Question about Pool & Spa
Hotsprings Prodigy Spa
After refilling the spa the 220 GFCI keeps tripping so the heater will not operate
    Scholar:
  • 111 Answers
Assuming there aren't any other faulty electrical components your GFCI will trip as a result of the heater element short circuiting.
Typically this happens when water infiltrates the heater element's protective outer coating and comes in contact with the internal heating coil. The culprit could be corrosion but usually it is a pin sized hole in the element which will lead to a short circuit.
When this happens the element has failed and cannot be repaired it must be replaced.
Posted on Feb 23, 2012
PartsCenter
  • 125 Answers
SOURCE: Spa water drains to pool
Here is a link to the Aqualink website so you can download a trouble shooting guide.
Posted on Feb 26, 2009
SOURCE: SPA Filter on while Spa is Heating
you have one jandy valve ( the suction valve in front of the pump) that is not working right when you press spa mode. have someone watch the valves to see if they move when you press spa mode and heat inside the house. if the one in front of the pump does not move and the switch is in operating mode then that valve is bad and will have to be replaced.
Posted on Aug 06, 2009
  • 5 Answers
SOURCE: I have Jandy RS4 system with 4-button poolside
Pull the cover off the control panel. You will probably find a button which would be accessible from outside the panel with a paper clip or pencil but is unlabeled. On the board itself by the button, in small letters it should say "reset". Push the button and see what happens.
Posted on Oct 09, 2009
rsmith972278
  • 160 Answers
SOURCE: my spa heater is saying the spa is 126 degrees so
Use a thermometer to check the actual temp of the water to see if the units temp probe is accurate. Also what is the max temp allowed by the spas safety program...owners manual.
Thanks,
RSMITH972278
Posted on Oct 12, 2009
SOURCE: I have a spa pac 1100 kw heater it trips the
jkuigjiu9u9uirj9u9jrri89jij9f ijoijog j9j9r hi8h9jrij9jfij9j9dij9jasifj9jifj8ef i8hfh9ufihihfhihd73uurwejhydjjhuynjujjuyvnnydhnhrhhydfhyfhhyrhyyjhhfuhuughurtuguhuerghuhrrguhurhgurgbrguhrrguhrhguherghuhghughfjvnuhuf udfu h8h uhufhuwenuh uh hh unu huwenfui h8ef hwuehfu bufg ubdfuh unuwebf jwbfubu weyfgu huyff uhehfuywehfuyweghufhweufhuwefhuefuefuwefguwefgudfbdbvusfgfudgfugfugsdfsdgfusdusdfusdfsudfg7egrwegfwgefyugydgybefygeyfgywfgygdycgybefygybsyfvwyfbgydvfytyfgefywefy y ge7yfg gyeyf wy yegjhbuvhuvye7fg7egf7g7dg77gd76gwte6t6qge6qt6q6e
Posted on Jan 08, 2010
EasyPak 1000 Flex-Fit Air Spa Control System. Everything works fine, except, when plug in heater power. Gfci trips. When unplut heater power, everything works
GFCI blows because you have a short to ground. Check your wiring for loose connections and your heater core element.
Mike
May 29, 2017 | Pool & Spa
The pump shorts out when heater is put on
Electric spa control?
what do you mean pump shorts out? Are you saying a breaker trips or a GFCI trips?
if so, it has nothing to do with the pump, if it's already running. But once the heater engages and the breaker trips, then you have about heater element.
Mar 28, 2015 | Pool & Spa
My hydroquip 9000 trips the gfci when it starts now. the heater,pump,blower and everything was working fine till the power went out. when the power came on the spa didn't work? there is a reset button on...
If the GFCI is tripping, the reset button will not do anything. If it was fine before the electricity shut off, it is possible that while the pump was not running, water got into the inside of the pack, and that is what is causing the GFCI to trip. An electrical surge may have damaged the GFCI, itself. Those are the two things that might be related to the power going out.
The most common cause for tripping GFCI's are a heater that has a ground fault. A distant second is a bad GFCI. If it starts to run, then quickly trips, it is almost certainly the heater.
Oct 26, 2013 | Pool & Spa
I have a Beachcomber Model 350 hot tub abd the GFCI is tripped and won't reset
You may have a bad heating element. But first make sure you have power to the gfci. (check the braker) You can test this by disconnecting the heater leads and see if it will reset. If it still trips try disconnecting your equipment one at a time, ie. blower, ozone, circ pump, booster pumps. If nothing solves the gfci issue you need to replace the gfci. All of this is assuming you have a blank gfci receptical monted to your spa pack.
If your talking about the 50 amp gfci at the braker box try pushing the braker all the way to the off position then back to the on possition. If it trips right away do the above.
Aug 06, 2013 | Pool & Spa
Why is the gfci tripping on my hot tub after being on for 30 min. After resetting the breaker after the 30 min. run, it trips immediately!!!
You will want to make sure that all of your spa equipment is functioning properly. It is best for a spa technician or electrician to determine this issue.
It is likely that a particular piece of equipment is turning on around the 30 min time frame and causing the breaker to trip. Pump, ozonator or similar. Also check the heater element, a pin sized hole in the element will cause it to fail. Lastly your spas breaker itself could be bad.
Nov 20, 2012 | Pool & Spa
We have a 2004 Balboa series spa and the breaker keeps tripping what could cause this? Everything has been working fine.
Understand that this information is beingprovided as-is and without warranty or guarantee. As with all electricalcomponents and devices, all work should be performed by a licensed spa or pooltechnician. Serious injury or death can occur if a component is improperlyrepaired or installed.
There are several reasons the breaker can trip. It could bea bad pump, bad heater, GFCI or wiring issue.... Typically unplugging eachcomponent will help isolate which component is causing the trip. It is rare fora board to cause a breaker trip, so if all components (including both legs ofthe heater) are disconnected and the breaker continues to trip then you move onto wiring or the GFCI.
You can find answers to common spa or bath problems online at http://www.balboadirect.com/support.aspx
Apr 02, 2011 | Balboa Instruments Duplex Digital Panel 2...
I have a Hotsprings Grandee tub. I drained and
Probably a ground Id check that water did not get into any ele.system
Apr 16, 2010 | Spa Parts Plus GFCI, Circuit Breaker, 30...
My hot tub keeps tripping the breaker and will only stay on for a short period of time before tripping the breaker. What can I do?
Check for a water leak in the electrical areas of your spa... specifically look closely around the heater terminals, look for wet and corroded connections... If this spa is wired to a plug-in outlet, look at the GFCI plug assembly as well... You can also try disconnecting the blower, pump, heater, etc, from the control pack (one at a time) to determine which item is causing the tripping.
Dec 26, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Gfci breaker for spa
gfci's are designed to trip if they receive voltage on there ground/neutral side, therefore my vote is for Smithbrother I would say there is probably a partial short somewhere in you system.
Mar 15, 2009 | Spa Parts Plus GFCI, Circuit Breaker, 30...
Pool & Spa Logo
260 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
