Question about Ingersoll Rand Ingersollrand 2135timax 12" Titanium Air Impact
Help with air leak problem on Ingersoll Rand Ingersollrand 2135timax
    Habit-Forming:
    Scholar:
  • 102 Answers
I.R. has a tune up kit available which includes all the necessary gaskets and seals required for this tool.
Follow this link to see the parts list:
http://manualarchive.ingersollrandproducts.com/ir_pdfs/Tools/Vehicle%20Service%20Tools/Air%20Impact%20Tools/45534070_ed3.pdf
Tune up kit P/N 2135-TK2
Posted on Aug 30, 2014
5 Suggested Answers
SOURCE: ingersoll 261 problem
that tool is under warrenty whoever u bought it from should have it fixed. did u try to adjust the air flow on your forard and reverse by turning the nob right or left has numbers on it hold the trigger turn the nob i see what it does i rebuilt many a 261
Posted on Feb 21, 2009
  • 194 Answers
SOURCE: ingersoll rand 231A
if you have already used air tool oil you may have to take it apart and clean the motor vanes
Posted on Jan 30, 2010
pctech1
  • 1940 Answers
SOURCE: what the maximum working torque for a Ingersoll
Ingersoll Rand 2705P1 1/2 inch 40-200 ft lb Industrial Duty Impact Wrench
Max Torque 400 Ft-Lb
Pneumatic Impact Wrench, Industrial Duty
Pistol Grip Style
Standard Anvil
Square Drive Size 1/2 In
Torque Range 40-200 Ft-Lb
Average CFM @ 15 Second Run Time 4.2
CFM @ Full Load 23
Max Bolt Capacity 5/8 In
Free Speed 8500 RPM
Pin Retainer Type
Required Pressure 90 PSI
Air Inlet 1/4 In
Min Hose 3/8 In
Overall Length 6 3/4 In
Weight 2.55 Lbs
Country of Origin: USA
CR 4Z942
Posted on Mar 28, 2011
  • 11 Answers
SOURCE: I need to know were i can find a reverse valve assy for A 2135TiMAX 1/2 inch impact Ingersoll Rand
Call A-1 Hydraulics at 770-907-0013
Posted on Nov 13, 2012
Leaks air around fitting on bottom of handle. nut just keeps turning. .
Sounds like you might have an issue with the air inlet assembly (item# 26) at the very top there is a o-ring that is susceptible to wear (item # 28B) but it only comes in a repair kit p/n 2315-k303.
Removal requires a special tool p/n 2131-322 to depress the inlet clip (item # 27) to be able to slide the assembly out, but two small flat blade screwdrivers could be used as a substitute.
Follow this link to the parts list.
Sep 12, 2013 | Ingersoll Rand Ingersollrand 2135timax 12"...
How do i install trigger kit in qtimax
Unfortunately IR does not have a maintenance manual for this model, but you can use the manual for a model 2131.
The air inlet assembly is slightly different on both models but the parts kit will fit both models, assembly and disassembly are the same.
Follow this link for a maintenance manual:
http://manualarchive.ingersollrandproducts.com/ir_pdfs/Tools/Impact%20Tools/Air%20Impactools/45481785_ed1.pdf
Apr 03, 2013 | Ingersoll Rand Ingersollrand 2135timax 12"...
How do i change the sanding pad Ingersoll Rand Ingersollrand Dual Action Air Sander - 6
It simply unscrews. The pad is held on by a small bolt length attached to the pad. Unscrew it.
Jan 15, 2012 | Ingersoll Rand Ingersollrand Dual Action...
Want to turn when i plud the hose in , and not pulling trigger
YOU MIGHT HAVE A PROBLEM WITH THE THROTTLE VALVE AND/OR THROTTLE VALVE SEAT. THEY HAVE A TENDENCY TO WEAR AND FALL APART. USE P/N 2135-K303 INCLUDES ALL NECESSARY PARTS TOO CORRECT THIS ISSUE.
YOU CAN DOWNLOAD THE OWNER'S MANUAL AND PARTS LIST FROM WWW.IRTECHPUBS.COM
Sep 14, 2011 | Ingersoll Rand Ingersollrand 2135timax 12"...
Well my ir2135timax work on my 26gal air compressor that have 5.3 cfm at 90psi.
yes it will work. but you wont have full power since its made to run at 120 psi.
Aug 15, 2011 | Ingersoll Rand Ingersollrand 2135timax 12"...
Ingersoll Rand Ingersollrand 2135timax 12" Titanium Air Impact Logo
175 people viewed this question
Top Ingersoll Rand Air Tools & Compressors Experts
elunsford
Joe Garcia
Joe Garcia
John Trevino
Are you an Ingersoll Rand Air Tool and Compressor Expert? Answer questions, earn points and help others
