Question about HTC PPC-6800 Smartphone
Htc mogul cant receive any internet connections on my mogul....shouldent it be free because i have wi fi
  • 2 more comments
  • Anonymous Jan 16, 2009
    I am unable to get the wi-fi to work. I owned the previous phone and never had a problem connecting to open unsecured internet hot spots. What gives? I'm frustrated!
  • xcthulhux Feb 27, 2009
    Can connect to wifi, but cannot get on internet. wifi works on my laptop and nintendo ds, but not my mogul.
    it worked this morning, i got it flashed to cricket this afternoon, and then after that it hasn't worked.
    my mom has the same phone flashed to cricket and it works fine.
  • Anonymous Mar 13, 2009
    Gosh my phone has the same problem is anybody going to fix it????
  • el_papi_80 Apr 01, 2009
    I have a XV6800. I have been able to use the wi-fi service till now. I had custom rom, all of the sudden the wi-fi stopped working so I did hard resets, change roms, and also even changed it back to the original rom and still wi-fi not working. i called Tech support and they were not able to help and took it to the store and same thing.
    if any one out there can provide me with some assistance will be much appreciate.
I downloaded Monster WiFi for my htc and it unlock the wifi that the company locked out. It work.
Posted on Oct 17, 2009
    Problem Solver:
  • 5 Answers
The Mogul has a switch on the side of the phone to turn the wifi on. Double check to make sure that is enabled. If you have not enabled the wifi and your data connection is disabled you will be unable to use the internet.
Posted on Aug 05, 2009
  • 56 Answers
Depending on what company it was/is on they probably locked out wifi, im having the same issue, and im still searching for the answer
Posted on Jul 21, 2009
  • 813 Answers
Can you turn on the wifi connection?
Posted on Oct 29, 2009
HOW TO CHANGE THE INTERNET SETTINGS IN THE HTC WILDFIRE A3333
Wi-Fi provides wireless Internet access over distances of up to 100 meters (00 feet).
To use Wi-Fi on your phone, you need access to a wireless access point or "hotspot". The availability
and range of the Wi-Fi signal depends on the number, infrastructure, and other objects
through which the signal passes.
Turning Wi-Fi on and connecting to a wireless network
From the Home screen, press MENU, and then tap Settings > Wireless & networks.
Select the Wi-Fi check box to turn Wi-Fi on. The phone then scans for available wireless
networks.
Tap Wi-Fi settings. The network names and security settings of detected Wi-Fi networks
are displayed in the Wi-Fi networks section.
If the wireless network you want to connect to is not in the list of detected networks,
scroll down the screen, and then tap Add Wi-Fi network. Enter the wireless network
settings, and then tap Save.
Tap the Wi-Fi network you want to connect to.
If you selected an open network, you will be automatically connected to the network.
If you selected a network that is secured with WEP, enter the key and then tap
Connect.
Depending on the network type and its security settings, you may also need to enter more information
or choose a security certificate.
When your phone is connected to a wireless network, the Wi-Fi icon appears in the
status bar and tells you the approximate signal strength (number of bands that light up).
The next time your phone connects to a previously accessed secured wireless network, you
will not be prompted to enter the key or other security information again, unless you reset
your phone to its factory default settings.
Jan 28, 2015 | HTC Wildfire A3333 Cell Phone
Cant connect to wifi
watchout if wi-fi router is displayed only to limited people else try this.
reset factory default settings and try different wi-fi settings in wi-fi settings menu
Jan 20, 2013 | HTC Desire HD Cell Phone
How do i connect to the wifi
If you need to connect your HTC Wildfire to a Wi-Fi network then check out this simple, step-by-step user guide to getting connected wirelessly
If you're using your HTC Wildfire for the first time, you can easily select the Wi-Fi network you'd like to join using the setup manager.
When you opt in for either Mobile Network or Wi-Fi, or just Wi-Fi, the Wildfire will by default try to connect to a Wi-Fi network near you.
Select the network you wish to connect to, enter the password if required and you're set up.
If you want to change the settings, or set it up for the first time, you can do this through the Settings menu.
Note: If you're attempting to access a network-based page or app, you may be required to set up a new Wi-Fi connection. When prompted, select the option to set up a new connection.
  1. Access the Wi-Fi settings menu by navigating to the Wireless & networksmenu
  2. Select Wi-Fi settings
  3. Choose a listed network, or add a hidden network by selecting Add Wi-Fi network
  4. If you choose one of the listed networks and it's secured, enter the password, press Connect and you'll be connected to that network
  5. If you wish to access a hidden network, select Add Wi-Fi network and enter the SSID
  6. If a password is required, you'll be prompted to enter this before connecting
If Wi-Fi is turned off, you can now turn this on by ticking the box in the Wireless & networks menu.
links that may helphttp://www.htc.com/uk/howto.aspx?id=3381&type=1&p_id=316 http://www.knowyourcell.com/htc/htc-wildfire/wildfire-guides/487458/how_to_set_up_a_wifi_connection_on_the_htc_wildfire.html
Jul 28, 2011 | HTC Wildfire Cell Phone
How do i get my phone to connect to the internet
You must have internet service, example an anything data plan. Then all you do is tap on the internet ball and it conects.
