Bunn NHB Coffee Maker
Problem for Bunn NHB Coffee Maker
Bunn CWTF15 Airpot brewer
By welchdrew on Oct 25, 2008
Help. Bunn CWTF15 airpot brewer with automatic water feed. The unit has a constant drip from the spout just above the basket. Never done this before and not sure how to repair. Thank you, Drew
Best Solution
posted on Feb 12, 2009
Very Helpful)
furnoptn
Rank: Guru
Rating: 89%, 69 votes
If the unit does this constantly, it's probably seeping past the solenoid valve. you can try taking it off and check for dirt or corrosion that is stopping it from closing properly, or replace it. the solenoid valve is located under the front panel, and is silver in colour with 2 wires & 2 copper tubes coming to it. as always, please be sure there is no power coming to the unit before servicing!!
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Bunn NHB Coffee Maker
Questions and Unsolved Problems for Bunn NHB Coffee Maker
Do you recommend Bunn NHB Coffee Maker?
Answer
Answer
How much water do I put in resivior to start the coffee pot.
Answer
I have a small water leak at the back of the coffee pot. Water is coming from inside the coffee pot.... (More)
Answer
when water is put in the maker, it will leak about a cup. can it be fixed
Answer
my bunn coffee pot is leeaking water out the holding pot, then it onloy makes half a pot of coffee... (More)
Answer
my bunn is leaking water out the back
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Bunn NHB Coffee Maker:
Top Coffee and Esp... Experts
Rank: Guru Guru
Solutions: 2511
Experience: ASE Certified Master Car and Truck Mechanic Certified AC mechanic Cert. AWS Cert. welder Contract me
Ask Me
Find more Coffee and Esp... Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
