Question about PANDIGITAL SuperNova
The place where i enter my charger has broken inside the tablet
The area where i enter my charger has broken inside the tablet
  • Debbie Jul 17, 2013
    same thing happened to mine and the instruction booklet says do not send back to point of purchase i purchased mine from QVC is there anyother way to charge it besides the one plug in point?
  • sophielaycoc
    sophielaycoc Feb 05, 2014
    same thing happend to mine also.. i now cant charge it... is there another way?
  • 25 Answers
That you would need to go either to where you purchased it to be repaired, or they will have to send it out to the manufacturer to be repaired. That is not something you can fix yourself. At least, I would not recommend you trying.
Posted on Feb 17, 2012
  • 33 Answers
Charge it using the mini usb port.
Posted on Aug 04, 2013
Keeps saying connect charger even wben charger connected.iam trying to charge tablet
probably your charger is broken or your charging port is broken. either way, if the charger is broken, its cheap to replace. if the port is broken, its cost a bit more
Dec 05, 2015 | Dragon Touch Touch 7 Purple Dual Core Y88...
My irulu tablet wont charge
Check charger, cable and connectors. When you can borrow another charger try that one. If a new or good charger does not change the situation, and nothing is in the connector, the defect must be in the tablet, like a bent or broken pin in the connector, or a broken cable inside. An oxidised connection inside or just a defective main board, to mention some possible causes. As soon as the tablet needs to be opened, consult a tech, or start saving for a new tablet.
Apr 24, 2015 | Tablets & eReaders
My tablet was in use, needed charging, it shut off. Now it won't charge or come on
It sounds like there's a problem with the charger. The wire on the charger is rather delicate. So is the port on your tablet where the wire plugs in. There may be a break inside the wire. If you dropped your tablet while the wire was plugged in and it hit the floor on the charger plug, the charger plug could have damaged the charging port in the tablet or the wire itself could be damaged.
Find someone else who has the same tablet and ask to switch chargers to see if either of them still work on the other tablet. If your friend's charger starts charging your tablet without a problem, then the problem is a a broken wire in your charger. If neither charger will charge your tablet but both chargers charge your friends tablet without a problem, then the problem is with the charging port on your tablet.
Mar 17, 2015 | Tablets & eReaders
SM-T211Why will tablet not turn on or charge
When it does not have enough power, it can't switch on. And even a new charger can't get in any power if inside the tablet is something wrong. Like a dirty or defect connector, or inside a bad or broken cable. also check the connector, where you put the charger cable in.
Feb 13, 2015 | Samsung Galaxy Tab Tablet PC
Charger
If the end of the charger broke off inside your nabi, it will be difficult, but you can get it out. Ideally you still have the broken piece. Superglue the end, put it back in and let it set, then pull it out quickly. If you don't have the rest of the broken piece, you can use something like a toothpick or a cotton swab with the cotton tip removed. Check out YouTube for videos on this. If your charging cord just fell apart and nothing is broken inside your nabi, just buy a universal charging cord. Make sure the tip matches the one you broke. Amazon is a good place for finding these. It will still charge your device.
Apr 16, 2014 | Nabi 2
Hisense sero 7 lite
check wires....if it's not broken or damaged.....
check if cable is not broken around connector area or around plug...
check if you connected connector deep enough while charging..... check if connector on tablet is clean, if not, try to clean it, remove dust from inside
Jan 13, 2014 | Tablets & eReaders
Tablet will not charge
then you may need to have the charging port looked at it may be broken or loose on te inside and try another charger first just to be sure it's not the charger
Nov 11, 2013 | Tablets & eReaders
I I dropped my samsung galaxy tablet with the charger plugged in. Now it will not take a charge. The green battery leitz does nothing while the charger is plugged in. I have an official samsung galaxy...
Hello, Mackenzie -
It seems that when you dropped your tablet something may have been knocked loose inside the tablet or something may have broken.
That means you will need to take your tablet to a reputable computer repair business in your area to have a repair technician check it out.
Usually for such repair evaluation services you will have to pay an initial inspection fee. The place where I take my computers and tablets charges $35 for an initial inspection and repair evaluation. Then, if the equipment can be fixed, they tell me the repair cost from which the initial $35 evaluation fee is deducted.
Note: In the future, after having to pay to get your dropped tablet fixed, you may choose to purchase a protective case for your tablet, to help prevent any damage from future accidents.
Jan 02, 2018 | Samsung Galaxy Tab Tablet PC
PANDIGITAL SuperNova Logo
1,250 people viewed this question
Top PANDIGITAL Tablets & eReaders Experts
Colin Stickland
Colin Stickland
castletech
castletech
Are you a PANDIGITAL Tablet and eReader Expert? Answer questions, earn points and help others
