Question about Sanyo Televison & Video
Diagrama esquematico para tv.sanyo mod.ds31590
Solo presenta linea de falla vertical
jomaru
  • 337 Answers
SOURCE: TV Konka modelo K2038U. No enciende.
Muchas televisiones tienen reguladores ,si ese regulador no esta dando lo que tiene que dar hay que cambiarlo,tambien puede haber un corto en la linea y eso esta manteniendo bajo el voltaje,hay que chequiar los filtros(capacitadores).Suerte
Posted on Sep 12, 2006
SOURCE: Sanyo DS31590 and converter box
I just checked the owners manual online. Looks like this model only has an NTSC analog tuner. No ATSC digital tuner built in.
If you use cable or satellite TV services, the digital converters won't help you. The coupon-eligible ones are strictly for use with a traditional antenna. If this is your situation, ignore the remainder of this message.
If you use a regular TV antenna with this TV, then, yes, you will need a converter box. FYI, the Insignia model at Best Buy and the Zenith at Circuit City, and elsewhere (radio shack) have gotten good reviews from early purchasers. More converter box models will be available in a few months time.
If your current reception with your antenna is poor (snowy), you may have problems receiving the new DTV signals. If not, you should be pleasantly surprised with the quality of the DTV signals - and the extra "virtual" channels. Try the converter box using the RCA video and audio inputs, for a slightly better picture than with the coaxial cable inputs.
Good Luck
Posted on Feb 29, 2008
yambo
  • 230 Answers
SOURCE: colores
El chassis de synch, no esta funcionando adecuadamente. Probablemente loose connections around.Si puedes quitar el tunner board y resoldarlo, hazlo; Pero la solucion esta en el chassis donde esta el tuner. Tambien lleva unos panel conectado verticalmenet, esos hacen mucho falsos. resoldalos. Por ahi si tienes dudas escribeme noetvs@embarqmail.com Hechale ganas!!!
Posted on Aug 19, 2008
ladywinn
  • 5138 Answers
SOURCE: Sanyo DS31590 31'' TV DO I NEED CONVERTER BOX?
If you do not have cable or satellite YES you will need converter box anyone and everyone that uses antenna to watch tv needs converter Box.
Posted on Dec 01, 2008
mie999s
  • 105 Answers
SOURCE: my sanyo ds31590 31 has a black picture with a thin white line in
check the voltage at vertical ic must get 24volt dc then replace the IC that all
Posted on Jul 01, 2009
Mi tv mitsubishi presenta falla al momento de ver una entrada ya sea digital ..hdmi o rca se miran rayas purpuras de lado a lado alguien me puede ayudar
Tengo un Mitsubishi 73 inch el prende pero no se ve nada en la pantalla pero se oye despues de 5 minuto prende la bombilla roja y no se ve nada ni se oye
Mar 18, 2014 | Mitsubishi WD-62525 62" Rear Projection...
Rear speakers stopped working on my 2008 Accord
se hace una inspeccion de la linea de los altavoces que no este abierta( cortada) o en su defecto que no se haya averiado la linea de salida de estos revisar probando otro altavoz ajeno al del auto la otra posible falla seria que el fader ya no funcione o hayas desabilitado el sonido para estas busca la opcionn fader y situalo en center o rear para saber si funciona
Mar 12, 2013 | Cars & Trucks
Que significa SRS en el panel de mi mitsubishi mirage 1995
Hola:
EL codigo SRS se refiere al sistema de seguridad del vehiculo (Air Bag System), y aparece cuando se presenta algun codigo de falla en el mismo.
La presencia de un codigo de este tipo no sera eliminada con solo desconectar la bateria durante algunos minutos; necesariamente tendra que llevar el vehiculo a su representante o algun taller que cuente con lector de codigos (scanner) para determinar exactamente que codigo de falla se ha presentado, Solamente con este codigo podriamos ofrecerle mayores detalles.
Suerte.
Jul 10, 2012 | 1995 Mitsubishi Mirage
.necesito un diagrama esquematico para europower MPX 5000
.necesito un diagrama esquematico para europower pmp5000 pmp6000
Jun 29, 2012 | Behringer Europower Pmp5000 Powered Mixer...
Tengo un problema con mi lavadora whirlpool duet cuando la enciendo para lavar me presenta un fallo en la pantalla. y sale fallo 22.que es el swich de la tapa.pero se lo cambie por uno nuebo y sigue...
ke tal tengo una lavadora whilpool duet pero al encenderla y poner el ciclo de lavado normal me prtecenta una falla dice falla 11 y no se que es esta falla me podria orientar?
elrayo_0609@hotmail.com gracias
Feb 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Need vacuum hose routing diagram for 1991 isuzu rodeo
how do i know if it's a vacuum leak in my 1999 isuzu rodeo 2wd 3.2l
Jan 28, 2010 | 1991 Isuzu Rodeo
Mi televisor presenta una falla de el vertical que puedo hacer
hay que revisar los voltajes de alimentacion del ic vertical, tanto de su vcc., como de los voltajes de entrada y retroalimentacion del mismo., verificar tambien si el ic. tiene algo de temperatura esto nos da la certeza que se encuentra trabajando., sino es que esta abierto dicho componente, ademàs de esto hay que verificar si la data y clock del ic. de la jungla estan presente porque si uno de ellos esta ausente, el tv encendera y presentara como falla vertical.
Mar 03, 2009 | Toshiba TP55G60 55" Rear Projection...
Nececito diagrama
tienes que dar mas informacion del tipo o marca del televisor pero si quieres intentar por ti mismo solo ve a la pagina de la compania que la fabrico y ve a soppporte manuales y diagramas ahi puedes encontrar lo que buscas es igual para todo tipo de aparato solo busca la pagina del fabricante
Nov 13, 2007 | Astar LTV2001 Television
Sep 06, 2006 | Konka K1369U 13" TV
Televison & Video Logo
42 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
