MXR 114 Ten Band Graphic Equalizer
Operators manual
3 Suggested Answers
  • 7 Answers
SOURCE: Hi I would like to know how to wire up a kam keq
Either run the main ouptut for your amp to the input of the eq and output of the eq to the main input of your amp OR use one of your tape monitors on your amp. Record on your amp goes to eq input and play on your amp goes to eq output. Hope this helps you.
Posted on Jul 30, 2009
  • 32 Answers
SOURCE: The settings on my Peavey Q215FX dual 15 band
Assuming that you eq is installed in your system correctly add a source like a cd of the type of music you will be putting through the system. Now starting at 0 on all frequencies adjust to your liking. Try to avoid going above 0 as much as possible because this will be adding to that particular frequency and could damage your speakers if done incorrectly.
If there is too much bass lower your sliders to the left. If there is not enough highs boost the sliders to the right up to about half way then start decreasing the bass to get the desired effect. Small increments is important.
I found that if you go to your local music store the people there are more than willing to help you.
Posted on Jan 26, 2010
I need data sheet or user manual for my pioneer graphic equaliser
If is a parametric equalizer is zero watts. ,pionner should have a front, rear and subwoofer connections. If i remenber correctly, a single rca going to your stereo and the rest from eq to amp or amps. Hope this helps ,hope you get WIRED.
May 15, 2013 | Pioneer EQ-6500 9-Band Car Equalizer
Can I download and print the manual for the ART 355 Dual 31 Bank Graphic Equalizer
Simple, how much instruction would you need? Check here http://www.manualslib.com/manual/210377/Art-355-Eq.html
Mar 05, 2013 | ART 355 Dual 31 Band Graphic Equalizer
Can a ten band equalizer be used on a JVC rx-8030v 6.1?
Yes.
Use the Tape/MD or the one next to it (lower)
Aug 12, 2012 | JVC RX-8030V Receiver
When i turn my 10 band eq I hear a radio station
As cool as that might be for some people I am sure you find it a nuisance.
Check for loose or disconnected ground wires all the way from the instrument to the pedal, and inside the pedal.
It may be a cold solder joint as well (disconnecting something from ground, and letting the radio station sneak onto the signal line)
The EQ and anything connected to it could be the problem, but start with the pedal itself and then the instrument and it's cable.
Mar 09, 2011 | MXR M108 10 Band Graphic Equalizer Pedal
I need a wiring diagram for the pyramid 10 band graphic equalizer. Where can I find this diagram?
Click on MANUAL DOWNLOAD
LOOK PAGE 4 INTO THE PDF FILE!!!!
http://www.pyramidcaraudio.com/sku/903G/10-Band-Half-Din-Power-Booster-Graphic-Equalizer-Amplifier-200-Watts#
Oct 10, 2010 | Pyramid 903G 10-Band Car Equalizer
I need a wire diagram for equalizer 903g
Jan 29, 2010 | Pyramid 903G 10-Band Car Equalizer
196 people viewed this question
 Grubhead
Grubhead
