Question about Garden
JS20 walk behind wont stay started
It runs great for about 10 minutes after it warms up it dies .Have had the carb serviced and cleaned twice.. it works great for about 3-4 mows then back to dying again
    Sergeant:
  • 316 Answers
Hello,After it stalls take the fuel cap off and put it back on and see if it starts,maybe the cap is bad or clogged and not letting air in to equalize the pressure of the fuel being used in other wards a clogged vent, this is a small thing but a big problem,,hope this helps, ``
Posted on Feb 20, 2012
redbeard00
  • 957 Answers
SOURCE: Craftsman GT5000 W/22hp B+S surges and dies when warm
Replace the spark-plug, check the quality of the fuel(gas that is mixed or was stored more then three months is stale and wont fire correctly) make sure the fuel and air filter not clogged. If there is no change then your problem may be more technical, a nest may be restricting the govenor or you missed something with the carb and there still is debre causing it to stall.
Posted on Apr 24, 2009
  • 109 Answers
SOURCE: Last weekend I sharpened the blades, changed the
There is an operator presence switch under the seat...if the mower shuts off when you release the brake, this switch is faulty and must be replaced
Posted on May 03, 2009
  • 246 Answers
SOURCE: dies after 10-15 min of use
Hello barcomb31:
>>The Following is a Basic Instruction File I made for this. Any Input is Appreciated. I Usually Suggest you Check the Following in this Order for a Problem like yours. 1- Check the Gas Tank Cap and Ensure it is Venting the Tank. A Vacuum Builds in the Tank and the Gas Flow Stops or Slows (15 to 45 Minutes and if the Small Grainular Sand is in the Tank it can Take Several Days of Constant Running to Bring All the Sand Particales to the Tank Outlet Port) to a Point it Shuts Off the Engine. 2- Operate the Equipment Until it Quits (15min to 1hr). Then Immediately Check for Fire from the Plug. If the Plug is Firing, then 3- Check the Carburetor Solenoid. If the Carburetor Shut Off Solenoid has Current, then Remove the Carburetor Solenoid and Go to the Hardware Store. Purchase a Bolt of the Same Diameter and Threads. It Needs to be 3/4" Long. Put this Bolt in Place of the Solenoid. If this Corrects the Engine Problem, then Replace the Solenoid. ***NOTE: THIS IS FOR CHECKING THE SOLENOID ONLY I NEVER SUGGEST YOU OPERATE THE ENGINE WITH THE SOLENOID OUT OF THE CARBURETOR EXCEPT FOR TESTING PURPOSES*** Sometimes the Plunger is Moving, Just Not Far Enough to Allow the Gas to Enter the Jets. 4- Depending on the Model Mower, it can Also be the Pickup Tube in the Gas Tank. If No Fire, then Remove the Shut Off Wire from the Coil and Check for Fire. If Still No Fire, then the Ign Module or Coil is Bad. **Even if the Coil is New of Fairly New, it can Still be Bad.** On JD Mowers; Remove the Igniter/Module and the Coil and have the Local JD Dealer Test them.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 14, 2009
bridgesdean7
  • 41 Answers
SOURCE: 15.5 horse craftsman riding mower. Runs fine
carb is probaly dirty
Posted on Jun 03, 2009
  • 1129 Answers
SOURCE: Was mowing starting cutting out and died wont
replace the spark plug first then go from there, try starting fluid if flooded but also as soon as it fires during starting pull back the throttle off choke sometimes you don't want to give the unit full throttle when starting 3/4 throttle is good enough
Posted on Aug 02, 2009
Mercury 40 2011. Boat starts great but will turn off after 10 to 18 minutes of use. I then have to pump primer bulb a lot of times. I have replaced with new primer bulb but with continue to shut down.
Just some pondering........
Runs
good when cold but when warms up it dies.
Have you checked for spark at the plugs right after it died?
Have you tried priming it (squirt gas into carb)
What happens if you pull the choke on the moment that it starts to die?
Wild guess? Vacuum leak at carb gasket. If bolts are not snug, when the engine warms up it might expand enough to let air in past the gasket.
Please reply as a COMMENT to this post.
Jan 03, 2016 | Boating
I have a year 2000 toro dingo (walk behind). The I have a year 2000 toro dingo (walk behind). The motor runs great but stalls out immediately when I engage the track. To move forward or back. I checke
One of your hydro pumps are seized. this is causing the engine to stall when ever the torque is transferred to the pump. There are the small pumps (or final drives) under the engine. One or both need to be replaced
Mar 27, 2013 | Toro 2007 Dingo Tx420 Walk Behind Mini...
Start runs wants warm up dies wont start
experienced similar problem (1990 1500se)-removed carbs-repaired slides-yes they can be repaired, thoroughly (replaced no carb parts) cleaned carbs-runs/idles great.
Apr 08, 2012 | 1985 Honda GL 1200 Interstate Gold Wing
My 85 700 max sat for a long time. i put in a new battery and fresh gas with sea foam. i got it running and rode maybe two miles. now it wont stay running . it will start then die. then nothing. if i leave...
carbs dirty with varnish--may need to overhaul--but 1st clean float area to eliminate any possible clog--get a repair book for carb maintenance and service
Oct 12, 2011 | 1985 Yamaha XJ 700 X Maxim
I have a toro 72 that I just bought .Got it home and it ran great the first cut then a week later I ran for about 20 minutes and it started to sputter real bad and finally died.Now thats all it will do.I...
you should clean the fuel cell as well,when you clean the carb did you take the jet out as well,also always put a new spark plug in as well,they faul very easy
Jun 08, 2011 | Electrical Supplies
Engine starts and runs fine for about a minute
try to clean out the carb first with auto parts carb cleaner, then you may need to buy a totally new carb for the unit, as this company will NOT sell parts for these carbs due to the carb setting is sealed & has to stay at a set level for voltage output and setting
Nov 05, 2009 | Coleman Powermate Premium Plus 6250W...
Won't stay running
Check the gas cap vent. A partial vacuum in the tank will cause these symptoms.
Sep 06, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Wont stay running
Hello:
Soak and Clean the Carburetor.
Hope this Helps.
Good Luck
Respectfully
John
May 09, 2009 | Toro Lawn Mower With Toro Power Tools
Apr 24, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I would push the prime button 3 or 4 times it starts then quiet
I took my carburetor off and blew it out with compressed air. Runs great now. Make sure to get all of it. Little screw on bottom has a hole in it too!
Apr 18, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Garden Logo
73 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
