When I try to print something off the computer, it will print only the headlines very well, but you can't see the remaining parts of what you are trying to print. It is very light until you can't read it
    Master:
  • 409 Answers
You are running out of ink
Posted on Oct 25, 2008
Removing headliner
James, Check the attached links,instruction and guides on head liner removal. You can also google search your vehicle.Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Automotive Headliner Removal
Replacing your car headliner in 5 easy steps
How to Install Headliner
Installation Bow type Headliner Part 1 Removal and Preparation
Jul 03, 2016 | Cars & Trucks
I can't close the moonroof on my F350. I got it to the closed position with the back end up and couldn't close from there. The motor is trying but something is broken. I found a small piece (1/4" sq. x...
You will need to remove the entire assembly and find out what is broken, it is real pain in the rear and is very time consuming, about 8 hours hard work, the headliner must come out and that means all the interior trim be removed.
Jun 21, 2017 | 2003 Ford F350 Super Duty DRW SuperCab
Lexmark x1150 wont print text but will print pictures
In this case what i would Request u to do is.........
Goto Control Panel goto Printers folder.........
There u will see the Lexmark Printer Icon...........
Just right click on the Printer Icon and click on Properties.........
Now click on Advanced and goto Print Processor.........
Change it to Lexmark NTEMF 1.0008........
Click on Apply click Ok now try to Print..........
Prints Fine............Issue Resolved........
Same Problem........
Download the Lexmark ToolBar from:
http://www.lexmark.com/lexmark/sequentialem/home/0,6959,204816596_1255995709_0_en,00.html
Restart your computer once and now try to print using the Lexmark Tool Bar..........
It should work fine........
Good Luck..............
Apr 18, 2013 | Lexmark X1150 All-In-One InkJet Printer
I need free support to empty memory of brother HL-2140 printer
This error occurs when your printer is dealing with a particually complicated print job and cannot process it all. Try to reduce the complexity of your document or cut the print resolution. It may be worth trying to print the document in several parts if at all possible.
I hope this helps.
Dec 27, 2012 | Brother HL 2140 Laser Printer
How to remove the headliner and install it
When Your head liner starts to sag or You have another nice headliner You want to use in replacing Your old liner, it is actually a good thing. Removing and installing a new one is also a easy task and does not require any form of technicality to do this. Please get these instruments(Replacement headliner fabric, Spray glue adhesive, Screwdriver, Sandpaper, Scissors) and follow the steps below:
  1. Remove everything that bolts into the headliner like visors, lights and coat hooks. These things are normally bolted to the ceiling through the headliner, making it impossible to remove the headliner with these things in place.
  2. Take down the old headliner. You can grab it through the dome light hole or one of the other holes now showing. Be careful not to rip or bend the headliner. Slowly move it towards the rear of the car. You may have to remove some of the molding along the sides of the headliner.
  3. Carefully take the headliner out through a door of the car. You may have to maneuver the headliner around the seats and steering wheel to get it out of a door. Be careful not to bend the headliner.
  4. Peel the fabric off of the shell of the headliner. It should easily come off by pulling it with your hands. Use some sandpaper to remove any foam that remains on the headliner shell.
  5. Lay the new fabric on the headliner in the correct position. Fold half of it back so the shell is visible.
  6. Spray the adhesive glue on the visible side of the shell and on the underside of the fabric. Allow it to set until it has dried some.
  7. Fold the fabric over slowly onto the shell. Smooth out any wrinkles as you go. Work your way to the outer corners of the shell.
  8. Repeat the gluing procedure for the other half of the shell and fabric. Make sure to smooth out any wrinkles so the fabric doesn't completely dry this way.
  9. Trim the left over fabric to 1/4 of an inch long. This will be hidden behind the molding of the car.
  10. Install the headliner using the opposite steps you took to remove it. Slide it back into place, replace the molding and then the visors, lights and coat hooks
Hope this helped. Thank You for using FixYa!!!
Jan 14, 2011 | Nissan Maxima Cars & Trucks
My Canon printer only prints part of my selections
CHANGE PAGE SETTINGS -> UPPER MARGIN DOWN MARGIN ETC IN PRINTER PROPERTYS
Mar 19, 2010 | Canon PIXMA iP5000 InkJet Photo Printer
My printer will not print the text only the
Driver issue... www.driverguide.com, search model type/# for most recent. Since a drivre is a "translator" for the CPU to the peripheral, this is usually the case.
If it functioned correctly, and now all-of-a-sudden is malfunctioning, I would still try the driver route, and then perhaps do a system restore to a point before the malfunction...
Hope this helps!
-- RT
Sep 03, 2009 | Lexmark Z2300 InkJet Printer
Only headlines of document prints and no black text
First try to nozzle check your printer. For most cases this works best.
Dec 23, 2008 | Canon PIXMA iP90v Printer
Fails to print
if you run it useing the platen, (or copy from on the glass image to image) is it ok or full copy. If it is good, then its a printer ( imean computer) to copier problem. Maybe connection. eliminate the source of the problem first.
Feb 02, 2008 | Office Equipment & Supplies
jasbo
jasbo
