Question about Dryers
Asko 7005 dryer quit in middle of drying my clothes. the reset button didn't pop out. the power comes on but the dryer won't start. i here a ticking noise though....is it the fuse? i think the ventalation was messed up and blow something. asko 7005 dryer not running, power light on, fuses look okay, overheat button not popped out. What else can cause the problem?
  • Mary Schmitt Mar 02, 2009
    I have a similar problem with my 7005. It quit in the middle of a load, the power light is off (the washer is working and they're on the same cord-stacked) the reset is deployed and I've cleaned out all the lint places. It's plugged in and the circuit breaker has been reset. Do I have to call a servive person or have I missed something easy?
    Problem Solver:
  • 5 Answers
Go reset your circuit breaker. Even if it didn't pop out, reset it.
Posted on Dec 14, 2008
Asko 7005 dryer, start capcitor is cracked and has hard goo coming out the side, dryer wouldn't start and stay running, now it won't start at all. Could the capacitor be the problem or do you think...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 17, 2011 | Asko T781 Electric Dryer
When drying a load of clothes the dryer (Asko 7305) simply quit and when I came back to the unit the clothes were dry, but the digital panel was dark and no power available to the unit. I have pushed the...
Hello Susan, Welcome to FixYa. Have you checked to see if perhaps one or both of the fuses may have blown at the back of the unit...I don't mean the hi-limit that you already referred to...I mean the in-line fuses the Asko machines are equipped with. Let me know and we can move forward from here. Regards, Macmarkus :)
Sep 12, 2010 | Asko T761 Electric Dryer
I have a 7005 asko dryer and it is not drying clothes. It heats and tumbles for hours but the clothes never dry. I have cleaned the filter. Any ideas?
Hi, Sorry you have had to wait so long for an answer or possible solution. Hopefully it's not too late. There are two things to look for on an Asko dryer that is heating & tumbling but not drying ( since you've indicated the lint screen has been cleaned ) 1) a clogged vent...however this doesn't seem likely since you have heat & a poor vent usually trips the manual hi-limit reset on the heater housing in back. 2) a loose or broken exhaust blower wheel...this IS most likely and I've come across quite a few. The squirrel cage type blower has a "D" shaped shaft which fits to the shaft of the motor and is held there via a single nut. Over time or use, the blower will stripe the "D" shape shaft which enables it to not move the exhaust sufficiently, hence the items do not dry properly or as they once did. You can chrck this by pulling the access panel off followed by the plastic covering ( exhaust housing covers ) to expose the blower wheel. If it spins freely and independant of the motor, you'll need to tighten it or, more likely need to replace it. Hope this was helpful in solving your problem. Thanks for coming to "fixya" and let me know if I can assist you further. Good luck. Macmarkus :)
Mar 29, 2010 | Asko Dryers
No manual, don't know what the buttons do
laundry.manualsonline.com/.../asko/asko_clothes_dryer_product_list.html
Mar 31, 2009 | Asko T731 Electric Dryer
Asko 7005 and washer 10505
1) there is a reset button on the back panel of you dryer it is in the middle black rubber...
2) you really can't the asko washer needs a 240v to run... You can hire an licenced electrician to wire a 240v plug for your asko washer if you do not want to plug it into the dryer
Jul 01, 2008 | Asko W6021 Front Load Washer
Asko t760 display panel
My Asko T761 had the same problem, power button lights up but the LCD panel if off. This is not the fuse becuase I replaced with "new fuse replacement kit" provide by Asko but this did not solve my problem. All I needed to do was press the "reset button".
Feb 08, 2008 | Asko T761 Electric Dryer
Dryers Logo
392 people viewed this question
Top Dryers Experts
