Question about Kenmore 63672 Convection/Microwave Oven
Kenmore Microwave turned off, not back on
After cooking an 11 minute dish in the microwave last night, our Kenmore Microwave model 665.61639100, serial number xcl2316605 completely turned off. It is mounted above the stove and wired to a regular receptical. There was no power surge and there are no breakers tripped at the box. The receptical still works (other appliances tested) but the microwave will not come back online, even after an hour unplugged. Is there a reset button or some other trick? It was manufactured in 2001.
  • catb723 Oct 27, 2008
    I just had the same problem with a GE microwave after 10 minutes and 30 seconds!
  • Kenmore Master
  • 5,568 Answers
Both of you have suffered at least a failed fuse and these are nearly always inside the housing.
Sometimes the fuse (which are calibrated pieces of special wire) will fail from metal fatigue but it can also mean that either the heavy current, high voltage rectifier that produces the magnetron voltage or the magnetron itself has failed.
Some units have separate fuses for the control and display electronics and another, very high current (~30 Amp)  fuse for the magnetron circuit.
Do not attempt to open the unit unless it is, and has been, unplugged for an hour or more.
Gaining access is generally not difficult and either the back panel or top can be removed with a half-dozen screws. The fuses may not always look the same but the most common is a ceramic case with metal ends and it might be pushed into a simple fixture that snaps over the metal ends.
If you do not own a simple digital multimeter, I recommend buying one. They are available from various sources; electronics and auto parts stores will have them for under $20 US or if in the US, check your local directory for Harbor Freight outlets. I have bought several for $3.00 there and scattered them around vehicles and the normal junk drawer in the kitchen. Even the simplest of these will have several basic ranges and the resistance range is the one used for checking that fuse.       Remove the fuse from its clips and measure it between the metal caps on the low range (often 200 Ohms). If the display does not change, the fuse is blown; if it shows something in tenths or at least below 10 Ohms, it's OK.
If you care to delve further into your microwave at all instead of replacing it (they have gotten almost too cheap to repair), comment back here again and I will try to guide you further.
Posted on Nov 17, 2008
Kenmore model 721 - Cooked a meal for 30 minutes. Afterwards the microwave did not heat. However, the next day it worked. A few days later, was operated for 20 minutes, and again did not heat, and has not...
Yes, there is a thermostat device located on the magnetron. It will open up (turning off the magnetron) when it gets too hot, and it will reset automatically after it cools back down (in 5 to 15 minutes). The question is, Why is is over-heating? Usually it is caused by the exhaust fan being turned the wrong way. (For example, it may be set to exhaust the air out through the top of the microwave, but you don't have a vent there.) That fan can be turned to exhaust air out the top, out the back, or recirculate the air back through the front of microwave. It's easy to turn it around - the hard part is that you have to take the microwave down to be able to pull the fan out and rotate it the right direction.
Jan 17, 2015 | Kenmore Microwave Ovens
I need instructions for 10in. microwave browner
Only place I've found is here: CorningWare Browner Instructions
As these dishes were designed by Corning for a 650 watt over, you can recalculate preheat and cooking times for your oven with the following formula:
650/(your oven's wattage) x (listed preheat time or cook time)
For example, for a Corning MW-9 dish, they list 4 minutes maximum preheat time. I have a 1,580 watt oven. So 650/1580 = .41 x 4 minutes = 1.64 minutes and about a minute and a half preheat. (MAX).
Mar 09, 2014 | CorningWare Microwave Ovens
My frigidare microwave model #FFMV162LB (about 5 years old) stopped working. I was cooking last night, and in the middle of it, the table stopped turning and the heat stopped. The timer still works and the...
After 5 years of service, there could have been a magnetron failure but the door interlock (latch) could have failed which would acccount for the turntable failure.
Feb 13, 2014 | Frigidaire FFMV162LB Microwave Oven
Electrical storm last night. Microwave (Panasonic NN-S669WA) has lost functions: quick minute, time-cook, stop/reset.
Is it dead now or just won't respond to the key pad? Try unplugging it from the wall for at least an hour. Plug it back in back in and see it it will reset...
Sep 17, 2013 | Microwave Ovens
Burns my popcorn constantly. is there a different setting i can put it on?
HELLO.
Solution to your microwave problem is given as below.
* 1 Set your Daewoo microwave on a countertop near an electrical outlet and plug it in. Open the door and place the circular roller guide in the center of the oven cavity, then place the glass cooking tray over it.
* 2 Set your food on a microwave-safe dish and then put the dish on the cooking tray and close the door. Make sure that it latches properly.
* 3 Turn the upper knob to select a power level. Power levels include "Defrost," "Med-High," or "High." If your Daewoo has a touch pad, touch the "Microwave" button once to set the highest power level. Touch it consecutive times to lower the power level.
* 4 Turn the lower knob to set the cooking time. For cooking times less than two minutes, turn the knob up past the two-minute mark, then back to the correct time. For touch pad models, enter in the cooking time with the numerical keys and then press "Start."
* 5 Open the door at any time to stop the cooking and check the temperature of your food. Shut the door to automatically continue cooking, or turn the timer knob to the right to add more time. For touch pads, press the "Stop/Clear" button, then key in a new cooking time and press "Start."
* 6 Open the door when the timer reaches the "Off" position and take out your food.
Thanks.
Sep 24, 2011 | Daewoo KOC-925T Microwave Oven
Kenmore microwave model 721.80033700 won't heat
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Jul 24, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
We were cooking a dish and stopped it at the mid point and to add some sauce and it would not restart. Clock and everything is out. Everything esle in house works, no circuit breakers were off. The Jenn...
The same thing happened to ours last night. We went to add another minute of cooking time and realized the oven was dead - no clock, no display of any kind, and no more cooking!
I've verified the power outlet is OK. Ideas???
Feb 19, 2010 | Jenn-Air M170 Microwave Oven
Kenmore built in microwave displaying "D" and wont heat.
"d" may mean demo mode. The first thing to try is a "hard reset". Unplug it from the power outlet for 10 minutes, plug it back in, set the clock, then try again.
Jun 06, 2009 | Kenmore 62622 Microwave Oven
I own a Advantium 120 Oven. I love my microwave however there are times that I need to stop the turntable in order to reheat or cook something in a casserole dish. How can the turntable be turned off?
I guess my problem cannot be fixed. I was told that my microwave turntable is automatic and cannot be turned off, therefore, if you have a 9 1/2 x 11 dish and need to reheat something it cannot go in the microwave because it does not fit .
Aug 26, 2008 | Microwave Ovens
Microwave light
my kenmore microwave model # 66222, doesn't let the steam out, its ventilated so I know thats not the problem, smells like its burning then shuts off and doesn't come back on until its cooled off, this happened when cooking a Baked Potato, also when I cook something for over 5 minutes
Aug 13, 2008 | Microwave Ovens
Kenmore 63672 Convection/Microwave Oven Logo
303 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
