on)
3. Hold down the power button until the device restarts.
4. The device should automatically connect to your computer.
5. Run TomTom HOME and check for any updates.
6. If there is no new application, try: www.tomtom.com/9091 <-- that will show you how to remove and then reinstall the application.
Dec 22, 2008 | Tomtom GO 510 GPS Receiver
Frozen
Hook the Tomtom using the USB cable to your computer4.gif. You should see the Tomtom drive under My Computer as a drive letter.
Backup1.gif all data1.gif from the Tomtom to a folder on your computer. Now select the Tomtom drive and right click, select properties, select tools, and then Check now. Allow the computer to fix any problems with the Tomtom drive. Once this is completed. Remove the USB cable and do a reset. Now turn on your Tomtom and it should work.
Jan 04, 2008 | Tomtom GO 910 GPS Receiver
Tom tom go 910 issue
press the on button then hold the on button the press the reset button, the screen sould flash white, once this is done connect the tomtom to the pc and turn it on then update it via tomtom home
Dec 13, 2007 | Tomtom GO 910 GPS Receiver
GPS Won't Turn On
I suggest any unit under warranty to be returned to its supplier or if they will not help, contact tomtom directly!
http://www.tomtom.com/support/index.php?Lid=1
Download the latest updates from tomtom.
Dec 03, 2007 | Tomtom GO 300 GPS Receiver
Frozen tomtom
Is there a reset button? See this from PocketGPSworld.com: Reset hole The Reset hole is hard to find, you need to first remove it from the mount, turn it upside down, and within the mounting base area of GO you will see two interface slots (currently only one is being used) and towards the front of the unit on the base you will see a little hole marked reset. This is just like soft resetting a Palm or Pocket PC, it requires something small like a paperclip, and nothing was supplied with GO to enable you to easily reset the device.
Feb 25, 2007 | Tomtom GO 510 GPS Receiver
Frozen tomtom
Try the reset button on the hole in the bottom of the unit. I had a frozen unit after attempting to upgrade and this made it work. Use a paperclip to press into the hole, it will reset the unit.
Feb 25, 2007 | Tomtom GO 300 GPS Receiver
Tomtom GO 300 GPS Receiver Logo
238 people viewed this question
Top Tomtom GPS Experts
k24674
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
