Question about Mantis 4-Cycle Tiller
Does not work on high RPM
I have 4 stroke Mantis. After 20 min of normal work it stops at high RPM and works on very low RPM. I clean the blades, and it happens even when blades are in the air.
I change fuel with the new one. Same thing. Please give me an idea what to do. It is under warranty and only 8 hours of job, and i already change an oil.
    Problem Solver:
  • 8 Answers
Sounds like its over heating. be sure all cooling fins on engine are free of debris. your carbeurator may also be running to lean which will cause over heating.
Posted on Nov 16, 2008
2002 jeep liberty heat only works at high rpm
Sounds like low flow issue. Flush and clean system, PROPERLY! Buy a flush kit, drain system, blow compressed air through, fill with cleaner/water mix, run for 30 min with heat on, drain system, blow out with compressed air, fill with water, run for 30 min, drain, blow out with compressed air, fill with 60% coolant mix.
Nov 26, 2013 | 2002 Jeep Liberty
2 stroke Mantis Tiller 1) Very difficult starting, when started, high rev works, but 2) Engine dies on deceleration. Carburetor is signed C1U K4589A. The priming pump does not suction, gasoline...
Hi there is a small stone fuel filter in the tank. this filter stops fuel from running back into the tank from the carb check to insure it still on and make sure there are no cracks or hole in fuel line that should fix your problem
Aug 31, 2011 | Mantis 2-Cycle Tiller
Im looking for a spark plug wirng diagram for a 1966 corette 427
1966 - 1969 with 4 Barrel Carb (L36)
(Low Compression Model)
Max Brake Horsepower - 390 @ 5200 rpm
Max Torque - 470 @ 3600 rpm
Stroke - 3.76
Bore - 4.251
Compression - 10.25
Firing Order - 18436572
1966 with 4 Barrel Carb (L72)
(High Compression Model)
Max Brake Horsepower - 425 @ 5600 rpm
Max Torque - 460 @ 4000 rpm
Stroke - 3.76
Bore - 4.251
Compression - 11.0
283, 327, 396, 409 and 427 CID Engine 1965-1966
Firing Order 1-8-4-3-6-5-7-2
350 CID Engine 1969-1974 Corvette, 427 CID Engine 1969 Corvette
Hope this helps (remember to rate this answer)
Jun 15, 2011 | Chevrolet Corvette Cars & Trucks
How many miledge will give yamaha r125?
Hi, Depending your driving style, but normally the mileage of this bike will (15-20) KM/L.
Please see below for more detail: TECHNICAL SPECIFICATION :
ENGINE : LIQUID COOLED 4 STROKE SOHC
CC : 124.66
BHP :15 PS @ 9000 rpm
TORQUE :12.24 Nm @ 8000 rpm
GEAR : 6 SPEED
COMPRESSION RATIO :11.2:1
BORE X STROKE :52 x 58.6MM
LUBRICATION SYSTEM :WET SUMP
IGNITION SYSTEM :TCI
STARTER : ELECTRIC ONLY.
WHEEL BASE:1355 mm
FRONT TYRE :100/80-17
REAR TYRE :130/70 -17
LENGTH :2015 mm
WIDTH:660 mm
HEIGHT :970 mm
FUEL TANK CAPACITY :13.8 LTS
MILEAGE : 15-20 kmpl
Dec 08, 2010 | 2008 Yamaha YZF-R125
Mantis tiller rpms shoot way high with slight increase in throttl
It is leaking air into the intake somewhere or
the rings are shot
the crank seal is shot
the crankcase gasket leaks.
Jun 08, 2010 | Mantis 2-Cycle Tiller
Headlight issue on a 99 Audi A4 1.8T
Your headlight switch has overheated and failed. It's common. The switch is $158 new and replacement requires airbag and steering wheel removal.
Apr 20, 2010 | 1999 Audi A4
Mantis 2-strke cultivator,split pins Australia
contact southern supply
company at 205-833-2525 or email them at
southern.supply@mindspring.com and I feel sure Jason or
someone there can help you.
Sep 13, 2009 | Mantis Little Wonder Tiller/Cultivator...
Mantis to stroke start not very easy once it starts use for five minutes then it stops and doesn't start again I bought this from the ebay in February 2009 and I paid under £175 when I bought it the person...
either the choke is still on
or
the air filter is so dirty that it is acting like a choke
either way, replace your spark plug and air filter
if your air filter is foam, you can clean it in gasoline, just be sure to air dry it before refitting it and tring to run the mantis
the carburator can be dirty and or having the screws out of adjustment.
thy the spark plug and airfilter first
Apr 01, 2009 | Mantis Electric Mini Tiller/Cultivator
Mantis tiller sv-4 echo engine: no spark from coil
There are only 4 parts to the 2-stroke Mantis ignition system: the spark plug, the "kill button", the flywheel with embedded magnets, and the coil with integral plug wire. There are no "points" to clean or refurbish. If you've tried a new spark plug, unplugged the wire leading up the handlebars, and the magnets on the side of the flywheel are strong enough to attract a screw driver blade, then it must be a bad coil. That's all it could be. End of story.
Cruising the internet I see where these Echo coils go bad all the time. You can order the coil, but if the machine hasn't run in several years the carb will also need cleaning. So one thing leads to another. The gear box grease also needs replacing each year. What I'm trying to tell you is these are disposable tillers and due to length of time, incomplete care/ storage, ....whatever, this one's time is up.
Sorry.
Feb 26, 2009 | Mantis 2-Cycle Tiller
Mantis 4-Cycle Tiller Logo
262 people viewed this question
Top Mantis Garden Experts
paulfvincent
Matt Olenzek
Matt Olenzek
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