May 24, 2011 | HTC Desire Cell Phone
Hiii ... i am harjit and wanna connect my htc hd2 with my laptop... i need pc suit to open internet browser.. help me soon plz
hi
your phone support to act as wi-fi Rotor please see this video connect your pc to your phone wi-fi access point then simply access the inter net
see this link
http://www.youtube.com/watch?v=A208VI461yo
if any doubt replay me
Apr 19, 2011 | HTC HD2 Smartphone
C an not buy muisic,they said, i'm not connect to the internet
You have to ocnnect your iphone to internet first , Follow below step to connect to internet
When you use any Internet enabled application, iPhone does the following in order until connected:
  1. Connects over the last Wi-Fi network you used that's available.
  2. If no Wi-Fi networks you've used are available, shows a list of Wi-Fi networks in range. Tap a network and, if necessary, enter the password to join. Networks that require a password show ht1695_1.jpg next to them.
  3. If no Wi-Fi networks are available or you choose not to join any, iPhone connects over the cellular data network.
Note: You can be on a call and use Wi-Fi or 3G1 at the same time. Other cellular data networks are unavailable while you're on a call.
Wi-Fi
  • Wi-Fi is often faster than cellular data networks. Wi-Fi networks cover limited areas. iPhone can join AirPort and other Wi-Fi networks at home, at work, or at Wi-Fi hot spots around the world.
    When iPhone is connected to a Wi-Fi network, the Wi-Fi icon ht1695_2b.jpg in the status bar at the top of the screen shows connection strength. The more bars you see, the stronger the connection.
  • To see all the Wi-Fi networks in range, from the Home screen choose Settings > Wi-Fi. Tap a network to join it.
  • Many Wi-Fi networks can be used free of charge, and some require a fee. To join a Wi-Fi network at a hot spot where charges apply, in most cases you can open Safari to see a webpage that allows you to sign up for service.
For information about configuring Wi-Fi settings, see the "Wi-Fi" section of the iPhone User's Guide.
Note: iOS devices sold in China may use the term Wireless LAN (WLAN) instead of Wi-Fi. Not all China iPhone models support WLAN; see this article for more information.
Cellular data networks
  • Cellular data networks allow Internet connectivity over the cellular network. Check your carrier's network coverage in your area for availability.
    You can tell iPhone is connected to the Internet over a cellular data network if you see ht1695_utms_onb.png,ht1695_3b.jpg or ht1695_gprs_onb.png in the status bar at the top of the screen.
    If you're outside your carrier's network, you may be able to use a cellular data network from another carrier. Roaming charges may apply.
    Note: If not on 3G, while iPhone is actively transferring data over the cellular data network-downloading a webpage, for example-you may not be able to receive calls. Incoming calls may go to voicemail.
I hope , after this , you will be able to connect to Internet....
Thanks
Sandeep
Mar 14, 2011 | Apple iTunes
What is wifi
Wireless local area network is a local area network that uses high frequency radio signals to transmit and receive data over distances of a few hundred feet, uses ethernet protocol.
In simple word allow you to surf internet without any internet cable connection, Wi-Fi enabled device such as a personal computer, video game console, smartphone or digital audio player can connect to the Internet when within range of a wireless network connected to the Internet. The coverage of one or more (interconnected) access points called hotspots, can comprise an area as small as a few rooms or as large as many square miles. Coverage in the larger area may depend on a group of access points with overlapping coverage.
In addition to private use in homes and offices, Wi-Fi can provide public access at Wi-Fi hotspots provided either free-of-charge or to subscribers to various commercial services. Organizations and businesses - such as those running airports, hotels and restaurants - often provide free-use hotspots to attract or assist clients. Enthusiasts or authorities who wish to provide services or even to promote business in selected areas sometimes provide free Wi-Fi access.
Thanks....!!!
Nov 06, 2010 | Nokia N81
Permenantly connected to the internet
Go to the following options
Settings > Wireless Controls > Wi-Fi Settings > Menu > Advanced > Wi-Fi Sleep Policy
This would stop the interent connection.
Thanks
Proton
May 21, 2009 | HTC G1
Wi-fi
You probably called their customer support or billing, which know nothing about technical stuff.
Wi-fi is completely independent from the cellular network, so it will not charge you anything. Wi-fi just connects to a wireless router, like the one in your home, if you have one. In other words it connects to the internet via someones home/office internet connection. I have a touch diamond and dont have a data plan, and only use wifi, works great..BUT:
If you do not have a data plan (pay as you go data) with Bell, IMMEDIATELY get a 'data block' on your phone, at first they might say oh it will not let you use some functions, etc, put insist, persist, and use force if neccesary as they dont like giving you a data block..It costs about $50 per mb if you use the pay per use internet! I think that was the 1X, but im not sure, its ridiculously high!
Mar 07, 2009 | HTC Touch Pro Smartphone
HTC PPC-6800 Smartphone Logo
1,110 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
