Question about Frigidaire FRS26H5AS Side by Side Refrigerator
I have a frigidare side by side refrigerator fghs2344kf4, the freezer if -27 and the refrigerator is 68 degrees. What could it be?
The freezer is solid frozen and the refrigerator is warm. I check the temperature settings and the freezer is set to 0 and the refrigerator to 35. please need some help all my food is spoiling.
  • Javier Pagan Feb 17, 2012
    Thank you Chris for the answer. I took a look at the damper before and it had a block of ice in it, not letting air go though. I took it out clean all the ice and connected back, i notice the damper moving open and closing, but after a few hours it was full of ice again. Any other thing come to mind?
  • Electrolux
    Electrolux Feb 17, 2012
    Well if the damper is continuing to freeze up that is your indication of a moisture issue. This could come from the doors not sealing all the way, having a gap or damage, or the fill tube to the ice maker not sealing where it goes back through the back wall. Check the doors and see if you notice any issues with the tubing in the surrounding area.
fridgetech
  • 473 Answers
SOURCE: food stays frozen regardless of temperature setting
It is possible it has a bad thermostat but most likely cause would be a bad damper motor.  It is the vent inside the fridge that opens and closes, based on temp. setting, to allow cold air from the freezer into the fridge section.
Posted on Oct 14, 2007
BNewberry
  • 93 Answers
SOURCE: WARM REFRIGERATOR
Sounds like the damper isn't opening. Put you hand on the Left wall of the fridge side, at the top. If you feel No Air. Then there is your issue. Bad Damper Motor. Also check the back wall of the freezer, there sould be No Frost. If there is then you have a defrost issue. Not a damper problem. One more thing. Make sure when you shut the fridge door, the light goes out. About a half inch or so before the door is completly shut, the light will go out, if not then thats your issue. Let me know how you make out.
Bill
Posted on May 15, 2008
Sea Breeze
  • 4654 Answers
SOURCE: frigidaire freezer cold, refrig in 50's.
Because the model FRT21P5A has a manual adjusting vent I believe your problem is either the defrost heater and defrost thermostat and or the cold control (thermostst) is not working correctly. When temperatures rise in the refrigerator side first that is a sign that the air flow from the freezer is restricted. You will need to unplug the refrigerator and remove the rear panel in back of freezer to confirm. If Iced over use a hair dryer to defrost and disconnect one wire on the defrost heater. Check the defrost heater with an ohm meter. You should get a reading. If defective and no reading you need to replace the defrost heater and defrost thermostat. Let me know what you find, Thanks Sea Breeze
Posted on Jul 19, 2009
bobicehouse
  • 1524 Answers
SOURCE: Neither the freezer or refrigerator side is cold.
Defrost problem.
Posted on May 08, 2010
  • 35 Answers
SOURCE: My refrigerator was not cooling
the defrost thermostat may be bad
Posted on Feb 28, 2011
Frigidare PLHS67EGSB1 IS 6 YEARS OLD Temperatue Fluctuates On freezer side
Good Morning bernie3003 - For this particular model, the control on the door is the brain which controls all the functions of the unit. If the temperature inside the unit is not reading the correct temperature, then there might be a thermistor or wiring issue between the thermistor and the main control board on the door. I would personally contact a professional to accurately diagnose the refrigerator to determine the root cause to reduce the risk of unnecessary parts.
May 19, 2013 | Frigidaire 22.5 Cu. Ft. Counter-Depth...
Frigidare freezer making buzzing sound like a motor
You hear the evaporator fan that is probably rubbing on some ice buildup. Remove the rear panel in the freezer to confirm that there is ice buildup and post back to me.
Nov 17, 2012 | Frigidaire FRS23KF7AB Side by Side...
My frigidare refrigerator has a freezer on top but the fridge door has dropped it is a newer frigidare how do I fix
The bottom hinge needs slackening off, lift the edge of the door in place and retighten the hinge screws; if it's not that loose, a sharp tap with the heel of your hand may bring it back into line
Apr 24, 2012 | Frigidaire Refrigerators
Frigidare model # frs26znh freezer side works good refrigerator side dose not get cold
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 13, 2011 | Refrigerators
Frigidare frs26znh freezer side works good refrigiator side dose not get cold
heatman101
Jul 13, 2011 | Microwave Ovens
My GE Profile PS123SGPA BS side by side keeps dripping water from the water dipenser
Frigidare Model FRS26H5AS Side by side HELP!!!
Water collects and freezes in the bottom of my Freezer eventually leaking out the freezer door.
Thank you!!! bstrickmaker@neo.rr.com
Feb 15, 2010 | Frigidaire FRS26H5AS Side by Side...
I keep my frigidare in garage even during winter time. When temperature drops to 3 degrees Celsius my frigidare stops working. Does anybody know what can I do to make frigidare to work and keep it in...
I know the minimum operating temp for many refrigerators is around 33 F (about a degree above freezing or so). This is due to the refrigerant gas within the compressor and the fact that it is not stable at low temps. Typically, a refrigerator's minimum ambient temp should be 50 degrees F (10 degrees C).
I don't know if there is a whole lot you can do. The refrigerator really wasn't built to work in such cold weather. You may either have to relocate it, put a heat source near it or look into a special freezer that is *supposedly* able to operate in much colder ambient temps.
Dec 07, 2009 | Kenmore Refrigerators
Freezer at 32 degrees, fan running ,fridge cool
The evaporator coils behind the rear cover inside the freezer are probably iced over because of defrost system failure. Defrost system consists of defrost heater, defrost thermostat and defrost timer(or motherboard in newer models.)
Jul 27, 2009 | Frigidaire FRS26H5AS Side by Side...
Frigidaire FRS26H5AS Side by Side Refrigerator Logo
79 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
