Question about Xerox Phaser 6140v_n Blk18/colour20 Pp - XEROX & VISIONEER - 6140V_N Laser Printer
Stuck toner xerox phaser 6140
The cyan cartridge of my xerox printer is finished but I can not remove it. It is stuck. Has anyone experienced the same problem? It is not a xerox cartridge btw.
I am sorry I can not help you. I am having the same problem with a magenta cartridge (also non Xerox)I tried disassembling but I could not find my way. For the time being I am printing B&W .
the other replies are not very relevant I am afraid.
Posted on Oct 23, 2012
  • 7 Answers
SOURCE: Magenta Ink cartridge is stuck in Xerox Phaser 8550/8560
09,03x
35 = Cyan
36 = Magenta
37 = Yellow
38 = Black
The error indicates an ink stick was jammed. You have to clear the ISC (ink stick count) error.
Turn off the printer.
Turn on the printer.
As soon as you see XEROX start moving across the display hold down the back and help buttons until you see "beginning service mode" on the display.
Release the buttons, it will now come up in the service mode.
Scroll down to the function menu, hit ok, scoll to clear isc fault, hit ok.
Hit the back button to get back to the first menu then exit diagnostics, hit ok when it asks if you want to restart in customer mode.
Posted on Jun 10, 2009
ikechinedu
  • 184 Answers
SOURCE: Invalid Black Toner Xerox Phaser 6110 MFP
reload the driver again and if it persists, change the toner
Posted on Jun 23, 2009
jaggujoshi
  • 119 Answers
SOURCE: i have refilled the xerox phaser toner it is
Dear,
Is there any chip identifier for that toner. If there you have to change the chip. Otherwise yiu refilled wrong toner posder for that toner.
Cheers
Jaggu
Posted on Oct 18, 2009
nakshatraipu
  • 241 Answers
SOURCE: Hello, how to reset toner cartridge for xerox
Through Module we can resetted Xerox 3100 permanently.
www.nakshatraworld.com
Posted on Dec 31, 2009
SOURCE: need solutons for xerox phaser
need solutons for xerox phaser 3100 after refill message toner empty. how to reset and usr this cartridge
Posted on Mar 26, 2010
Xerox phaser 6140
Hi Anonymous,
I suspect you should have this problem sorted by now.
Looking at the Xerox website says that a replacement printer is available for around £190 that could have worked out cheaper that trying to get this one repaired.
Replacement Xerox 6500
Good Luck.
Jun 17, 2014 | Xerox Phaser Office Equipment & Supplies
Replace drum in xerox phaser
asic technical parameters forToner cartridge chip of Xerox Phaser 3450B:
chip-b.jpg" ]
Version: No area limited
Yield: 5,000-10,000.
Printers Model compatible: Xerox Phaser 3450B
Toner cartridge Model: Xerox 106R00687-BK and Xerox 106R00688-BK.
Manufacturer regulations pages yield ofToner cartridge chip for Xerox Phaser 3450Bis 5,000-10,000 then printer do not print andDrum chip for Xerox Phaser 3450Bhas mission paper pages count.You should resetDrum chip for Xerox Phaser 3450Bcaused by following reasons:
And then, you can choose one in three following plans: replace Toner cartridge, replace Drum chip or reset Toner cartridge chip.
1.Replace new Toner cartridge for Xerox Phaser 3450B:
- If you choose plan replace Toner cartridge then cost is too high. Each Toner cartridge for Xerox Phaser 3450B (Xerox 106R00687-BK and Xerox 106R00688-BK Toner cartridge) costs about $150 - $200
- With replace new Toner cartridge solution is not optimal, because the price is quite expensive.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new unit.
2.Replace new Toner cartridge chip for Xerox Phaser 3450B :
khe-chip-b.jpg" ]
- If you choose plan replace Drum chip then cost higher than reset chip. EachToner cartridge chip for Xerox Phaser 3450Bcosts about $6 - $10/color.
- With replace new Toner cartridge chip solution is cheaper replace new Toner cartridge.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new Toner cartridge chip.
