Question about OKI C5800Ldn Led Printer
OKI C5800 color problems
My printer for some reason stopped printing anything orange.. the yellow and red print just fine but when you try to print orange it comes out red.. any tips or advice would be most appreciated.
- Marco
Open the top cover. using a clean soft paper towel clean each othe glass vanes that hang down between the drums that are attached to the top cover. I use Alcohol, and a different paper towel for each vane.
Posted on Nov 10, 2008
Printer will not print yellow or orange, but prints other colors correctly. Brand new lexmark cartridge.
Yellow is one of the printer's "primary" colours.
Orange is mix of "red" and "yellow".
So, an empty "yellow" cartridge, or clogged ink-jets would cause your symptoms.
Sep 17, 2010 | Lexmark Z705 Photo Jetprinter InkJet
Colors are not printing the acutal color
It all depends on the meaning of 'not properly'.
Try creating a document with four different squares, or words, of these colours: yellow, magenta, cyan and black. If all of them print (albeit not with the correct shades) it is probably an ICM driver error. But my guess is that only one of those four colors will print badly, due to a defective color cartridge.
The OKI 5150 makes all perceivable colours using cyan, magenta, yellow and black toners, so if one of these malfunctions, the resulting colors will lack the required shade of, say, yellow, and will appear to be "wrong". The yellow colour itself, of course, would simply disappear (the "yellow" you use might actually be 95% yellow and 5% cyan; then the "yellow" square will be printed as a very light shade of cyan, while the other colors - say, 95% magenta and 5% yellow - will turn out almost exact).
Try with the color test and replace any failing cartridge; if all four (almost) pure colours do print incorrectly, it's unlikely to be a cartridge problem, and we'll have to dig deeper.
Sep 09, 2009 | OKI C5150n Led Printer
The cartridsge printe red and blue fine. No yellow
The print head for the yellow color may be clogged. Check the manual to see how to turn on your print head's cleaning system. Run it until the yellow starts to print properly. If after running the cycle 4 or 5 times you still can't get any yellow to print you will probably have to take the printer to your local repair depot to have them diagnose the problem.
Jul 11, 2009 | Office Equipment & Supplies
Incorect line of colour from one edge to the other
I am presuming the rest of the page prints the correct colour and this is an area in the direction of feed that is missing yellow. Try swapping the yellow and magenta drum positions and then the green text should come out a very dark blue colour. if it does then the fault is with the YELLOW drum, if there is still a noticeable Cyan stripe still then the fault will be with the LED head or engine control board.
Apr 21, 2009 | OKI C5100n Laser Printer
HP 6110 swaping colors
this should be problem with u r Printer Firmware ..u need to update it .plsase use below link for Software & drivers of 6110 printer
frist u select correct OS witch used for u r Pc
then in frimware option download "Firmware update for the hp OfficeJet 6100 series" if u want any update for u r printer get it form this link.
if this information is useful for u Please Rate me......
Jun 08, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Oki c5100n printing yellow color offset
What is the stats % of drums if low under 50% change them, soon as you add non Gen you throw a spanner in any attempt to fault find, fix is possible toner more than likely drum/drums, do a print of each colour and change drums as indicated by failure in its colour to print, check transport belt is OK and led heads are clean
Nov 13, 2007 | OKI C5100n Laser Printer
OKI C5100 only printing cyan
I need to know if the test page that the unit prints as "Demo Page" comes out fine. If this is the case, your problem is within your application (software) or computer connection (check all cables). If this is NOT the case, I'll need to know more about your scenario. Operating system, type of connection (USB, parallel) and what are you trying to print. I'll be waiting.
Sep 27, 2007 | OKI C5100n Laser Printer
OKI C5800Ldn Led Printer Logo
268 people viewed this question
Top OKI Office Equipment & Supplies Experts
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