3. Reset Toner cartridge chip for Xerox Phaser 3450B
If you choose plan resetToner cartridge chip for Xerox Phaser 3450Bthen that is best plan. It cheaper than replace Toner cartridge or replace Drum chip
The phenomenonToner cartridge chip for Xerox Phaser 3450Bout of count are printer do not print and display error on the LCD monitor:
-"Drum low", "Drum eppty", on monitor laptop or desktop appear yellow exclamation mark corresponding color, on monitor printer report Drum empty.
-"Tone life end", "Replace new unit"
- "The x unit an error". In that "x" is color of Toner cartridge or code of Toner cartridge
How to fix the errors:"Drum low", "Drum eppty", on monitor appear yellow exclamation mark corresponding color,"Tone life end", "Replace new unit", "The x unit an error"? cheaper, the most effective.
We use unismart device toreset Drum chip for Xerox Phaser 3450B
Unismart is a device reset Drum chip. Unismart can reset for many Drum chip of manufacturers: Samsung, Hp, Canon, Epson, OKI, Xerox ...
Unismart system is designed to offer a complete solution for writing, resetting, testing various chips with the combination of Unismart Box and Unismart chips. Unismart include: unismart box and test head, power adapter, Data wire, flat writer.
unismart1.jpg" ]
Test head is used for data transmission between Unismart Box and Unismart chips. There are 20 types of test heads designed according to different chip shape, which can be used for operation on all chip models that
current Unismart system supports. Please choose the right test head in accordance with the PCB code. Some PCBs share a same test head, which is clearly indicated in the chip compatible list.
In Case You Still Having Problem Then Follow Us For On :Xerox Printer Support
Jan 23, 2014 | Xerox Phaser® 860, 8200 Standard Capacity...
I have a xerox phaser 6280, i keep getting this message say i need to " Check Cyan " cartridge. but its a brand new cartridge, its full of ink. can you please tell me how to fix this issue.
Remove the cyan ink cartridge and shake it. Be careful not to spill any toner. If that does not solve the problem it is most likely a dirty sensor. What I usually do is remove all toner cartridges and blow out the inside with an air compressor. Be very careful when doing this and try to use very low pressure so that nothing gets damaged.
May 19, 2011 | Office Equipment & Supplies
I have a Xerox phaser 7300 that keeps telling me to install or reseat the black cartridge
It is slightly unusual for it to be the black toner cartridge (usually cyan or magenta) but this issue is quite common on the 7300. You can find a lot of information about this here.
Dec 15, 2010 | Xerox Phaser 7300DN Laser Printer
What is error code 941 on a Xerox Phaser 7400?
www.support.xerox.com -phaser 7400- support -fault code-941 says cyan or magenta toner failure, but the solution says to
1. remove & reinsert the cyan or magenta imaging units.
2. replace imaging units .
check out the site to see if helpful
Jul 01, 2010 | Xerox Phaser 7400DN Laser Printer
We have a Phaser 7400. It continues to give us
If you've already changed out the toner cartridge and the problem persists, then it could be several other parts that are either defective, dirty or blocked.
You may want to contact a certified Xerox technician and have them look at the Imaging Unit Agitator Bar and the Low Toner Sensors for Cyan/Magenta. There could also be a faulty toner supply motor.
Sep 10, 2009 | Xerox Phaser 7400/DT Laser Printer
After removing toner cartridges error display said replace various colour toners.
it is not according to your printer or your head of cartige is not clean or damage. try replace new one
May 09, 2009 | Xerox Phaser 6100/BD Laser Printer
004-354 cyan atc sensor failure
Hi mgordonO:
The problem is with the toner cartridge or the developer. One or both may be empty.
Apr 08, 2009 | Xerox Phaser™ 7760/DX Laser Printer
09,03x
35 = Cyan
36 = Magenta
37 = Yellow
38 = Black
Mar 31, 2009 | Xerox Phaser 8560MFP Laser Printer
Cyan is not working or printed over pages
Hi, Have you checked your cyan imaging unit?
R
Jun 18, 2008 | Xerox Phaser 7760/YDX Laser Printer
Xerox Phaser 6140v_n Blk18/colour20 Pp - XEROX & VISIONEER - 6140V_N Laser Printer Logo
505 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
